The client is experiencing incorrect product quantities displayed next to the WooCommerce product filter in languages other than the default language on their website.
To address this issue, follow these steps:
- Navigate to Products -> Attributes.
- Click "Configure terms" to access the "Kompatybilność" attribute terms.
- Click on the number of products next to the problematic term to view all products in this term.
- Select all products.
- From the "Bulk Actions" dropdown menu, choose edit.
- Change the status to "Publish" and update them.
If these steps do not resolve the issue or if the solution seems outdated or irrelevant to your specific case, we recommend opening a new support ticket. We also highly recommend checking related known issues at WPML Known Issues, verifying the version of the permanent fix, and confirming that you have installed the latest versions of themes and plugins. For further assistance, please visit our support forum at WPML Support Forum.
This topic contains 20 replies, has 2 voices.
Last updated by przemyslawD-3 1 year ago.
Assisted by: Osama Mersal.
August 29, 2024 at 11:50 am #16119743
przemyslawD-3
I have a problem with the WooCommerce product filter in each language (apart from the basic language) on my site hidden link. The product quantities next to the filter are incorrect. For example, it shows two products when the correct value is four. An example can be seen here: hidden link. I am following the documentation at https://wpml.org/forums/topic/woocommerce-color-filter-not-working-correctly-2/.
The product quantities next to the WooCommerce product filter are incorrect in each language except the basic language.
Why are the product quantities next to the WooCommerce product filter incorrect in each language except the basic language?
How can I fix the incorrect product quantities displayed by the WooCommerce product filter?
August 29, 2024 at 2:40 pm #16120662
przemyslawD-3
I did all the steps step by step, unfortunately it did not solve the problem 🙁
September 1, 2024 at 9:25 am #16128611
Osama Mersal
WPML Supporter since 02/2020
First of all, sorry for the late reply; it was due to a higher workload.
I would need to look closely at your site, so I would need to request temporary access (WP-Admin and FTP)
Osama
September 2, 2024 at 11:20 am #16131196
Osama Mersal
Thanks for the access details. I Synchronized the attribute from the WooCommerce Multilingual-> Attributes tab.
This fixed the issue for the English language. Kindly check this hidden link">page.
Osama
September 2, 2024 at 12:19 pm #16131541
przemyslawD-3
Ok, I don't know why, but I tried this before and it didn't work. I don't know what exactly you did, but etraz one of the translations is missing (Switzerland) and I see a critical error when editing the translation 🙁
September 2, 2024 at 12:29 pm #16131584
Osama Mersal
I checked the site and re-added the Switzerland language. Please check if it works correctly.
Osama
September 2, 2024 at 12:34 pm #16131600
przemyslawD-3
Not really. I see the language, but the translation on the page is wrong (part is Polish, part is English). Everything should be in German (except the currency).
September 2, 2024 at 12:43 pm #16131665
Osama Mersal
Please check this hidden link">product and let me know which strings have not been translated.
Osama
September 2, 2024 at 12:51 pm #16131691
przemyslawD-3
On the yellow on screen & cookie banner.
September 2, 2024 at 1:04 pm #16131804
Osama Mersal
I translated some of these strings via WPML-> String Translation. Please let me know how the "The product has no reviews" string and the cookie banner are added to the default language to check how they can translated.
Osama
September 2, 2024 at 1:17 pm #16131851
przemyslawD-3
Cookie banner: CookieYes | GDPR Cookie Consent plugin
Trust mate: TrustMate.io integration for WooCommerce
But there is more thing withaut translation (checkout form, etc.). Maybe it will be easier to restore database and start once again?
September 2, 2024 at 1:22 pm #16131884
Osama Mersal
If you have a recent backup, you can do so.
Please take a backup of the current database first.
Osama
September 2, 2024 at 1:31 pm #16131971
przemyslawD-3
Ok, I suggested restoring the database too soon. In the meantime, orders came to the store, and a colleague changed some things, and restoring the database from 6 a.m. is not the best idea if it is not necessary.
It will be easier to translate the forms. I will take care of it myself. However, the original problem is still not solved - on versions other than Polish and English it still shows incorrect quantities of products.
September 2, 2024 at 1:54 pm #16132122
Osama Mersal
I updated the translations, and the filter appeared to be correct. Please check the hidden link">German page.
Osama
September 3, 2024 at 10:46 am #16135040
przemyslawD-3
Two things:
1) Can you write exactly what (or how) you refreshed the attributes? It's strange that I've done this many times and it doesn't work.
2) I still have a problem with the translation to Switzerland. And even with another translation - I just can't find the basic strings. For example this one below - it's translated to every language (except Swiss version), but I can't find it in the string translation. I tried to scan plugins, theme, find it in the admin translation panel and there's nothing.
This string shows up after adding a product to the cart.
Edit: if I tried to scan woocommerce .mo it's stopoing at keep bufforing at -134.
