Supporter timezone: Europe/Zagreb (GMT+01:00)
This topic contains 12 replies, has 0 voices.
Last updated by Bruno Kos 2 months ago.
Assisted by: Bruno Kos.
September 5, 2025 at 1:11 pm #17379478
wilcoA
I am experiencing an issue with WooCommerce and WPML on my site hidden link staging site: hidden link . I am trying to ensure that products are visible on translated category pages when 'Hide out of stock' is enabled. The issue is occurring on the Portuguese category page hidden link, while the Dutch category page hidden link is working fine. I have verified stock status on all translations, checked WPML settings for product fields (`_stock_status`, `_stock`, `_manage_stock`), used WooCommerce Multilingual troubleshooting options, and cleared WooCommerce transients and regenerated product lookup tables.
Products are missing from the Portuguese category pages when 'Hide out of stock items' is enabled, despite being set to 'In stock' and accessible via direct URL.
Could you please check why the stock status is not syncing correctly between translations?
September 5, 2025 at 1:59 pm #17379756
Bruno Kos
I’ve set up a clean sandbox that mirrors your configuration:
Could you try to reproduce the problem there? If you can reproduce it there (with one simple product), I’ll escalate to our developers for further checks.
Let me know if you have any questions!
September 8, 2025 at 5:28 am #17382314
wilcoA
Can you please check this issue on my staging site? Earlier, the support team asked me to create a staging site, so I’ve created one. Please log in and check the site.
URL: hidden link
September 8, 2025 at 7:13 am #17382480
wilcoA
Hey Bruno Kos,
I have checked the website link shared by you, and I'm facing a load issue on the website as it takes so much time to load a single page.
And you mentioned creating a product on the provided website, which is not feasible because I have to set all the properties again on this website, and it will consume a lot of time.
As requested from your side, I created a staging website for you, which took 2-3 days to transfer the data, and I also have to ask for extra database space from SiteGround support team
I have already spent so much time on this, and I would request you to use the staging website provided below to fix the issue
Hope you understand it and we are on the same page ASAP
Thanks, and let me know if you need anything.
URL: hidden link
Martijn
September 8, 2025 at 10:29 am #17383140
Bruno Kos
No problem.
However, I’m unable to log in using the one-click link. Could you please share credentials for a regular admin user instead and temporarily disable two-factor authentication on the staging site? You can create a custom admin account using the email: admin@example.com
Also, would it be possible for me to test the site under the following conditions?
* Only WPML plugins (and WooCommerce) are activated — this will help us determine if the issue is caused by a conflict with another plugin.
* The theme is switched to a default WordPress theme like Twenty Twenty — this will help us check for any theme-related conflicts.
Let me know once this is ready or if you have any questions!
September 9, 2025 at 4:48 am #17385465
Bruno Kos
I tried various thing but none of them worked.
To troubleshoot this problem, I'll install the Duplicator plugin and generate packages for further debugging purposes. I'll ensure to exclude all media files to maintain a minimal package size.
You can find more information about the process here:
https://wpml.org/faq/checklist-before-opening-a-ticket-in-wpml-support/#get-help-from-support
Please confirm if this approach is acceptable to you!
September 9, 2025 at 5:06 am #17385484
wilcoA
Thank you for your efforts in troubleshooting this issue. Yes, your suggested approach sounds good. Please proceed with installing the Duplicator plugin and generating the package while excluding media files to keep the size minimal.
Once the package is ready, kindly share the details so we can move forward with debugging.
September 9, 2025 at 1:14 pm #17387261
wilcoA
Just following up to check if you were able to proceed with installing the Duplicator plugin and generating the package.
Please let me know once it’s ready so we can continue with the other process.
September 9, 2025 at 1:17 pm #17387265
Bruno Kos
I was able to create duplicator packages. I am checking this with our 2nd tier and will keep you posted!
September 9, 2025 at 3:03 pm #17387735
Bruno Kos
Can you check it now?
If it’s working properly now, please let me know. I’ve tried several things, but I’m not entirely sure which one fixed it—or if it was a combination.
If it does work, I can either apply the same changes on your live site or let you know what to try, to see if it helps there as well.
September 10, 2025 at 12:40 pm #17390758
wilcoA
Thanks for checking and fixing it on the staging site. Yes, it seems to be working fine now. Please go ahead and apply the same changes on the live site as well.
September 11, 2025 at 5:22 am #17392571
Bruno Kos
Can you send me logins for this site as well?
I marked your next reply as private so that you can safely add credentials.
September 11, 2025 at 9:44 am #17393502
Bruno Kos
Can you check now?
The topic ‘[Closed] WPML/WooCommerce – Products not visible on translated category pages when “Hide out of stock” …’ is closed to new replies.
