The client reported an issue with the WPML Advanced Translation Editor where the progress indicator always shows 100%, even when there are draft segments.
We explained that the appearance of a dash-line status indicates that the sentence is translated automatically. If the sentence is in Draft status, it will display an orange color line instead of a blue color line. Editing the sentence and clicking on Save changes the status to a straight-line, indicating manual translation. In both scenarios, the sentence is considered translated, and the total showing 100% is accurate. For further details, you can visit our forum post: https://wpml.org/forums/topic/advanced-translation-editor-total/#post-16014261
If this solution does not resolve your issue or seems outdated, we recommend checking related known issues at https://wpml.org/known-issues/, verifying the version of the permanent fix, and confirming that you have installed the latest versions of themes and plugins. Should you need further assistance, please open a new support ticket at WPML support forum.
This topic contains 7 replies, has 3 voices.
Last updated by Long Nguyen 1 year, 8 months ago.
Assisted by: Long Nguyen.
July 25, 2024 at 3:15 pm #16004351
markL-39
Updating a translation in the advanced translation editor, the total (100%) is not updated at all.
Can't see progress on translation editor
Could this be updated please
July 25, 2024 at 3:45 pm #16004622
Marcel
before your ticket is assigned to one of my colleagues, please allow me to walk you through some initial debugging steps. This will help speed up the support process.
Could you please provide a specific example of the issue you're encountering? For instance, do you complete a task 100%, but it doesn’t update on the frontend?
Thank you!
Marcel
July 26, 2024 at 2:21 pm #16009019
markL-39
Hello.
You should see in the enclosed video that the translation job completes, but the percentage complete indicator stays on 100% whether there are draft segments or not.
You should see a video enclosed here
July 29, 2024 at 8:02 am #16014261
Long Nguyen
WPML Supporter since 02/2022
Languages: English (English ) Vietnamese (Vietnamese )
Hi Mark,
Thank you for contacting WPML support, I’m happy to help you with this issue.
Those sentences are translated automatically and it has the dash-line status. If the translation sentence is in Draft status, it will have the orange color line instead of the blue color line. Please check the attached screenshot.
I hope that makes sense.
August 6, 2024 at 11:06 am #16043590
markL-39
Hi. Thanks. Understood.
But its actually about the total at the bottom of the page, which is always at 100%
August 7, 2024 at 1:25 am #16045921
Long Nguyen
Can you share a screenshot or a screen record (full screen) that shows a or some sentences that are not completed and the translation status still shows 100%?
August 7, 2024 at 9:27 am #16047128
markL-39
Here is a screen record of this. Hope you can see it.
I can't upload a video directly here only image
August 7, 2024 at 9:47 am #16047232
Long Nguyen
As I already mentioned https://wpml.org/forums/topic/advanced-translation-editor-total/#post-16014261
if you see the dash-line status, which means the sentence is translated automatically, it is actually translated.
if you edit the sentence and click on Save, the status will be changed to straight-line, which means the sentence is translated manually.
In both cases, the sentence is translated and the total shows 100% is correct.
August 7, 2024 at 10:42 am #16047456
markL-39
OK thanks understood.
However its a change from the previous design, a bit disconcerting.
Previously you had 2 ratios I think, blank and confirmed, but it din't work so well. Updating my mindset.
