Last updated by Kor 1 year, 8 months ago.
June 13, 2024 at 1:12 pm #15736363
bjornB-33
I am using WPML with the Uncode theme on my site hidden link. I have spent hours trying to set up the translation.
Navigation points of different slugs like #vermittlung still appear in German and link to German subpages even after manual translation. Most buttons on the website have the same issue.
Is it possible to change the design size of the dropdown of the language switcher?
How can i fix the Navigation Issue? the #parts of the navigations are still german and link also to the german site 🙁
June 13, 2024 at 1:23 pm #15736454
bjornB-33
additionally the buttons are not translatet as well and not linked to the english page
June 13, 2024 at 2:20 pm #15736792
Thank you for contacting us. Typically, button links are translated using the Advanced Translation Editor. Could you please attempt the method outlined here and see if it resolves your issue? You can find the instructions at: https://wpml.org/announcements/2020/02/translating-links-with-advanced-translation-editor/
Regarding styling the dropdown language switcher, could you provide a rough idea of how you would like it to appear? I believe I can assist you with this.
June 20, 2024 at 6:03 am #15761060
bjornB-33
Re #2 (styling the dropdown language switcher):
Image 1 shows how it looks like now
Image 2 shows how we like to have it set up
Differences:
-Transparent background
-Font same size as currently chosen language
-Alternative language directly below currently chosen language
-Less distance between options
Please let us know how to achieve the desired result. Thank you!
June 20, 2024 at 6:33 am #15761306
Thanks for your reply.
June 30, 2024 at 5:21 pm #15862968
Thanks for your patience.
Please try inserting the custom CSS code below into WP > Appearance > Customize > Additional CSS. It should look like the attached if it works.
.submenu-dark .menu-horizontal .menu-smart ul {
    background-color: transparent;
    margin-left: 0px!important;
    padding: 0px;
    top: 70%;
span.wpml-ls-native {font-size: 22px!important;}
.wpml-ls-menu-item a.cursor-init {padding:0px!important;}
July 8, 2024 at 2:48 pm #15914120
bjornB-33
Hey Kor,
It's still not working. Most of the links are broken, and those links do not appear in the string translator. Could you please have a closer look? Maybe there is an option that we can search and replace all the links at least?
Thanks for your assistance.
Best,
July 8, 2024 at 5:05 pm #15914776
It looks like you've not translated the navigation menus yet and I've done it for you. Now, go to this link hidden link and correct the links and menu item titles so that it displays correctly on your English Language navigation menu.
Let me know once you've done that so that I could check further.
July 9, 2024 at 8:28 am #15918984
bjornB-33
Hey Kor,
great thanks! Thats works, I still have the problem with the buttons though unfortunately.
July 9, 2024 at 8:28 am #15918986
bjornB-33
I meant the buttons on the english site.
July 9, 2024 at 9:36 am #15919515
Thank you for your response.
I noticed that you've switched to using the "WordPress Editor" for manual translations. Here are the steps to manually change the links on the English Language page: hidden link
Alternatively, if you opt for the WPML Translation Editor, you can translate the links using the method outlined here: https://wpml.org/announcements/2020/02/translating-links-with-advanced-translation-editor/
July 14, 2024 at 8:02 am #15949653
bjornB-33
Dear Kor,
Many thanks for your support so far!
Re the language switch button, it looks much better now. However, the faded-in options for other languages
(a) appears relatively far away from the language switch button, and
(b) these options are not exactly the same size as the Language Switch button, but are slightly smaller.
We have simulated this in the graphic below (once the current status, once how the option should look).
Kindly ask you for further assistance in order to receive the desired outcome like in the graphic attached.
Thank you!
https://wpml.org/forums/topic/language-switcher-styling-issues-with-uncode-theme/
July 15, 2024 at 9:36 am #15953257
Thank you for your reply.
Upon review, it appears that the styling issues are quite complex, and I recommend contacting your theme author for assistance. Meanwhile, I have divided the ticket into two parts: one focusing on the language switcher styling concerns, which you can find here https://wpml.org/forums/topic/language-switcher-styling-issues-with-uncode-theme/ Please feel free to mark this current ticket as resolved.
The topic ‘[Closed] Assistance Required for WPML Issues with Uncode Theme’ is closed to new replies.
