Last updated by Kor 1 month, 4 weeks ago.
May 4, 2025 at 3:17 pm #16993399
lieveV
I have added two pages with a gallery using Elementor Pro on my site hidden link. The pages are hidden link and hidden link. I have activated media translation in WPML settings.
<b>Symptoms: </b>
In the lightbox, the caption and description of images are shown but are not translated on the English pages. The standard language is Dutch.
<b>Questions: </b>
Why are the captions and descriptions in the lightbox not translated on the English pages?
Is there a specific setting in WPML that I need to adjust to ensure media translations appear correctly?
May 7, 2025 at 1:03 am #17003998
WPML Supporter since 08/2022
Thanks for contacting us. I can see the issue when I compared with the original language here hidden link .
While checking the debug info, I see that the WordPress Memory Limit is below the requirements. The minimum requirements are 128M, but we do recommend 256M and the debug information of your site shows it set to 40M. Please check this link for more details
https://wpml.org/home/minimum-requirements/.
You can increase it by adding the following code in your wp-config.php file, right before the /* That’s all, stop editing! Happy publishing. */ line:
define( 'WP_MEMORY_LIMIT', '128M' );
After adding the code you can confirm that the memory was changed correctly from WPML > Support > WordPress > Memory limit.
May 13, 2025 at 2:35 pm #17028539
Thanks for your reply. You have everything setup correctly. You just have to translate the title and description using the media translation as explained here https://wpml.org/documentation/getting-started-guide/media-translation/
here is a screen recording for your reference hidden link
May 13, 2025 at 4:41 pm #17029203
lieveV
Hi Kor
Thank you. I think I followed the instructions in the documentation, but still nothing is translated.
Kind regards
Lieve
May 13, 2025 at 5:08 pm #17029264
Thanks for your reply. Have you seen the screen recording here hidden link of when I made changes to your website?
May 14, 2025 at 8:58 am #17031066
lieveV
Yes I have, but does that mean that I have to translate captions and descriptions manually for every image? 🙁
May 14, 2025 at 10:47 am #17031703
Thanks for your reply. Yes, that's correct. You'll need to use the media translation for this.
The topic ‘[Closed] Caption and description of images opening in lightbox are not translated’ is closed to new replies.
