9:00 – 13:00 9:00 – 13:00 9:00 – 13:00 9:00 – 13:00 9:00 – 13:00 - -
14:00 – 18:00 14:00 – 18:00 14:00 – 18:00 14:00 – 18:00 14:00 – 18:00 - -
Last updated by Christopher Amirian 4 days, 12 hours ago.
May 11, 2026 at 12:49 pm #18027547
Arto Hautanen
I’m having an issue with the WPML plugin together with WooCommerce.
The website is partially translated into multiple languages, but the WooCommerce shop is only available in the original/default language.
For example, the shop front page is:
This shop page has not been translated. However, I am still able to access:
and the page loads successfully.
The same issue exists with products. Products have not been translated, but I can still access URLs such as:
Shouldn’t WPML redirect users to the default language version or homepage with a 301 redirect when a translation does not exist?
My current settings are:
Products post type:
Products (product) → Not translatable
Best regards, Tuomo
May 11, 2026 at 2:24 pm #18027958
Christopher Amirian
WPML Supporter since 07/2020
Hi Tuomo,
The behaviour you're seeing is actually working as expected for the setting you currently have, but I think there's a useful clarification about how WPML's three Post Type translation modes differ — and which one matches what you want.
Why /en/kirjakauppa/ and /en/tuote/... currently load
When the Products post type is set to "Not translatable," WPML treats every product as not having a language at all. There is exactly one product in the database, and WordPress's permalink rewriter happily resolves both /kirjakauppa/... and /en/kirjakauppa/... to the same Finnish content. WPML doesn't interfere because, from its perspective, "not translatable" means "this content is language-neutral, don't apply any language logic to it." So it doesn't 404 the URL and it doesn't redirect — both behaviours would be incorrect for genuinely language-neutral content.
WPML does not natively 301-redirect untranslated URLs to the default language.
Since your shop and products aren't translated and you don't want them indexable under /en/, I'd recommend:
If you specifically need 301 redirects you'll need to implement those redirects outside WPML — either with a redirect plugin (e.g. the "Redirection" plugin from wordpress.org) or in your server config. WPML doesn't generate these redirects natively.
For more information:
https://wpml.org/forums/topic/avoid-wpml-to-hijack-redirect-to-another-language-domain/
