I am using WPML on a site with Bricks and have trouble with the Advanced editor.
I used pay-as-you-go for the majority of the translation and need to do some editing and when I try to load the editor, it just keeps on loading but never actually loads. I already upped the memory limit to 512 mb from 215 but it didn't help either.
Languages: English (English )Portuguese (Brazil) (Português )
Thanks for your contact.
Before your ticket is assigned to one of my colleagues, please allow me to walk you through some initial debugging steps. This will help speed up the support process.
We might be facing an interaction issue with a third-party functionality, in this case:
- Make sure to have a website backup
- Deactivate all the plugins that are not related to WPML
- Switch for a moment to a WordPress default theme like Twenty Twenty-one
- If the issue is gone, activate one by one to see with which one there is an interaction issue
Could you please tell me the results of this investigation? Also, can you enable the debug mode? Just add the following code in your wp-config.php file:
// Enable WP_DEBUG mode
define( 'WP_DEBUG', true );
// Use dev versions of core JS and CSS files (only needed if you are modifying these core files)
define( 'SCRIPT_DEBUG', true );
After adding the code above, try to reproduce the issue again and check if you'll find a debug.log file inside the wp-content folder. If you locate it there, kindly send us the last lines here in the ticket.
Mateus.
Kind regards,
Mateus.
The topic ‘[Closed] Advanced editor won't load’ is closed to new replies.
