Last updated by Shekhar Bhandari 11 months, 1 week ago.
February 25, 2025 at 4:26 pm #16747041
desireeM
I am trying to convert URLs using the WPML plugin, specifically in the file sitepress-multilingual-cmsclassesurl-handlingconverterstrategyclass-wpml-url-converter-domain-strategy.php. The code snippet involved is:
<code>
public function convert_url_string( $source_url, $lang ) {
$original_source_url = untrailingslashit( $source_url );
if ( is_admin() && $this->get_url_helper()->is_url_admin( $original_source_url ) ) {
return $original_source_url;
return $this->convert_url( $source_url, $lang );
</code>
The untrailingslashit function causes URL conversion of URLs without a trailing slash to include a trailing slash when converted, which is incorrect. I expected no trailing slash when the source URL does not contain one, but instead, I got a trailing slash.
Why does the URL conversion add a trailing slash when it shouldn't?
How can I prevent the trailing slash from being added during URL conversion?
February 28, 2025 at 5:28 am #16758786
Shekhar Bhandari
WPML Supporter since 03/2015
Thank you for reaching out to WPML support. I'd be happy to assist you with this issue.
To address your questions accurately, I’ll need to escalate this to our 2nd-tier team. However, before doing so, could you provide a few examples of pages where you're encountering this issue or any steps to reproduce the error. This will help us better understand the behavior and proceed accordingly.
March 4, 2025 at 7:37 pm #16775753
desireeM
e.g.
var_dump( apply_filters( 'wpml_permalink', '<em><u>hidden link</u></em>', 'de' ) );
March 5, 2025 at 9:35 am #16777526
Shekhar Bhandari
Hello there,
I asked our 2nd tiers about the issue and they mentioned the following:
[php]
Permalinks returned are based on the permalink settings - if the value is /%postname%/ then you will got a trailing slash. if this is without trailing slash, you will receive it without the slash.
Let me know if this helps.
March 5, 2025 at 2:11 pm #16779368
desireeM
Why do you think did I specify the request URI in the example as "/some-invalid-url" ?
March 6, 2025 at 9:42 am #16782171
Shekhar Bhandari
I believe you specified the request URI as /some-invalid-url to demonstrate how the system handles invalid or unexpected requests.
If you’re looking to retrieve results regardless of the permalink settings, please let me know. I can escalate your request to our second-tier team for further assistance.
The topic ‘[Closed] URL conversion incorrectly adds trailing slash’ is closed to new replies.
