3- Update the page in the default language
4- Update its translation
Please note that the currency symbol won't be translated using the translation editor, so you will need to edit the translated page using Elementor and change it.
1) First of all, sorry for the late reply; it was due to a higher workload. Please login to this sandbox site and install the ElementsKit plugins. (hidden link)
After that, please create a test page using the toggle element and translate it to replicate the issue.
If the issue is replicable, please let me know how to reproduce it.
2) It's not related to the issue, but according to your Debug.info, the WP memory limit needs to be increased. PHP memory is fine, but WordPress uses 40Mb as default. The minimum requirements for WPML are 128 MB. (Kindly check this page https://wpml.org/home/minimum-requirements/)
You can increase it by adding the following code in your wp-config.php file right before the /* That's all, stop editing! Happy publishing. */ line:
Thank you for getting back to me. I have updated the memory.
As for the translation of elementskit advanced toggle; I received a video from their team showing how to make the elements visible for editing and translating here: hidden link
This already helped me a lot and I could translate most.... but not all.
I noticed that some parts of the pricing table I can not translate, for instance the currency symbol or the 2nd and 3rd product button link.
I will install the elementskit in the sandbox environment as soon as it loads, seems very slow
unfortunately for the advanced toggle; this is an advanced feature so need the pro version. the pro version came with the theme and only 1 license so I can not install. please advise.
Thanks for your update. Please create a test page on your site named "WPML TEST", add the problematic elements, and translate it.
Also, I would need to request temporary access (WP-Admin and FTP) Preferably to a test site where the problem has been replicated.
Kindly check if the translated test page works correctly. If yes, please update the home page in the default language and its translation.
Please check the following guides to know more about registering page builder widgets.
2 things:
A. I noticed that for 1 dynamic element, specifically by the name "dynamic-content-widget-210658c-a43fd2c" does offer the translation of the other button links, however this is not the case in the other other piece of dynamic content, for instance 2nd one with name "dynamic-content-widget-210658c-ed823ec"
B. as mentioned before these dynamic content items are tricky and can not be changed in the elementor editor us per usual; we can not change the currency symbol through elementor, it would change the main language too
Now, considering that somehow you managed to get the other button links translatable in at least one of dynamic content items, why would this not work for field 'currency' symbol?
Thanks again.
P.s.: I have no issue if you would test on the actual home page where the issue is taking place, I have a backup.
2) The currency symbol is not a test, so it won't show in ATE. In order to translate it, please check the following steps:
1- Go to ElementsKit items-> All Items
2- Switch the language using the top admin bar to Dutch
3- Edit the translated item using Elementor
4- Change the Sympol
