Last updated by Shekhar Bhandari 8 months, 2 weeks ago.
December 14, 2024 at 11:08 am #16513346
fadiS-3
I am trying to bulk upload products in both English and Arabic on my site hidden link. I have exported the products from another WordPress website using WPML and am following the documentation at https://wpml.org/documentation/related-projects/wpml-export-and-import/preparing-import-files-for-wpml-export-and-import/ to upload them.
this is a screencast of the issue: hidden link
When I try to import the products, the English versions work correctly, but the Arabic ones do not translate.
Why are the Arabic products not translating during the import process?
December 17, 2024 at 5:16 am #16519715
Shekhar Bhandari
WPML Supporter since 03/2015
Hello there,
Thank you for contacting WPML support. I'd be happy to assist you on this issue.
Can you send me the product csv file in the next private reply so I can test it on my local setup first and see if it works.
I have enabled the private reply for you.
Look forward to your reply.
December 17, 2024 at 7:22 am #16519881
Shekhar Bhandari
Hello there,
For me it works without any issue, can you please do the following and see if it helps:
- While Importing the CSV set the ID and SKU to "DO NOT EXPORT".
December 17, 2024 at 11:09 am #16521207
fadiS-3
ok let me check it out now. But quick question, if i dont import the id and sku, how would i sync the english and arabic products toghether. There are almost 600 products tha i would need to import as a final file
December 17, 2024 at 11:12 am #16521216
Shekhar Bhandari
**Hello,**
The synchronization will be based on the `_wpml_` fields in the CSV. If you need to use specific SKUs, I recommend using unique SKUs for each field. When WPML imports the data, it will adjust the SKUs accordingly so they remain consistent across all languages.
Thank you!
December 17, 2024 at 11:55 am #16521487
fadiS-3
Thanks for this, and sorry im a bit lost here. would you pls be able to create a quick loom video explaining how this would be done, because in the documentation, i learned that the sku's need to be the same for english and arabic which we will then use for _wpml_ translation group field.
December 18, 2024 at 4:32 am #16524038
Shekhar Bhandari
Were you able to import it using the settings I mentioned? Essentially, the SKU needs to be the same for both languages when using WPML. However, with the importer, products with the same SKU aren’t imported. To resolve this, we can either assign different SKUs or upload the products without a SKU, allowing the system to generate one automatically.
Once the products are imported and the WPML settings are applied, WPML will automatically adjust the SKUs to match across languages.
Let me know if this makes sense.
December 18, 2024 at 5:37 am #16524100
fadiS-3
Hello, yes i imported using the setting you suggested. I see that the arabic products also uploaded but they were not synced and they were assigned english. I made sure that the sku and ID is not imported
December 18, 2024 at 5:44 am #16524176
Shekhar Bhandari
Hello there,
I ran the import on your site and it works for me, please check this video: hidden link
Let me know if this helps.
December 18, 2024 at 7:05 am #16524291
fadiS-3
wow that works, i did exactly the same. Let me try it out again on my end and get back pls
December 19, 2024 at 2:07 am #16528250
fadiS-3
Hi there, thanks for the hold. I was able to upload all the products onto the website, but i have another issue with the categories not added correctly. Here is the screencast of the issue that im facing:
Here is the product list that i used to upload the products: hidden link
December 19, 2024 at 2:40 am #16528303
fadiS-3
This is a further analysis of the issue: hidden link
December 19, 2024 at 5:02 am #16528409
Shekhar Bhandari
Hello there,
I just reimported the product with the link you provided and it didn't even complete, but I can see around 70+ categories in English whereas in your site, it's not that much, so I would suggest you to delete all product and categories from the site, then try to import it in short bulk, lets say 50 first and see if the problem exists.
If the error doesn't exists there, try with next 100 and so-on.
December 20, 2024 at 2:31 am #16532011
fadiS-3
ok im checking this out, let me get back to you shortly
December 20, 2024 at 4:12 am #16532060
fadiS-3
Hi so im tried the way you had instructed. In the first set of the products, i imported from row 2 to 99 and theyimported correctly. I then tried importing row 100 to row 200, and in this set the same issue happened where all the products had one cateogry in english. I also double checked that the arabic products in the sheet do not have the english categories. Can you please advise. Is there a way we can connect and figure this out to expedite this?
The topic ‘[Closed] Need help with uploading products in both english and araboc’ is closed to new replies.
