Last updated by Shekhar Bhandari 1 week, 5 days ago.
April 10, 2026 at 1:21 pm #17962270
mateuszH-2
I am writing to report a critical performance issue that seems to have started after upgrading WPML Multilingual & Multicurrency for WooCommerce to version 5.5.5, which I have traced to a change in how WCML injects multi-currency price cache HTML into price strings.
## The Problem
My wp_woocommerce_sessions database table grew from ~1-2GB to over 4GB within a short period, with ~65,000 entries. Each session entry is approximately 115KB in size, whereas previously sessions were a few KB each.
## Root Cause Identified
After analyzing the raw session data in the database, I found that each session contains a key called fs_free_shipping_notice (written by the Flexible Shipping plugin). Inside this key, WCML is injecting a wmc-price-cache-list HTML blob containing pre-rendered price strings for every single supported currency (~100 currencies), for every price threshold value.
For a single $100.00 free shipping threshold, WCML is generating and storing a full HTML price string for all ~100 currencies (USD, EUR, CHF, GBP, PLN, AED, KRW, JPY, CNY, AUD, CAD, NOK, SEK, DKK, CZK, AFN, ALL, AMD... and so on). This alone accounts for ~115KB per session entry.
## This Is a Recent Regression
This behavior started approximately after upgrading WPML Multilingual & Multicurrency for WooCommerce - it was NOT happening before. Session sizes were normal prior to this.
## Environment
- WordPress: 6.9.4
- WooCommerce: 10.6.2 (HPOS enabled)
- WPML Multilingual & Multicurrency for WooCommerce: 5.5.5
- Flexible Shipping: 6.5.7
- PHP: 8.1.34
## Evidence
Here is a sample of the bloated data structure stored in each session. The wmc_price_cache attribute inside the price HTML contains pre-rendered strings for every currency:
<span data-wmc_price_cache="{"USD":...,"EUR":...,"CHF":...[~100 more currencies]}">
I have also contacted Flexible Shipping support, but since the oversized data originates from WCML's currency cache injection, I believe the fix needs to come from the WCML side.
Thank you,
April 13, 2026 at 11:06 am #17965585
Juan de Paco
Hello.
Thanks for reaching out.
While a supporter gets assigned to your request, I would like to pass some information to our development team to do some initial checks. To do so, I would need you to share some more information about your setup:
- Some description on your WCML configuration (like your currencies setup).
- A confirmation of the Flexible Shipping plugin being used (Is it https://wordpress.org/plugins/flexible-shipping/? Are you using other related plugin, like https://wordpress.org/plugins/octolize-shipping-notices/?).
Thanks in advance.
April 21, 2026 at 8:55 am #17983311
mateuszH-2
we are using Flexible Shipping plugin.
We have 3 active currencies and the rest is disabled. The list of currencies is the standard list created when the plugin is installed.
April 22, 2026 at 4:25 am #17985781
Shekhar Bhandari
WPML Supporter since 03/2015
Hello there,
I'd be helping you forward here.
To debug this issue further, I would need to check your site settings once, for this I would need temporary access (wp-admin and ftp) to your site.
Note:
Look forward to your reply.
