Last updated by Bobby 1 year, 11 months ago.
Assisted by: Bobby.
February 5, 2024 at 11:18 am #15265578
vasileiosT-3
I am trying to: Show the translation of this ACF fields here hidden link in Greek. as you can see all custom fields except the section "Στοιχεία ακινήτου" (Property Details) is translated. only in this section is not translated.
I expected to see: the translation in Greek
Instead, I got: the english text
February 5, 2024 at 3:28 pm #15266998
Lauren
WPML Supporter since 10/2015
Please go to WPML -> Settings -> Post Types and check to make sure Field Groups are set as Not Translatable.
Then, go to your ACF field group for this content and expand the fields. What are your settings for translation for these fields? Are they set as Translate, Copy, Copy Once, or don't translate? In order to translate them, they should be set to Copy Once or Translate. If not, you will not see them available for translation in the translation editor.
Please take a moment to reivew translation options when using ACF with WPML: https://wpml.org/documentation/related-projects/translate-sites-built-with-acf/
February 6, 2024 at 12:07 pm #15271372
vasileiosT-3
Hello i did what you said and the problem still exists. I need more assistance on this
February 6, 2024 at 10:19 pm #15274022
Bobby
WPML Supporter since 04/2015
Thank you,
Bobby
The topic ‘[Closed] Problem with ACF and Jet Engine’ is closed to new replies.
