Last updated by Osama Mersal 1 year, 4 months ago.
Assisted by: Osama Mersal.
February 9, 2024 at 7:21 pm #15287419
Fred
We are having problems with the translated composite products. Unfortunately these don't work. The composite product works in the original language, but when we translate the products into WPML, the composite products do not work. As you can see you continue to see 'loading'.
We have already contacted Composite Products, but they refer to WPML.
hidden link (this composite product is correct)
hidden link (this is the translated composite product - as you can see this shows 'loading' instead of the choices)
What is the link to your site? hidden link
February 12, 2024 at 9:21 am #15291648
Osama Mersal
WPML Supporter since 02/2020
1) First of all, sorry for the late reply; it was due to a higher workload. Please login to this sandbox site and install the "Woo Product Bundles" plugin. (hidden link)
After that, please create test products and translate them to replicate the issue. If the issue is replicable, please let me know how to reproduce it.
2) It's not related to the issue, but according to your Debug.info, the WP memory limit needs to be increased. PHP memory is fine, but WordPress uses 40Mb as default. The minimum requirements for WPML are 128 MB. (Kindly check this page https://wpml.org/home/minimum-requirements/)
You can increase it by adding the following code in your wp-config.php file right before the /* That's all, stop editing! Happy publishing. */ line:
/* Memory Limit */
define( 'WP_MAX_MEMORY_LIMIT', '256M');
Osama
February 15, 2024 at 9:40 am #15305713
Fred
Hi Osama,
Thanks for your message. I have adjusted the WP memory. This seems to work well.
I have installed the plugins on the test environment, but I find it difficult to create the exact product combination. Is it possible that you investigate this problem in the hidden link environment? This is not yet a live environment, so development can continue as normal.
What do you need from me?
Fred
February 15, 2024 at 10:00 am #15305786
Osama Mersal
Hi Fred,
Sure, I would need to request temporary access (WP-Admin and FTP)
Osama
February 15, 2024 at 12:13 pm #15306805
Osama Mersal
Hi Fred,
Please check the access details. I got the following error. (Invalid login details.)
February 15, 2024 at 3:59 pm #15308548
Osama Mersal
Hi Fred,
I've installed a local copy of your site and found that the issue is fixed when the "WooCommerce Wholesale" plugins are deactivated.
Please deactivate these plugins and check the issue. (hidden link)
Osama
The topic ‘[Closed] We are having problems with the translated composite products.’ is closed to new replies.
