10:00 – 14:00 | 10:00 – 14:00 | 10:00 – 14:00 | 10:00 – 14:00 | 10:00 – 14:00 | - | - |
16:00 – 20:00 | 16:00 – 20:00 | 16:00 – 20:00 | 16:00 – 20:00 | 16:00 – 20:00 | - | - |
July 22, 2025 at 2:54 pm #17259918 | |
dimitriosV-4 |
July 23, 2025 at 2:05 pm #17264366 | |
Nigel WPML Supporter since 02/2016 Timezone: Europe/Madrid (GMT+02:00) |
Hi there Sorry for the delay in receiving a response, we are working through tickets as quickly as possible. While waiting for a colleague to take this ticket, can I ask you a few questions so that we are clear exactly the issue you are reporting? If I understand you correctly, you have used JetEngine to register a custom post type. You have created a template to display those posts with a theme Layout. I assume you have made the post type translatable and have translated posts. And you have sent the Layout for translation (from WPML > Translation Management), and translated it. (Again, I assume it contains some texts in the original language that should be translated to the second language.) And the problem is that when you view one of the translations of the posts on the front end the texts from the Layout are showing the original language, not the translations. (All texts or just some texts?) Can you please confirm if that is correct? It would probably help if we have access to your site to check the configuration, if you are agreeable. Let me set a private reply to get credentials from you. |
July 24, 2025 at 8:52 am #17266566 | |
dimitriosV-4 |
I am still waiting for your feedback. Please reply to me the soonest possible. Thank you. |
July 25, 2025 at 5:33 am #17269901 | |
dimitriosV-4 |
Dear sirs, Info: Please reply today! |
July 27, 2025 at 11:38 am #17273020 | |
dimitriosV-4 |
Hi again. Please look into my ticket and provide me with a solution. |
July 28, 2025 at 11:52 am #17274743 | |
Hi, I'll continue to help you with this issue. Can you please confirm that the 'House Single' template is located in JetEngin -> Listing Items/Components? If so, then you need to set it to be translated in WPML -> Settings Post Types Translation. Currently, it is set to Not Translatable. You must put it into Translatable and click the Save button. Please see the attached screenshot listing-component.jpg. In addition, if the issue persists, please be aware of the following known issue and apply the suggested workaround: https://wpml.org/errata/jetengine-components-are-not-translated-on-the-frontend/. Please let me know how it goes. If you would like me to apply those changes, please let me know, and I will make the necessary updates on your site. (I'm not allowed to do that without your consent.) |
July 28, 2025 at 12:40 pm #17275027 | |
dimitriosV-4 |
Hi, Please let me know the soonest possible. The delivery deadline is approaching and we need a solution asap! Thank you |
July 29, 2025 at 7:07 pm #17280129 | |
Hi, and thanks for trying my suggestions. I'm sorry if it was not clear enough. Now you must translate the template to display in Russian. I checked JetEngine -> Listings/Components and could see that the 'House Single' template (or any of the two other templates) is not translated. Please see the attached screenshot. Please proceed with translating it and check. If you are using caching on your site, please clear all the caching when checking this. Regards, |
July 30, 2025 at 10:04 am #17281394 | |
dimitriosV-4 |
Hi Itamar, I translated but it keeps showing the english version. I don't know what else to do. Thank you |
July 30, 2025 at 6:23 pm #17283077 | |
Hi, When I check the translation here hidden link, I can see it is translated. Please see the attached screenshot. Can you please tell me where it is not translated? Thanks, |
July 31, 2025 at 2:55 pm #17285624 | |
dimitriosV-4 |
Hi Itamar, Maybe we need to translate the taxonomies to work? Please give us a solution, we are under pressure. |
August 1, 2025 at 9:02 am #17287486 | |
Hi, Thanks. I can see the problem on the translated hidden link">house. Otherwise, we will need to investigate this problem on our server and not on your production site. So please allow me to take a copy of your site. For this, I must install a plugin like Duplicator or All In One Migration. Please let me know if you agree. Regards, |
August 1, 2025 at 10:31 am #17287926 | |
dimitriosV-4 |
Hi Itamar, |
August 4, 2025 at 1:04 pm #17293147 | |
dimitriosV-4 |
Hi Itamar, Thank you |
August 4, 2025 at 3:58 pm #17294108 | |
Hi, I installed the All-in-One WP Migration and Backup on your site and created a copy of your site. I will install it on our servers, investigate the issue, and get back to you. Meanwhile, I want to urge you to update the related plugins like Elementor + Pro, and the JetEngine plugin to their latest versions. And also, I want to encourage you to place the Post Content Widget in your House Single template as I already mentioned in my previous reply. Then check if it helps to solve the issue. If you have caching enabled on your site, please deactivate it while you try this. Regards, |
