You are trying to update the WPML Multilingual CMS plugin to the latest version, but after installation and activation, the dashboard still shows the old version (4.5.12) even though the newest available version is 4.8.5. The update seems to complete, but the version number remains the same and the plugin behaves as if it never updated.
If you're experiencing this issue, we recommend you try registering a new site key:
1. Go to Plugins → Add New and click the Commercial tab. Then click 'Unregister WPML from this site'.
2. Once the page loads, click on 'Register WPML'. You will see a message asking you to enter the site key. Click on 'Get a key for this site'.
3. In your WPML account, complete the site key wizard and set it to 'Production site'.
4. Copy your new key and paste it in the Commercial tab. Afterward, you can delete your old site key in the WPML account.
If this solution does not resolve your issue or seems irrelevant due to being outdated or not applicable to your case, please open a new support ticket. We highly recommend checking related known issues at https://wpml.org/known-issues/, verifying the version of the permanent fix, and confirming that you have installed the latest versions of themes and plugins. For further assistance, visit our support forum at WPML Support Forum.
Last updated by Andrey 5 months ago.
Assisted by: Andrey.
November 19, 2025 at 10:23 pm #17593684
lencS
I am trying to update the WPML Multilingual CMS plugin to the latest version. After installing and activating the plugin, the version does not update. The dashboard still shows the old version (4.5.12) even though the newest available version is 4.8.5. No errors appear during installation. The update seems to complete, but the version number stays the same and the plugin behaves as if it never updated. Link to a page where the issue can be seen: hidden link
The plugin remains on version 4.5.12 after installation and activation, despite expecting it to update to version 4.8.5.
Why does the plugin version not update after installation?
How can I ensure the plugin updates to the latest version?
November 19, 2025 at 11:53 pm #17593716
Andrey
WPML Supporter since 06/2013
Have you tried to register a new site key?
1. Go to Plugins → Add New and click the Commercial tab. Click Unregister WPML from this site.
2. Once the page loads, click on Register WPML. A message asking you to enter the site key will appear. Click on Get a key for this site.
3. In your WPML account, complete the site key wizard and set it to Production site.
4. Copy your new key and paste it in the Commercial tab. When done, you can delete your old site key in the WPML account.
If it doesn't allow you to create a new site key, first delete the old one.
November 24, 2025 at 3:26 pm #17605432
lencS
I have managed to update with clean installs.
But now, I am getting a repeated 404 error in the browser console coming from the WPML “Account / Installer” dashboard.
Error in console:
GET hidden link 404 (Not Found)
frame_ant.js:2 window.fetch
frame_ant.js:2 xf
frame_ant.js:2 kf
dashboard.js?ver=485900:2 value
admin.php?page=otgs-installer-support:2133
WPML is trying to load a localization file for Slovenian (sl.json) that does not exist on your server, which results in a 404 on every admin page where the WPML Installer / Account dashboard runs.
What I need clarified:
Why is WPML requesting
when there is no Slovenian localization available?
Is this expected behavior or a missing file on the WPML side?
Can you provide the missing sl.json file or correct the request so the dashboard stops producing 404 errors?
This error occurs even when all WPML plugins are up to date.
Environment details:
WordPress version: 6.8.3
PHP version: 8.2
WPML Multilingual CMS: latest
WPML String Translation: latest
Browser: Chrome (also reproducible on others)
Please advise how to resolve this or if this is something that needs to be fixed on the WPML server side.
New threads created by Andrey and linked to this one are listed below:
https://wpml.org/forums/topic/split-i-am-getting-a-repeated-404-error-in-the-browser-console/
November 24, 2025 at 4:14 pm #17605683
Andrey
Thank you for your feedback.
I’m glad to hear that you were able to update the plugins. Since the new issue appears to be unrelated, I’ve created a separate support ticket to keep everything organized. I will continue assisting you here:
