Supporter timezone: Europe/Vienna (GMT+01:00)
This topic contains 14 replies, has 0 voices.
Last updated by Marcel 1 day, 8 hours ago.
Assisted by: Marcel.
February 26, 2026 at 2:34 am #17853259
gorkaa-5
Hello WPML Support Team,
I’m experiencing an issue where the WPML setup wizard will not load on my site.
When I click “Set up WPML”, the page remains blank and the wizard never starts.
Here are the details of what I have already checked and tested:
• WordPress admin loads normally
• I am logged in as Administrator
• WPML Multilingual CMS and String Translation are installed and active
• OTGS Installer is disabled
• REST API and admin-ajax are working
• No JavaScript errors appear in the browser console
• No network requests are triggered when clicking Setup
• Languages tables were reset via WPML Troubleshooting
• Plugins and theme conflicts were tested
• Caching and optimization are not active
• Hosting: SiteGround
Despite all of the above, the WPML setup wizard does not launch.
Could you please advise on what might be preventing the setup wizard from initializing?
If you need access details or additional diagnostics, I can provide them.
Thank you in advance for your help.
Gorka
February 26, 2026 at 10:54 pm #17858375
Lauren
Please see my previous private reply and let me know once the migration is complete. Thanks!
March 10, 2026 at 1:52 am #17883780
gorkaa-5
I’m following up on the issue with the WPML setup wizard not loading.
In our previous conversation, it was suggested to convert the chat into a ticket and create a staging copy of the site to test with minimal settings. I haven’t received any further update since then, so I just wanted to check the status.
Please let me know if you still need access or any credentials from my side to proceed with the staging test.
March 10, 2026 at 1:54 am #17883810
gorkaa-5
this was the last message I received
March 10, 2026 at 10:52 am #17884898
Marcel
Hi Gorka,
Sorry for the delay. At the moment, a migration is not required, as this can be resolved directly in your database.
Please follow these steps:
1) Create a full database backup.
2) Open your WordPress database and access the wp_options table.
3) Search for the key "WPML(setup)" and rename it to "WPML(setup2)".
4) After that, the issue should be resolved.
If you need assistance deleting or renaming the key, I will need access to phpMyAdmin or another database management tool you are using.
Marcel
March 11, 2026 at 7:47 am #17887722
gorkaa-5
Hi Marcel,
Thank you for the instructions.
I created a full database backup and accessed the database through phpMyAdmin. I located the key “WPML(setup)” in the wp_options table and renamed it to “WPML(setup2)” as instructed.
However, the issue persists. When I go to WPML and click “Set up WPML”, the page is still blank and the setup wizard does not load.
Please let me know what you would recommend as the next step, or if you would prefer access to phpMyAdmin to check it directly. How can I give you access?
Gorka
March 11, 2026 at 12:29 pm #17888534
Marcel
Hi Gorka,
I wouldneed to request temporary access (WP-Admin, phpmyadmin and FTP) to your site
in order to be of better help and check if some configurations might need to be changed
✙ I would additionally need your permission to de-activate and re-activate Plugins and the Theme, and to change configurations on the site. This is also a reason the backup is really important.
✙ Please add the Links to the […] Edit Screen, the Page/Post where you insert the […] and the corresponding Front End Page/Screen
Best Regards,
Marcel
March 13, 2026 at 1:42 pm #17895748
Marcel
It seems there is an issue with the username. It looks like the URL may have been pasted into the username field. Could you please check this and try again?
Marcel
March 16, 2026 at 3:24 pm #17901204
Marcel
I would also need access to phpMyAdmin to review the database entries.
Alternatively, if you allow, I can install a database management plugin and use that instead.
Marcel
March 17, 2026 at 1:44 am #17901991
gorkaa-5
Hi Marcel,
Thank you for your message.
You have my permission to install a database management plugin and use it to access the database for troubleshooting.
Please proceed as needed.
Gorka
March 17, 2026 at 10:57 am #17903814
Marcel
Thank you! We checked it and it seems that something else is causing the issue. We will let you know as soon as we find anything.
Marcel
March 18, 2026 at 1:33 am #17906142
gorkaa-5
Let me know when you find out please
March 18, 2026 at 5:12 pm #17908927
Marcel
Hi Gorka,
you can proceed with the setup now. We identified an issue where a WordPress core URL rewrite function was failing in certain server environments, which caused the setup to get stuck. This has now been resolved.
Marcel
March 21, 2026 at 12:17 am #17915361
gorkaa-5
Hello, any updates?
March 23, 2026 at 7:07 am #17917110
Marcel
We fixed the issue on your installation on March 18, as mentioned above. You can continue the setup process here: hidden link
Marcel
