Supporter timezone: Europe/Zagreb (GMT+01:00)
This topic contains 13 replies, has 0 voices.
Last updated by Dražen 3 weeks ago.
Assisted by: Dražen.
January 28, 2026 at 9:24 am
veronikaS-2
Hello, since the original thread where we discussed the issue has been closed, I am opening a new ticket. The issue was: https://wpml.org/forums/topic/wpml-issue-with-variation-color-synchronization-unclickable-missing-variation-colors-in-trans-2/
The issue has currently reappeared in the CZ language version; it is not possible to select the color yellow. Two days ago, it was the color chocolate. Could you please check this? We have not made any changes to the product.
January 28, 2026 at 10:00 am #17769968
Dražen
Since there has been no activity for a while, I’ve converted this conversation into a ticket to avoid the chat being closed and so we can continue here without interruption.
I have some few follow-up questions:
- Could you please let me know what the han-admin.php must-use plugin is used for?
- Do you have any server-side caching enabled on your live website?
- Also, what is the purpose of the Lubive Addons by Hanuliak plugin?
- Does the issue happens after maybe client making an order or similar?
Drazen
January 28, 2026 at 10:33 am #17770055
veronikaS-2
Hello Drazen,
thanks for the follow-up. Please see the answers below:
han-admin.php (MU plugin)
This is our internal must-use plugin used only to visually indicate whether we are currently working on production or staging. It does not affect frontend functionality, orders, WPML, or WooCommerce logic in any way.
Server-side caching
We are using hosting from Hetzner. We did not explicitly enable or configure any server-side caching on our side.
The only related information we found is this documentation from Hetzner regarding cache lifetime:
Other than that, no custom server cache rules were set by us.
This is a custom plugin responsible for product filters, custom gallery, and variant switchers.
We investigated whether the issue could originate there, but did not find any internal problem. The behavior we observed is that WPML does not return the expected value for the given language, which causes the value not to be displayed.
We tested the same scenario using the default WooCommerce variation switcher, and the behavior was identical.
Relation to orders / stock changes
We did not observe whether the issue changes after an order is placed or when the product stock is reduced. At this point, we cannot confirm a direct connection to stock changes.
Let me know if you need anything more specific from our side.
Roman
January 28, 2026 at 10:42 am #17770081
Dražen
Hello Roman,
Thanks for getting back to me and for sharing the additional information.
This happens after probably stock / attribute sync was not correctly applied from default language to 2nd language. We need to find out what action that is done to default language / translated language is causing this to happens. Since you said it does not happen on staging site then it needs to be connected somehow to your live website and action that are done there.
At this point, we need to identify which action on the live site is causing this state to occur.
What I would suggest next is the following. First, please ask your hosting provider to enable SQL query logging on the server. Second, install and enable the WP Activity Log plugin from https://wordpress.org/plugins/wp-security-audit-log/.
When the issue happens again, please check the server and SQL logs with your hosting provider to see when the change occurred to stock or attribute values. In parallel, review the activity log to identify what actions were performed shortly before the issue appeared. In particular, look for actions affecting variations, attributes, or stock status on either the default language product or its translation. This is also why an order being placed could be a possible trigger.
By correlating the timing in the SQL logs and the activity log, we should be able to identify which action caused the incorrect state. Once we have that information, we can try to reproduce the same steps and investigate why it happens and how to prevent it.
I’m afraid this is the best approach I can suggest for now, as there are currently no clear or consistent steps to reproduce the issue, and it does not occur on the staging site. Monitoring and log analysis should help us narrow this down further.
I hope this makes sense and helps explain our position. Let me know if you have any questions.
Drazen
January 28, 2026 at 5:48 pm #17771552
veronikaS-2
We will implement the above-mentioned changes tomorrow and keep you informed.
January 29, 2026 at 6:19 am #17772275
Dražen
great, thanks.
Let me know how it goes.
Drazen
January 29, 2026 at 4:20 pm #17774813
veronikaS-2
We have installed the WP plugin for logging that you recommended.
We tried to enable database logging on our side, but it was unusable after 15 seconds, with a log size of 25MB.
We will try to contact the hosting provider to see if they can enable logging on their side.
I will be in touch.
Roman.
January 30, 2026 at 7:00 am #17775650
Dražen
Hello Roman,
thanks for updating me.
Okay, sounds like a plan, let me know how it goes.
Drazen
February 2, 2026 at 2:13 pm #17784315
veronikaS-2
Unfortunately, our hosting provider is unable/unwilling to run database logs. Is there another solution to detect this problem on our end?
They asked us where exactly the problem lies, but I'm afraid that even if we take the trouble to describe the problem to them, they won't be able to help us.
Thank you very much for your response on how to proceed.
Roman
February 3, 2026 at 7:06 am #17785622
Dražen
Hello Roman,
thank you for the clarification, and I understand how frustrating this situation can be.
At this point, I’m afraid there isn’t much more we can proactively do or suggest until the issue can be isolated more clearly. Since it doesn’t present itself consistently on demand, the best approach for now would be to monitor the behavior closely.
If possible, I recommend keeping an eye on the live site and focusing on only single product where the issue occurs. Then try to identify the last action performed on that product before the problem appeared (such as an order, product update, or any automated process).
Once we can pinpoint what triggers the problem or gather a consistent reproduction path, we’ll be in a much better position to investigate further and advise next steps.
Hope this makes sense, I’ll be happy to continue helping.
Kind regards,
Dražen
February 13, 2026 at 10:59 am #17820063
veronikaS-2
Good day, it happened to us again. Thanks to the Activity log, we saw that the stock levels (by an order) of the product BARBARA - Brown were changed in the CZ language. An employee reported it to us. When we checked the handbag a few hours later (a purchase had occurred in the meantime), it was already back to normal. It therefore seems that the issue occurs when the stock is changed. Could you please check this on your side as well? Do you see anything in the logs that we might have missed? Thank you.
February 13, 2026 at 12:20 pm #17820477
Dražen
thanks for getting back.
I have checked but I do not see anything unusual in the logs. What I can see is the stock changing from 35 to 34, which looks like a normal change after an order.
Just so I understand correctly: do you mean that the stock was first changed after an order and the issue appeared, and then after another order it was automatically corrected and issue was gone or? That part is not fully clear to me, so I would appreciate if you could clarify the exact sequence.
Could you please try to repeat the same steps and check if the issue happens again, ideally on a staging site? If you can reproduce it, then it is likely related to a stock synchronization problem as we suspected, possibly caused by a plugin or similar. However, we first need confirmed steps and a reliable reproduction so we can investigate further.
Let me know.
Drazen
February 25, 2026 at 10:50 am #17850750
veronikaS-2
Good day,
We managed to simulate what is happening. Please see the recording here:
This issue also occurs even when we are not making any changes. At the moment, this is the only way we are able to replicate it.
February 25, 2026 at 12:32 pm #17851501
Dražen
Thank you for the detailed explanation and the video.
After reviewing your workflow, I believe the issue is related to the fact that you are using the WordPress editor for translating products. This is not the recommended method. With WPML, you should use the WPML Translation Editor to translate WooCommerce products.
I also noticed that the custom field attribute_pa_farba is set to “Copy”, while on a fresh test site it is set to “Don’t translate”. This difference in settings may also affect the behavior.
I recommend the following:
- Switch one product back to the WPML Translation Editor
- Update the product in the default language
- Re-translate it properly using WPML
- Apply the same changes as in your video and, if needed, use the arrows icon to update the translation so pencil icon shows and products are in sync
Please also review the custom field settings and confirm that no other related settings were changed.
Based on your workflow, I am assume this is related to using the WordPress editor instead of the WPML Translation Editor and possibly some adjusted settings.
Since this is a live production site, I am hesitant to perform debugging or make changes directly there.
Please check and let me know how it goes.
Dražen
The topic ‘[Closed] WPML – issue with variation color synchronization (unclickable / missing variation)’ is closed to new replies.
