Last updated by Bigul 8 months, 1 week ago.
Assisted by: Bigul.
April 1, 2025 at 12:32 pm #16882851
Frameworks AS
After following the instructions, the page now goes to WPML, but there are no other translations to translate other than the title.
There are 8 blocks on the page, one of which is a Global block/pattern
Removing the blocks one by one didn't change anything with how it passes over to the translation page
All the custom blocks are built with ACF, and we have ACFML installed. This hasn't been a problem before with the same setup, but now it no longer sees the blocks as it passes it over to WPML translate
April 1, 2025 at 12:52 pm #16882947
Bigul
A couple of requests for tracking this.
1) Please share the URL of the page/pages having the problem
2) Please fill the private details fields after a full site backup. I would like to access the admin area of your site for further checking. Refer to the following links for more details about our privacy information sharing policies.
Bigul
April 2, 2025 at 12:05 pm #16886881
Frameworks AS
591811#0: *9659221 FastCGI sent in stderr: "PHP message: WordPress database error Duplicate entry '562593-en' for key 'trid_lang' for query INSERT INTO `wp_icl_translations` (`element_type`, `language_code`, `trid`) VALUES ('tax_nav_menu', 'en', '562593') made by require_once('wp-load.php'), require_once('wp-config.php'), require_once('wp-settings.php'), do_action('init'), WP_Hook->do_action, WP_Hook->apply_filters, WPML_Nav_Menu->init, WPML_Nav_Menu->_set_menus_language, SitePress->set_element_language_details, WPML_Set_Language->set, WPML_Set_Language->insert_new_row; PHP message: WordPress database error Duplicate entry '562829-en' for key 'trid_lang' for query INSERT INTO `wp_icl_translations` (`element_type`, `language_code`, `trid`) VALUES ('tax_nav_menu', 'en', '562829') made by require_once('wp-load.php'), require_once('wp-config.php'), require_once('wp-settings.php'), do_action('init'), WP_Hook->do_action, WP_Hook->apply_filters, WPML_Nav_Menu->init, WPML_Nav_Menu->_set_menus_language, SitePress->set_element_language_details, WPML_Set_Language->set, WPML_Set_Language->insert_new_row" while reading response header from upstream
I'm getting this in the logs constantly
New threads created by Bigul and linked to this one are listed below:
https://wpml.org/forums/topic/wordpress-database-error-duplicate-entry-562593-en-for-key/
April 2, 2025 at 3:21 pm #16887832
Bigul
Thank you for the updates. I have added a new ticket for the DB error issue.
Please note that I am not able to log in; it is redirected to the login page again. Refer to the following screencast for more details.
Also, please share the URL of the page/pages having the problem: hidden link
Bigul
April 2, 2025 at 5:12 pm #16888224
Frameworks AS
try again— creating the user gave it an ID of 0. I assume wpml has ruined the database to the point where I have to move away from this server
April 3, 2025 at 10:33 am #16891349
Bigul
I am still facing issues with logging in to the site. It shows the following warning while accessing admin pages. Please check and grant me admin access.
Sorry, you are not allowed to access this page.
Bigul
April 14, 2025 at 5:57 pm #16930939
Bigul
Thank you for the updates and login information. I can access the site backend now.
Please check the attached image. Hope you are trying to translate these texts; am I correct?
If not, please share a couple of screenshots for a better understanding of the problem.
Bigul
The topic ‘[Closed] ACF Blocks are not showing for translation’ is closed to new replies.
