Supporter timezone: Africa/Cairo (GMT+02:00)
This topic contains 38 replies, has 0 voices.
Last updated by Osama Mersal 4 days, 17 hours ago.
Assisted by: Osama Mersal.
January 8, 2026 at 10:33 am #17712365
Osama Mersal
WPML Supporter since 02/2020
Hi Erik,
Our 2nd-tier support team has identified a quick workaround: clone the page using the Yoast Duplicate Post plugin; the cloned page doesn't have the issue.
This may be a good workaround for now.
Our 2nd-tier team is still working on another fix for the issue, and I'll update you as soon as I receive their response.
Osama
January 8, 2026 at 11:11 am #17712589
erikD-5
Hi Osama,
Ok thank you, I'll ask Hetsher to try this.
Erik
January 11, 2026 at 9:40 am #17718857
Osama Mersal
Hi Erik,
Thanks for your update.
Osama
January 16, 2026 at 2:21 pm #17737357
erikD-5
Hi Osama,
Did you here anything back from the 2e tier support about this issue?
Erik
January 18, 2026 at 9:51 am #17739885
Osama Mersal
Hi Erik,
Our 2nd-tier support team has found that it's a database issue. The workaround is to use the Yoast Duplicate Post plugin, as the duplicated posts won't have the same issue.
Please let me know if Hetsher has tried the workaround.
Osama
January 19, 2026 at 9:51 am #17741610
erikD-5
Hi Osama,
Thank you for the update.
I understand the suggested workaround using Yoast Duplicate Post, and I appreciate the confirmation that this is indeed a database-level issue.
Before applying this workaround, I want to be careful, as this site has:
existing indexed URLs,
multiple languages,
and SEO-sensitive content.
Cloning pages would create new post IDs and URLs, which is not ideal as a structural solution and may introduce additional SEO side effects.
Given that 2nd-tier support has identified this as a database issue, I would prefer to address it at the source if possible - for example by:
cleaning or rebuilding the affected WPML translation records,
resetting locked translation jobs,
or repairing inconsistent entries in the WPML tables.
Could you please confirm whether a database-level fix or cleanup is possible on your side, now that the root cause has been identified?
If needed, I can of course test the workaround on a single non-critical page, but I’d prefer to avoid duplicating live content unless there is no alternative.
Thanks again for your help.
Hesther
January 19, 2026 at 10:01 am #17741669
Osama Mersal
Hi Hesther,
1) Please try the following on a non-critical page:
1- Edit the page in all languages and change the slug to slug-old
2- Duplicate the page in the default language
3- Change the slug from slug-old-copy to slug
4- Check the issue
2) Our 2nd-tier support was not able to find an alternative workaround, but I'll share your concerns with them.
Osama
January 19, 2026 at 3:26 pm #17743162
erikD-5
Hi Osama,
I’ve completed the test you requested on a non-critical page. Below is a clear and final summary of the results.
Result of the test
After duplicating the page and assigning the original slug to the duplicate (test performed on the Privacy Statement page, Dutch → English):
The WPML translation editor opens normally
The translation can be saved / closed without redirects or warnings
The editor no longer falls back to the WordPress/Elementor editor
This confirms that the original blocking issue was caused by legacy database relations tied to the original post ID, not by the page content itself.
Remaining issue (important clarification)
Before these problems started, my site worked for years in local translator mode:
I only saw pencil icons
I edited translations directly myself
After saving, the icon returned to a normal pencil
Translations were never treated as “jobs” or reassigned
After the workaround:
The editor is functional again (good)
However, WPML now treats the translation as a translation job:
gear icon instead of pencil
messages such as “waiting for available translator”
in WPML → Translations, the same page appears with conflicting statuses (e.g. “needs translation” and “completed but needs update”)
This workflow behavior did not exist on my site before the issue and indicates remaining inconsistencies in WPML’s translation records.
Conclusion
The workaround successfully restores the editor and proves this is a database-level issue.
However, duplicating pages one by one is not a sustainable solution for a multilingual, SEO-sensitive site, and the original local-translator workflow has not been fully restored.
Question
Now that the root cause is confirmed, is it possible for 2nd-tier support to perform a database-level cleanup/reset of WPML translation data so the site can fully return to the original local-translator workflow (pencil icons, no translation jobs), without duplicating pages individually?
Thanks again for your help and for escalating this to 2nd-tier support.
Hesther
January 20, 2026 at 8:58 am #17745021
Osama Mersal
Hi Hesther,
Thanks for your update and cooperation. I'll check with our 2nd tier support team and get back to you.
Osama
