The client was experiencing issues with automatic translations on their WordPress site built with Elementor using WPML. Some elements like headers and footers were translated correctly, while others were not appearing as translated on certain pages, articles, and archives, despite being marked as 100% translated in the WPML dashboard.
1. We recommended increasing the WordPress memory limit to at least 128MB, as WPML requires more memory than the default 40MB provided by WordPress.
2. We advised installing the Advanced Custom Fields (ACF) Multilingual plugin to ensure compatibility with WPML for ACF fields.
3. To trigger an update of the automatic translations, we provided steps to bulk edit and apply changes without making any actual changes to the content. We also clarified that due to translation memory, there should be no charges for using Automatic Translation for content that has already been translated.
4. For the specific issue with the 'Capacity' field not being translated, we instructed the client to set the correct template for the English version of the page in Elementor and to clear any server-side cache that might be preventing updates from showing.
If you're experiencing similar issues, we recommend trying the steps outlined above. However, please note that the solution might be irrelevant due to being outdated or not applicable to your case. We highly recommend checking related known issues, verifying the version of the permanent fix, and confirming that you have installed the latest versions of themes and plugins. If the problem persists, please open a new support ticket with us.
Last updated by Marsel Nikolli 1 year, 4 months ago.
Assisted by: Marsel Nikolli.
March 12, 2024 at 11:57 am #15399249
Marsel Nikolli
Upon further checking, I've noticed that for the English version of: hidden link, the French "Loop Item" template ("Liste Appart Grid view Image Droite") was being used as well.
I already set the correct template by following these steps:
- switch to English language
- "Edit with Elementor" from the wp-admin top bar option
- on the Settings bar for the "Loop Item" element I set as a template the following:
"List Appart Grid view Right image"
* The same issue was happening for the page: hidden link, I changed to the correct templates as well.
Please check on your end and let me know if you have further questions or need further assistance.
Kind regards,
Marsel
March 12, 2024 at 5:43 pm #15400968
raphaelM-3
Thank you so much for your very good help Marsel.
