You are experiencing inefficiencies in uploading images with localized filenames for SEO purposes using WPML Media Translation. You've noticed there is no automatic process for translating filenames, which makes the process time-consuming.
We have considered the possibility of implementing automatic filename translation. However, after internal discussions, we decided not to pursue this feature at the moment. The main reasons are the lack of sufficient demand from our users and the potential increase in database usage due to file duplication. WPML is designed to focus on translating user-generated content like alt texts and captions while using the same media file across different translations.
If this solution does not resolve your issue or seems outdated, we recommend checking the related known issues and verifying that you have the latest versions of themes and plugins installed. If the problem persists, please open a new support ticket.
Last updated by 7 months ago.
