Last updated by Mateus Getulio 1 year, 1 month ago.
Assisted by: Mateus Getulio.
July 18, 2024 at 12:02 pm | |
dmytroT-5 |
July 18, 2024 at 12:33 pm | |
July 18, 2024 at 5:46 pm #15973981 | |
Mateus Getulio Supporter
Languages: English (English ) Portuguese (Brazil) (Português ) Timezone: America/Sao_Paulo (GMT-03:00) |
Hello, I suspect the issue could be related to compatibility. To pinpoint the exact cause, we need to isolate variables by replicating the issue in a sandbox environment. Sandbox login link Here's what is needed to be done: 1- Install Essential Components Only: In the sandbox provided above, please install your theme and only the plugins necessary to replicate the issue. Avoid importing the entire site. 2- Set Up the Page and Configurations: Mirror your current setup that's causing the issue, focusing on the filter part, we only need the site to be partially replicated up to a point where we can debug this issue. 3- Notify Us Once Done: After replicating the issue in the sandbox, inform us through this ticket so we can proceed with further analysis. The goal here is to identify if the problem is indeed a compatibility issue, reproducing it in a controlled environment. We appreciate your cooperation in this matter. Let us know once you've set up the sandbox. Best, Mateus |
July 19, 2024 at 12:34 pm #15978307 | |
dmytroT-5 |
Hello, Mateus. |
July 19, 2024 at 7:28 pm #15979746 | |
Hello there, Thank you for trying to replicate the issue to the sandbox. In the sandbox the original issue is not observed, the categories are listed but not filterable. Since the issue is not the same in the sandbox, it means that it is not a compatibility issue replicable from scratch and that we need to debug this directly in the site. I'd like to ask permission to make a copy/staging version of your site where I can debug this closely without affecting the live site. I'll make sure to delete this copy as soon as we get this issue fixed. I'm afraid of debugging directly on the live site and cause issues to your visitors. Also, it is important to test a different setup as part of the troubleshooting. Thank you, please let us know. |
July 22, 2024 at 7:09 am #15985137 | |
dmytroT-5 |
You can make a copy, I don't mind |
July 22, 2024 at 5:12 pm #15988182 | |
Hey there, I checked this out but so far I couldn't find a fix for it. I asked my colleagues to have a look at this issue in order to see if there's anything I'm missing. I'll come back here as soon as one of my colleagues reply back to me (which it shouldn't take long). Thanks, |
July 23, 2024 at 12:39 pm #15992423 | |
Hello there, In our staging site, as part of the debugging process, we updated all plugin, including WooCommerce. However, WOOF - WooCommerce Products Filter remains outdated. We checked it and while you're running WOOF - WooCommerce Products Filter version 2.2.5.6, there's an update to version 3.3.6.1 hidden link">available at the plugin's site. Given that this is a licensed plugin, we're unable to download the latest version. Are you able to login to your products-filter.com account and download the latest version of the plugin? You can upload it to the server and let us know the location. Or you can update it hidden link">directly in the sandbox and we'll retrieve it from there. Thank you, please let us know. |
July 24, 2024 at 2:00 pm #15998860 | |
dmytroT-5 |
OK, I'll try to figure it out |
July 26, 2024 at 3:01 pm #16009137 | |
dmytroT-5 |
Hey Mateus. I couldn't find creds to the WOOF plugin site and decided to install BeRocket's Ajax Filter. It works perfectly, and I don't have to worry about the WOOF filter problem anymore. Thank you and your team for your help. |
July 26, 2024 at 7:30 pm #16009659 | |
Hello there, I'm glad to know that you were able to find an alternative around the issue. Thanks a lot for sharing it with us. Kind regards, |
