The client is experiencing issues with ACF field group labels still appearing in WPML > Translation Management despite using the define('ACFML_EXCLUDE_FIELD_GROUP_STRINGS_IN_POST_JOBS', true); setting.
The constant *ACFML_EXCLUDE_FIELD_GROUP_STRINGS_IN_POST_JOBS* just prevents new occurrences of ACF Field Groups listing for translation in WPML Translation Management Dashboard.
So we recommend adding the following code to your functions.php file, ensuring you take a full backup before making changes:
 * Exclude the ACF field group section on the Translation Management Dashboard.
 * @see https://onthegosystems.myjetbrains.com/youtrack/issue/acfml-990
add_filter( 'wpml_tm_dashboard_item_sections', function( $sections ) {
    /** @var \WPML\UserInterface\Web\Core\Component\Dashboard\Application\ViewModel\ItemSection[] $sections */
    return array_filter(
                $sections,
                function( $section ) {
                    return $section->getId() !== 'stringPackage/acf-field-group' && $section->getId() !== 'stringPackage/acf-options-page-labels';
If this solution does not apply to your case, or if it becomes outdated, we highly recommend checking related known issues at https://wpml.org/known-issues/, verifying the version of the permanent fix, and confirming that you have installed the latest versions of themes and plugins. If further assistance is needed, please open a new support ticket at WPML support forum.
Last updated by Bigul 6 months, 2 weeks ago.
Assisted by: Bigul.
July 25, 2025 at 10:23 am #17270670
thomasS-38
Back to the Field Group Labels. It seems that the define('ACFML_EXCLUDE_FIELD_GROUP_STRINGS_IN_POST_JOBS', true); did not work after all. I still see them in the WMPL > Translation Management
July 25, 2025 at 10:34 am #17270690
Bigul
Welcome to the WPML support forum. I will do my best to assist you in resolving the issue.
I have created this ticket for easier follow-up and to avoid discussing multiple issues in a single thread.
The issue persists even after applying the following code in the functions.php file of your theme. Therefore, I have shared the details with our team for further review and am currently awaiting their feedback. Please wait.
add_filter( 'wpml_tm_dashboard_documents', function( $documents ) {
    return array_filter( $documents, function( $doc ) {
        return $doc->translation_element_type !== 'package_acf-field-group';
Bigul
August 20, 2025 at 4:49 pm #17335249
Bigul
Sorry for the delayed response. We were testing the best workaround for this issue, and it worked as expected after adding the following code to the functions.php file in our local copies. Please try it on your site after taking a full backup and let us know your feedback.
 * @see <em><u>hidden link</u></em>
                $sections,
Bigul
