We utilised moving the translations to the EFS which wasn't a satisfactory resolve as it caused the site to overload when trying to request the translations.
Since, we moved this as per dev recommendation: "WPML_ST_SYNC_TRANSLATION_FILES I would say is the right solution - it makes WPML keep the generated files in sync with the DB entries. Adds an additional query on requests for translated strings, and causes regenerations where necessary, but should be much faster than touching hundreds of files on a network drive."
An attempt to sort out this situation using the suggestion above has been made but we're not getting any translations to appear now. The constant is defined on UAT as true but yet, translating strings doesn’t reflect the translated strings for the translated language.
The Troubleshoot page has been accessed, WPML caches have been cleared. To no avail. I wonder if there are any technical limitations at "our" end with the fact that the website is setup on an Elastic Beanstalk environment and there’s a WAF region block, etc.
The topic ‘[Closed] WPML String Translations not appearing’ is closed to new replies.
