Last updated by Prosenjit Barman 1 year, 5 months ago.
October 28, 2024 at 9:53 pm #16339811
reneG-31
I am developing a site and trying to create a second language version. I have translated everything except the products. On different language websites, the product are not visible
How can I use German language products on different language websites e.g. English version of my site?
October 29, 2024 at 7:16 am #16340326
Prosenjit Barman
WPML Supporter since 03/2023
Hello There!
I understand your requirements. Please follow the steps below to display the default products in other languages.
- Make sure that the WooCommerce Multilingual plugin is installed and activated on your site.
- Now, go to "WPML > Settings" and scroll to the "Post Type Translation" section.
- Locate the 'Product' post type and set the translation preference for the post type to "Translatable - use translation if available or fallback to default language" and save the changes.
This will allow the default products to display in other languages until the translations are completed.
Please feel free to let me know if you need further assistance or clarification on any specific point. I'll be happy to help.
Prosenjit
October 29, 2024 at 9:19 am #16340876
reneG-31
That is what I have done. In addition, the products should not be translated, but should fall back on one language in the long term.
I have noticed that the language switch only shows the source language, but not others, even though they are set as visible.
October 30, 2024 at 3:27 am #16344616
Prosenjit Barman
Hello There!
Thank you for the update!
If the Fallback option is selected, the default product will appear in other languages, and the language switcher will display all available languages on your site.
After adjusting the Translation settings, have you checked by clearing the caches from your site and browser?
If the issue persists even after that, Could you please share the WPML Debug Information of your site so that I can get a better overview of your site and system?
- Here's how you can get the Debug Info: https://wpml.org/faq/provide-debug-information-faster-support/
Copy the Info and paste it into the Debug information box located just below the reply box. I'll check and assist you further in this matter.
Prosenjit
October 30, 2024 at 11:52 am #16346680
reneG-31
Cache got cleared multiple times
November 1, 2024 at 4:09 am #16353811
Prosenjit Barman
Hi There,
Thank you for sharing the WPML Debug info!
From the WPML Debug Info, I noticed that the WPML plugin and its add-ons are not updated to the latest version. Additionally, the translation preference for the Product post type is set to "Translatable - Only show the translated items." As a result, default products aren’t appearing in other languages since they haven’t been translated.
Please begin by updating the WPML, String Translation, and WooCommerce Multilingual plugins to their latest versions (WPML -> 4.6.13, String Translation -> 3.2.14, WooCommerce Multilingual -> 5.3.8). After updating, follow the recommendations provided in my first message(https://wpml.org/forums/topic/use-german-products-on-different-language-sites-e-g-english/#post-16340326). This should allow the default products to display in other languages and ensure the language switcher shows all languages until the products are translated.
Please give it a try and let me know how it goes. I'll be happy to help if you need further assistance in this matter.
Prosenjit
November 1, 2024 at 9:35 am #16354412
reneG-31
It shows there is a communication error, so there is no update possible.
In the log it mentioned Sitekey no-match
November 2, 2024 at 8:54 am #16356409
reneG-31
(Unable to register: Site key not matching)
November 4, 2024 at 4:07 am #16358701
Prosenjit Barman
Hello There,
I hope you're doing well. Sorry for the delay in responding due to the weekend.
The issue you encountered typically occurs when the WPML site key is incorrect. Based on the information in our system, I noticed you've registered a site without 'www,' but in the WPML Debug Info you shared, the site URL includes 'www.' This mismatch may be causing the license server not to recognize your site, preventing the plugin from updating.
If you prefer to use 'www' with your domain, you'll need to register a license specifically for the 'www' version and use that key to register your site. Alternatively, you can remove 'www' from the Site and WordPress URLs under Settings > General. Then, go to "WPML > Support > Troubleshooting" and click on the "Refresh license data" button at the bottom.
Once the license data is refreshed, you can attempt to update the plugin again.
Please try and let me know how it goes. I'll be happy to help if you need further assistance in this matter.
Prosenjit
November 5, 2024 at 10:00 am #16365277
reneG-31
Thanks, it worked.
There is one more thing - in the sitemap (regardless of how it is created), only German is listed in the default wp sitemap. If I use e.g. The SEO Framework, Yoast or Jetpack to create it, only English is listed. What could be the reason for this?
November 6, 2024 at 4:19 am #16369697
Prosenjit Barman
Hi!
Thank you for the update.
Glad to hear that the suggestion helped.
Regarding the sitemap issue, please note that the sitemap will only display posts and pages available in each language. If you have posts in both German and English, they should appear in the sitemap. Since WPML SEO is installed on your site, please regenerate the sitemap by disabling and then re-enabling the sitemap option, and check the sitemap again.
Please note that in WPML > Settings > Post Type Translation, if any post type translation setting is set to "not translatable" or "Translatable - use translation if available or fallback to default language," the contents of that post type will not appear in the sitemap for other languages.
Prosenjit
November 6, 2024 at 8:17 am #16370039
reneG-31
THat was not helpful - the conditions are clear, please help at the real problem why onlyone language is displayed even when it is translated. I do not mean different sitemaps, there is not even one sitemap containing all pages
November 7, 2024 at 4:11 am #16375079
Prosenjit Barman
Hello There!
I’m sorry to hear that the previous response wasn’t helpful. I’ll do my best to address your concern. Could you please provide the sitemap URL so I can check the available content?
If there are any issues, a closer inspection will be required to understand the root cause of the issue.
IMPORTANT
Best Regards,
Prosenjit
November 10, 2024 at 3:50 pm #16385898
reneG-31
Please have a look on sitemap:
At the moment it only shows german pages and products, why ever it shows no categories or other languages
November 11, 2024 at 6:06 am #16386596
Prosenjit Barman
Hi There!
Could you please check if the pages and products on your site have been translated into other languages? If they haven’t, it’s expected that the translated versions won’t appear in the sitemap, even if you’ve set the translation preference for the post type to display the default version in other languages in WPML settings. The sitemap will only include the pages and posts that are currently available on the site.
If they are translated and if you still don't see them in the sitemap, a closer inspection will be required to understand the root cause. Please share the access (wp-admin and FTP) to your site to take a better look at the issue. I have enabled a private box for you so that you can securely share access to your site. The private box looks like this:
Prosenjit
The topic ‘[Closed] use german products on different language sites e.g. english’ is closed to new replies.
