The client is experiencing an issue where the WooCommerce Min/Max Quantities plugin is not enforcing the set limit of 3 pieces per product on the Arabic version of the site, while it works correctly on the English version.
We found that the custom fields for the quantities were not being copied. We have now set these fields to be copied. We recommend that the client updates the products in the default language and then checks if the issue has been resolved.
If this solution does not seem relevant to your situation, please feel free to open a new support ticket with us.
Last updated by Osama Mersal 1 year, 8 months ago.
Assisted by: Osama Mersal.
January 14, 2024 at 10:52 am #15182204
muhamedF
Hi Osama,
2. I have recently installed a new plugin called (WooCommerce Min/Max Quantities) in an effort to limit the quantity that my customers can be per product .. The limit I set is 3 pieces per product .. The plugin is working as intended in the English version .. When I go to the cart page in English, it does not let me increase the quantity above 3 .. However, when I change the language to Arabic and visit the cart page, for some reason I can bypass the limit and increase the quantity above 3 .. Please feel free to test that on your end to confirm the issue ..
After contacting the developers of the plugin, they recommended I discuss this with the WPML developers, as the issue seems to be happening only when the website is in Arabic ..
Can you please look into this and help me figure out how we can enforce the 3-quantity policy?
Best,
Muhamed
ninalaskincare.com
January 14, 2024 at 11:18 am #15182227
Osama Mersal
WPML Supporter since 02/2020
Please login to this sandbox site and install the mentioned plugin. (hidden link)
After that, please try to reproduce the issue issue. If the issue is replicable, please let me know how to reproduce it.
Osama
January 15, 2024 at 4:03 am #15182922
muhamedF
Hi Osama,
Unfortunately, I cannot install the min/max extension on the sandbox as I would have to disconnect the license from my store, which would stop the functionality all together ..
However, I screen recorded the issue on my iPad and below is the icloud video link:
Please let me know if you're having an issue accessing/watching the video ..
I hope the video helps demonstrate the issue ...
January 15, 2024 at 8:40 am #15183572
Osama Mersal
I would need to look closely at your site, so I would need to request temporary access (WP-Admin and FTP)
Osama
January 16, 2024 at 3:20 am #15187480
muhamedF
Osama,
I created a staging website, where we can safely make modifications/changes without affecting the main website .. However, switching to Arabic is not working on the staging website despite me registering it as a development website ..
The reason I'm bringing this up is because I'd like to test on the staging website, since deactivating all plugins and switching to the default theme for my other ticket, kind of ruined a couple of things on the main website ..
January 16, 2024 at 7:55 am #15188039
Osama Mersal
Thanks for the access details. I checked the issue and found that the custom fields for the quantities are not copied. (Kindly check the attached screenshot)
I set those fields to be copied. Please update the products in the default language and check the issue.
Osama
January 18, 2024 at 1:01 am #15197483
muhamedF
Great support from the team as usual
