The client is trying to translate a page created in Elementor using JetEngine metadata for a Custom Post Type (CPT) called 'Artistes'. The issues faced include:
1. The English version of certain archive pages does not have the same structure as the original French version.
2. Some archive pages do not have an English version, as indicated by the absence of the English option in the language switcher.
3. Inconsistencies in Jet Engine queries within the listing grid across different languages.
We have identified that the issue persists even after isolated testing. It appears that updates to fields such as 'Artist Bio' are not recognized when changes are made. However, changes to the 'name' field seem to be effective. For the first issue, the problem seems to be that the artist's work is not loaded in the default language. Regarding the second issue, the artist has not been translated yet, which is why the language switcher does not show the English option. For the third issue, if it works in the translated version and not in the default language, this indicates an error on our side.
If this solution does not seem relevant to your situation, please open a new support ticket with us.
Last updated by Marcel 1 year, 8 months ago.
Assisted by: Marcel.
October 14, 2023 at 2:39 pm #14577329
mohammad-rezaG
I'm trying to translate a page created in Elementor using JetEngine metadata.
I've created a CPT called Artistes (The primary language is French and the translated language is English). This page is populated by dynamic fields that get data from JetEngine metadata.
I don't know what the correct way of translating such a page is.
I've tried translating strings, creating a new archive and attaching it to the French version, and translating the CPT but none of the methods work.
When I try to translate the CPT, all get in the translation editor is the name of the CPT.
The language switcher doesn't show the English language either. Apparently, it's only activated once the page or CPT has been translated.
I would like to know what the correct flow is for translating Elementor archives or templates created using Jet Engine metadata. I couldn't find a complete answer in the docs and the articles I found were not helpful.
I've gone through all the documentation on WPML and Crocoblock regarding translating archives, CPT, strings, and templates.
This is a page that shows one of our artists. The data is from metadata like a featured image, a French bio, date of birth, ...
October 16, 2023 at 1:31 pm #14585499
Marcel
a regular archive template should work the same way you would translate an Elementor Header or Footer. Please try if point "6. How to Set Up Language-Based Header & Footer for Dynamically Generated Pages" works for you?
Direct Link: hidden link
Best Regards
Marcel
October 20, 2023 at 11:29 am #14622807
mohammad-rezaG
Thank you for the reply.
The link you've provided seems to pertain to older versions of Crocoblock (and probably WPML).
I couldn't find any of the settings the page points to. (see screenshot WPML template parts). I can see Template Parts (wp_template_part) and Templates (wp_template) but both are already set to translatable.
I can't see Jet Plugin settings (Jet Plugin settings.png screenshot) in Crocoblock > JetPlugins Settings tab. I tried disabling all other plugins and wiping out my litespeed plugin and browser cache but it only showed a blank page so I can't know whether it's an issue or whether the settings have changed.
All in all, I'm unable to go through the steps because things seem to have changed in the recent versions.
Thank you for any assistance you can provide on this issue.
October 20, 2023 at 12:15 pm #14623325
Marcel
I would like to request temporary access (wp-admin and FTP) to your site to take a better look at the issue. It would be better to a testing site where the issue is replicated.
IMPORTANT
-Please make a backup of site files and database before providing us access.
Best Regards
Marcel
October 23, 2023 at 6:41 am #14633211
Marcel
please also provide the credentials for the WP Backend, as the input field was empty. Thank You!
Best Regards
Marcel
October 25, 2023 at 4:32 pm #14663365
Marcel
I added a "test" text to the French default language, and it seems it's not pushing any updates to the translated version.
Can you please provide a duplicator copy of your installation for local debugging? There was a translation ongoing, but if no new updates are pushed, it might prevent getting the data into the translation editor.
You can create a site copy as mentioned here: https://wpml.org/faq/provide-supporters-copy-site/.
Thank You!
Best Regards
Marcel
October 26, 2023 at 9:54 am #14668975
mohammad-rezaG
I'm getting server timeout errors on the Duplicator build.
Can you suggest any filters that can bring the sise to under 500 MB? Maybe some file upload directories, etc ..
I've tried several times with different options but the final size is bigger than 3GB and is causing issues.
Thank you
October 26, 2023 at 4:06 pm #14672577
Marcel
yes, you can use the pre-created filters on the right: hidden link. There, you can filter specific folders such as uploads, cache etc.
You can also filter below media files, etc. If it still does not work, you can try using "WP All in One Migration". Even if it's a bigger package, it should not cause any issues.
Best Regards
Marcel
October 27, 2023 at 6:07 pm #14681661
Marcel
thank you! I needed to remove some plugins to get the package runnable, but it seems it worked now I can open the Backend. I'm testing it now and let you know ASAP as I find something.
Best Regards
Marcel
October 28, 2023 at 8:06 am #14682905
mohammad-rezaG
Thank you for the update. I'll eagerly await your findings.
October 31, 2023 at 5:52 pm #14702931
Marcel
short update: I can confirm that making changes to CPT entries in French doesn't push any updates to the translated version. I will try next to isolate this by removing 3rd party plugins.
Best Regards
Marcel
October 31, 2023 at 6:45 pm #14703309
mohammad-rezaG
I'm grateful for this update.
I hope we can solve this issue eventually.
Kind regards,
Reza
November 2, 2023 at 5:19 pm #14719981
Marcel
Hi Reza,
thanks for your patience. I tested it isolated and the issue persisted. It seems the update on fields such are "Artist Bio" is not taken into consideration when making any change. If you push a change on the name field, for example, then it works.
1-The English version of certain archive pages created in Elementor and using dynamic data from Jet Engine, (like hidden link or hidden link) do not have the same structure as the original french version.
The only issue I can see here is that the artist's work is not loaded, but for your default language only: hidden link.
2- Some of the archive pages do not have an English version, (like hidden link) which is apparent since the language switcher doesn't show the option of an English language at all.
Yes, the artist is not translated yet. It shows the "+" icon: hidden link.
3- My Jet Engine queries work in some parts of my listing grid, sometimes in the French version and sometimes in the English version but it isn't consistent. While I'm aware that this may seem to be an issue with Crocoblock, their support tells me that this issue is due to certain custom fields not being translated. I don't believe this is the case because these fields were created in English to begin with and wouldn't need to be translated.
This is identical to 1. If it works on a translated version and not on your default language, I can confirm an error from our side. Your conclusion what you wrote is correct.
Best Regards
Marcel
