You are trying to translate content using WPML AI, but the process gets stuck as 'In Progress' indefinitely. Switching to another engine like DeepL works immediately.
The issue arises because Swedish is not included in the supported language pairs for WPML AI. You can view the full list of supported languages here. We recommend using another translation engine for languages not supported by WPML AI.
If this solution does not resolve your issue or seems outdated, please check related known issues at https://wpml.org/known-issues/, verify the version of the permanent fix, and confirm that you have installed the latest versions of themes and plugins. If the problem persists, we encourage you to open a new support ticket here.
Last updated by 9 months ago.
Assisted by: Paola Mendiburu.
