If you're experiencing issues where translations are not rendering on the page despite following the guidelines, it might be due to the incorrect settings in WPML for the field groups post type.
We recommend checking the settings in WPML-> Settings-> Post Type Translation and ensuring that the field groups post type is set to "Not Translatable". If it is set to "Translatable", you should change it to "Not Translatable" and delete any translated field groups. This adjustment should help the data to appear correctly on the translated pages.
Please note that this solution might be irrelevant if it's outdated or not applicable to your case. We highly recommend checking related known issues at https://wpml.org/known-issues/, verifying the version of the permanent fix, and confirming that you have installed the latest versions of themes and plugins. If the issue persists, please open a new support ticket.
Last updated by Osama Mersal 1 year, 8 months ago.
Assisted by: Osama Mersal.
July 30, 2024 at 10:26 am #16019855
michelleM-17
I was trying to add translation for multiple languages. We have a paid version of WPML and a paid version of ACF PRO. I followed your guidelines.
We cannot make it render on the page.
Why is the translation not rendering on the page despite following the guidelines?
July 30, 2024 at 11:12 am #16020056
Osama Mersal
Would you please elaborate more on the issue to help me understand it better?
It would be very helpful if you could share screenshots or a screen-recorded video while reproducing the issue.
Osama
July 30, 2024 at 8:58 pm #16022285
michelleM-17
Here is one image attached where you can see ACF group.
Second image is inside that ACF group.
Now I have page, homepage, where I load that template with those modules from Customize, 4th image (i've duplicated 2nd by mistake).
When I go to check German (second translation) it show traslated strings. image 5 (dark image).
English is okay (you see text on the left side - on the image 6). (And we are on En US)
Last screenshot is when I change language to DE:
SImply ACF content is not rednered for languages, except fro english. IS there something that I am missing.
THANK YOU, very much!
July 31, 2024 at 8:01 am #16023393
Osama Mersal
Thanks for your update. I would need to look closely at your site, so I would need to request temporary access (WP-Admin and FTP)
Osama
July 31, 2024 at 9:34 am #16023870
Osama Mersal
Thanks for the access details. I checked the issue and found that the field groups post type is set to "Translatable", while it shouldn't be translated.
So, I deleted the translated field groups and set the field group post type in WPML-> Settings-> Post Type Translation to "Not Translatable".
After that, the data appeared correctly on the translated hidden link">home page.
Osama
July 31, 2024 at 1:53 pm #16025692
michelleM-17
Thank you! It seems to be working, we will check further from here. THANK YOU!
July 31, 2024 at 2:14 pm #16025774
michelleM-17
well just few more things, i noticed that this is not translated:
and some content was broken:
on some of them , script was broken, I mean sliders are not working:
not how it looks like in EN version
Can you please describe me in steps what I should do for next?
Do I need to run translation to be generated again, or some parts of it?
Can you please check ?
New threads created by Osama Mersal and linked to this one are listed below:
https://wpml.org/forums/topic/split-wpml-and-acf-pro-problem/
July 31, 2024 at 2:15 pm #16025776
Osama Mersal
We try to keep one issue per ticket in our forum. Continuing with one ticket per issue helps supporters focus on one issue at once and enables other users to find solutions to their questions faster.
Therefore, I've split the other issue and created a new ticket with this issue.
Osama
