The client reported that badges from Yith Badge Management were not displaying on their multilingual website in languages other than the default English.
We advised the client to duplicate the badge for each language they are using on their website. This can be done by accessing the badge edit page, selecting the desired language, and clicking on the "duplicate" button. This process is outlined in the Yith documentation, which can be found here: Yith Badge Management and WPML documentation.
If this solution does not apply to your situation, or if it seems outdated, we recommend opening a new support ticket. We also highly recommend checking related known issues at WPML Known Issues, verifying the version of the permanent fix, and confirming that you have installed the latest versions of themes and plugins.
This topic contains 19 replies, has 3 voices.
Last updated by Long Nguyen 1 year, 8 months ago.
Assisted by: Long Nguyen.
March 9, 2024 at 10:22 am #15391284
joonaP
On our website nordictemptations.com the badges from Yith Badge Management are not showing on the other languages apart from English which is the default. This plugin should be compatible with WPML, strings are translated and all WPML plugins are up to date.
Can you please help? Thank you in advance
For the time being I'm using the free version of this plugin and tested with only one badge. But will update to premium as soon as this problem is solved.
Link to the site and product concerned: hidden link
March 9, 2024 at 1:34 pm #15391488
According to YITH those badges need to get translated with WPML > String Translation.
You might need to scan the plugin for new strings first at WPML > Theme and Plugin Localization.
Did you follow this guide?
March 12, 2024 at 7:21 am #15397838
joonaP
I still need assistance, will come back to this in a few days
March 12, 2024 at 7:33 am #15397884
Long Nguyen
WPML Supporter since 02/2022
Hi Joona,
Thank you for contacting WPML support, I’m happy to help you with this issue.
I would like to request temporary access (wp-admin and FTP) to your site to take a better look at the issue. It would be better to have a testing site where the issue is replicated. Your next reply is set to private to share the info.
March 14, 2024 at 5:25 pm #15411741
joonaP
Hi, I've got another major issue on the site going on. I will come back to this in a later stage when the site (read: webshop) is working again
March 15, 2024 at 1:19 am #15412583
Long Nguyen
I'm waiting for your feedback.
March 19, 2024 at 2:23 am #15423849
Long Nguyen
The shared user isn't correct, please check the user account and share it with me again. Your next reply is set to private to share the info.
March 19, 2024 at 8:03 am #15424285
Long Nguyen
I found a way to show the badge on the translation product, please follow steps below:
1. Go to WPML > Settings > Custom Fields Translation > Click on Show system fields > Search for the field "_yith_wcbm_badge_ids" and set it to Copy > Save changes.
2. Go to WPML > Settings > Post Types Translation > Set the post type "Badges (yith-wcbm-badge)" preference to "Translatable - Only show translated items" > Save changes.
3. Go to Yith > Badge Management > Edit a badge and translate it into second languages like posts, pages ...
4. Edit the product > Click on Update to sync the badge from the original to translation product.
March 19, 2024 at 8:05 am #15424303
joonaP
Thanks for this, I will try your instructions a bit later. What about the paypal payment fields?
New threads created by Long Nguyen and linked to this one are listed below:
https://wpml.org/forums/topic/i-want-to-translate-woocommerce-paypal-payments-strings/
March 19, 2024 at 10:21 am #15425457
Long Nguyen
It is a separate issue so I will split this ticket into a new one for better handling.
March 19, 2024 at 11:23 am #15425901
joonaP
Hi again,
the badge shows now exactly as I wish, thank you!
March 19, 2024 at 6:05 pm #15428308
joonaP
So sorry, was too quick with this also.
I got the badge to show on the product. But when I try to assign the same badge to another product it doesn't show on the translated version. I have updated the product, even updated the translations, without success. I'm talking about this product: hidden link I haven't updated the staging site yet, please let me know if you want me to do so.
March 19, 2024 at 8:43 pm #15428873
joonaP
Forgot to tell you something important: I have in the meantime updated the plugin to premium. New staging site is now created, login details as before
Sari
March 20, 2024 at 2:35 am #15429319
Long Nguyen
I see the issue on your staging site. The solution above works with the free version of Yith Badge plugin but doesn't work with the premium version.
It could be a compatibility issue with WPML. Can you please help me replicate the issue on a clean installation of WordPress so I can escalate this to our compatibility team? You can access the admin area with this link.
Note: Please don’t restore your site there.
March 20, 2024 at 8:39 am #15429915
joonaP
The site is now replicated as you asked for.
