9:00 – 13:00 9:00 – 13:00 9:00 – 13:00 9:00 – 13:00 9:00 – 13:00 - -
14:00 – 18:00 14:00 – 18:00 14:00 – 18:00 14:00 – 18:00 14:00 – 18:00 - -
Last updated by Christopher Amirian 11 months, 2 weeks ago.
May 20, 2025 at 9:38 am #17051722
jaapd-2
We have a webshop with 3 languages: NL as primary, and EN and DE as secondary. We changed the primary language to EN and want to remove NL and DE languages, then remove WPML.
When opening an EN product, it shows as a translation of NL and cannot be edited.
How can we make the EN products editable and set them as primary?
May 20, 2025 at 11:46 am #17052502
Carlos Rojas
WPML Supporter since 03/2017
Thank you for contacting us
To achieve this, you must follow these steps:
- Create a full site backup
- Edit a product in NL (original language)
- Go to the Language block (usually in the right column) -> Click on WordPress Editor -> In the popup window, select the scope of the change -> Save the changes
- Now you will be able to edit the products in English.
Let us know if you need further assistance.
May 20, 2025 at 12:13 pm #17052637
jaapd-2
Hi Carlos,
I need to to do this for all products in one go. With your steps it would need to be done per product (+450). Is there another option?
Cheers,
Jaap
May 20, 2025 at 1:42 pm #17053124
Christopher Amirian
WPML Supporter since 07/2020
Hi Jaap,
Welcome to WPML support. There is no bulk way to 100% remove everything but you can use this method:
- I repeat it is very important that you have a backup, so in any case the method does not work you will have away to bring back the website.
- Go to WPML > Settings and make sure the options below are unchecked:
- When deleting a post, delete translations as well
- When deleting a taxonomy (category, tag or custom), delete translations as well
- Go to List of the pages and from the top language switcher select the language you do not want.
- Select all the pages for that language and remove them.
- Do the same for other language that you do not want.
- Do the same for posts, categories, products or any other custom post you have.
- Go to WPML > Languages and click the Add/Remove languages button and remove the other two languages.
- Make sure you also delete the data of those languages after select save. (it will show in the list below the languages option)
- Deactivate WPML and check if everything works.
The topic ‘[Closed] Change primary language products’ is closed to new replies.
