Last updated by Bobby 1 year ago.
Assisted by: Bobby.
July 25, 2024 at 10:55 am #16003106
michaelS-302
I was experiencing an issue with the translation of a radio meta field using 'Manual Input' in Crocoblock. The issue concerns the meta field 'kuenstler_instrument' of the Custom Post Type (CPT) 'kuenstler'. WPML was not translating the field options correctly. While the German version works perfectly, the English version does not translate the field options. I have already contacted the Crocoblock Support regarding this issue. They gave me the following instructions: For multi-optional fields like Radio, Checkbox, and Select, we need to use another approach by creating a glossary: hidden link Glossaries in our context are simply sets of value + label pairs that can then be used as a source of options for meta fields, form fields, and filters. To use glossaries in custom fields, check out this tutorial: hidden link We also need the glossaries to translate the meta fields. Follow this step-by-step guide: 1. Here is the glossary - hidden link Note that you need to format the option values correctly - use only lowercase letters in Latin with no spaces. You can separate words with dashes and underscores. 2. Meta field of the glossary - hidden link 3. Then, proceed to string translation and translate the meta field's label - hidden link 4. Add the translation for the glossary options (only their labels!) - hidden link Here is the translated meta field hidden link
The string translation is not working. The languages are mixed up. Some German words are shown in the English column and vice versa.
What is the issue with the string translation?
How can I resolve the issue of mixed-up languages in the translation?
July 28, 2024 at 8:03 am #16011762
Prosenjit Barman
WPML Supporter since 03/2023
Hello There,
Before this thread gets assigned to my colleague, I'd like to offer some initial guidance or potential solutions.
The instructions from Crocoblock support are accurate. Ensure the 'Save as array' option is enabled for the translation to appear correctly. If everything is configured as per the Crocoblock instructions, the translation should display properly on the frontend. If translations are mixed across languages, use String Translation to set the correct language and translate the text accurately.
Based on your screenshot, some strings in other languages are set to English. Change the source language of these strings and translate them using this guide: https://wpml.org/documentation/getting-started-guide/string-translation/how-to-change-the-source-language-of-strings/.
Please carefully follow all the instructions and I hope they will help. Please feel free to reach us if you need further assistance, we wilkl be happy to help.
Prosenjit
July 28, 2024 at 9:06 pm #16012621
michaelS-302
Thank you for your response. I think I could solve the String Translation issue.
It now appears correctly in the backend, but there are still issues on the front end form. Therefore, I believe this might be a Crocoblock issue.
Backend:
German Version:
[hidden link)
- See Screenshot1
In the backend, the musical instruments are displayed correctly in German.
English Version:
[hidden link)
- See Screenshot2
In the backend, they are also displayed correctly in English.
Front End:
German Version:
[hidden link)
- See Screenshot3
English Version:
[hidden link)
- See Screenshot4
However, on the front end form, the musical instruments are still displayed incorrectly. In the English version, they still appear in German.
What could be causing this issue?
Thank you for your assistance.
All the best,
Michael
July 31, 2024 at 10:57 pm #16027151
Bobby
WPML Supporter since 04/2015
Thank you,
Bobby
August 2, 2024 at 8:14 pm #16034752
michaelS-302
Hi Bobby,
many thanks for your message - fortunaty the issue could be resolved.
All the best,
Michael
