Last updated by Otto 7 months, 2 weeks ago.
Assisted by: Otto.
March 17, 2025 at 1:15 pm #16825029
maciejK-33
I use PPOM fields in my products on hidden link. After translating them and setting up multicurrency, I have different primary prices. If some fields change the price, it's incorrectly calculated, like -200 euro translated into -200 PLN. I also want to change the price of tours in Traveliscious according to the language of translation.
Price changes in PPOM fields are not correctly calculated when translated, resulting in incorrect currency conversion.
Is it possible to set up PPOM fields to correctly calculate prices with currency conversion?
Can the price of tours in Traveliscious be changed according to the language of translation?
March 18, 2025 at 8:14 pm #16832373
Otto
WPML Supporter since 09/2015
I apologize for the delay in answering. I will take care of this ticket and reply time will be shorter now.
To ensure the quickest and most accurate support, please provide your debug information so I can look at some of your configurations. We have an excellent article on how to locate it here: https://wpml.org/faq/provide-debug-information-faster-support/.
Is this the plugin you are having issues with?
https://wordpress.org/plugins/woocommerce-product-addon/
Is it the free or PRO version?
This plugin is not in our compatibility list, however, it doesn't necessarily imply that it is not compatible, just that our team has not tested it yet.
To isolate the problem, I suggest you try this to help us identify if it might be a conflict with another plugin or theme that is causing the problem.
**IMPORTANT:** Please try this in a staging environment or at least with a backup of your site files and database before continuing.
Disable all plugins except WPML-related and temporarily change the theme to a default WordPress such as Twenty Twenty-five.
With these settings, is the issue resolved? If so, re-activate one by one to discover which one is the conflict.
Best Regards,
Otto
The topic ‘[Closed] I need to find solution for changing currency and calculations in PPOM fields.’ is closed to new replies.
