Last updated by Waqas Bin Hasan 1 year, 10 months ago.
April 16, 2024 at 12:24 pm #15525230
donatasS
On product category are missing translations... But only on header. Content, footer all ok. Wonder why ?
WPML version updates. Cache is turned of
config.php
define('WP_MEMORY_LIMIT', '296M');
define( 'WP_MAX_MEMORY_LIMIT', '296M' );
define('WP_CACHE',false);
using tags
<?php esc_attr_e('Call to us', 'pandastore') ?>
April 16, 2024 at 1:02 pm #15525526
Waqas Bin Hasan
WPML Supporter since 05/2014
Meanwhile this ticket is attended by one of my colleagues, may I ask you to fix and try the following?
IMPORTANT: Take full backup of your website and database beforehand. It is highly advised to try the following on a staging/dev site first, so your live website isn't compromised.
- Update WPML plugins to the latest versions.
Then:
- Deactivate all plugins except WPML and WooCommerce and check for the issue.
- If the problem persists, repeat the above steps with a default theme of WordPress (i.e. 2021 or 2024).
Please let us know your findings and we'll try our best to help you further on the matter.
Regards.
April 17, 2024 at 9:26 am #15530513
donatasS
After update the problem is solved thanks
