The client is experiencing issues where translations made using the Advanced Translation Editor are not appearing on the frontend of their website. The original English content is displayed instead of the translated Dutch content.
1. Ensure that the 'Advanced Translation Editor' is enabled in WPML > Settings.
2. Edit the primary language page, including any titles or main content.
3. Resave the page to ensure all changes are updated and reflected on the frontend.
If these steps do not resolve the issue, it may be necessary to check the setup or redo the translations for existing pages where the issue persists. Additionally, if the problem continues or the solution provided here becomes outdated, we recommend visiting related known issues, verifying the version of the permanent fix, and confirming that you have installed the latest versions of themes and plugins. If further assistance is needed, please open a new support ticket.
Last updated by jeroenS-7 2 months ago.
May 27, 2025 at 1:49 pm #17079027
jeroenS-7
I am trying to translate a new website using the advanced translation editor, but the translations are not appearing as expected. The issue can be seen on this page: hidden link
The frontend of the website continues to display the original English content instead of the translated Dutch content.
Why are the translations not showing up on the frontend?
How can I ensure the translated content is displayed correctly?
May 28, 2025 at 1:06 am #17080937
WPML Supporter since 08/2022
Thanks for contacting us. Please check the page contents and make sure any custom Elementor widgets are registered as explained here https://wpml.org/documentation/support/multilingual-tools/registering-custom-elementor-widgets-for-translation/ .
If the issue continues, I will need to closely examine your website. Therefore, I will require temporary access (WP-Admin and FTP) to a test site where the problem has been replicated, if possible. This will enable me to provide better assistance and determine if any configurations need to be modified.
May 28, 2025 at 11:51 am #17083208
Thanks for your reply.
I've checked and all the contents are there as shown in the attached screenshot. This is what I've done.
1. I've enabled "Advanced Translation Editor" in WPML > Settings.
2. I've edited the primary language page and the title.
3. Resave the page and the contents show up
May 28, 2025 at 12:19 pm #17083355
jeroenS-7
Hi Kor,
I don't understand what you did. You made a new page and apparently that does work.
But what about the existing translations? Do I need to redo those to make it work? Was there something wrong with the setup or how this was done before? What can it be? Because I now edited the About translation, gave the page a new title, and that does work. But once I revert to the original title, the translation disappears also.
I don't get your second step, what did you edit in the primary language page? How? This step confuses me.
How can I make the translation of the About page, which is clearly there in the editor, show up on the front? See the attached image..
What is wrong with the About page, or the primary language? And how do I solve this for the other existing pages?
Thanks again!
Bas
May 28, 2025 at 12:23 pm #17083375
Thanks for your reply. The about page works fine for me as shown in this screen recording. This is what I've done hidden link
May 28, 2025 at 12:34 pm #17083397
jeroenS-7
Wow, I do exactly the same with Story-roadmap now, without result...
Why, why, why! Stuff like this is driving me crazy. I do exactly the same as you do. And Story-Roadmap is NOT translating, except for the meta title, which does show up translated (I think it already was)...
May 28, 2025 at 1:15 pm #17083626
Thanks for your reply. This is what I've done hidden link . It looks like the primary language page needs to be resaved. Could you check now?
May 28, 2025 at 1:30 pm #17083704
jeroenS-7
DUDE!!! You are the hero of the day!
This is crazy, I don't understand why, but it works that way. Yes! We did is for the homepage now, and that is also showing the translated text from now. Amazing!
Many, many thanks for helping a desperate me out today! This was it. Thanks for going the extra mile to show me how to fix it. Will do these steps next time we run into shit we can't explain.
Cheers!
