You are experiencing issues with Contact Form 7 on your translated event page using WPML, built with Gutenberg and Kadence blocks pro. Specifically, dropdown fields in Contact Form 7 are not displaying correctly, the edit screen doesn't load properly, ACF Pro fields are missing on the translated page, and new translations are not appearing in the translation queue.
We recommend trying the steps outlined in this forum post: WPML Multilingual CMS & Contact Form 7. Additionally, a permanent fix is expected in the next version of Contact Form 7 Multilingual, version 1.3.2. Although we do not have an exact release date, it is anticipated to be available soon.
Please note that this solution might be outdated or not applicable to your specific case. We highly recommend checking related known issues at https://wpml.org/known-issues/, verifying the version of the permanent fix, and confirming that you have installed the latest versions of themes and plugins. If the issue persists, please open a new support ticket.
This topic contains 0 reply, has 2 voices.
Last updated by Bruno Kos 8 months, 2 weeks ago.
Assisted by: Bruno Kos.
November 19, 2024 at 10:24 am
peter-rF
I have translated an event page using WPML, built in Gutenberg with Kadence blocks pro. I created a Contact form 7 for registrations, and I have updated the ACF Pro fields and string translations. I have also increased my WP Memory limit based on forum posts.
The dropdown fields in Contact form 7 are not showing correctly. The edit screen for Contact form 7 forms doesn't load correctly, preventing me from updating the form name. ACF Pro fields do not show up when hovering over the menu in the translated page. New translations do not appear in the translation queue.
Why are the dropdown fields in Contact form 7 not showing correctly?
Why can't I update the form name in Contact form 7?
Why do ACF Pro fields not show up in the translated page?
Why don't new translations appear in the translation queue?
November 19, 2024 at 10:52 am
November 19, 2024 at 12:54 pm #16419691
peter-rF
I have been troubleshooting and when I disable the Contact Form 7 Multilingual plugin, the contact form 7 edit screen is no longer broken.
November 19, 2024 at 1:15 pm #16419800
Bruno Kos
If I check hidden link, dropdown values show in English now.
It this done on purpose, or?
November 19, 2024 at 6:22 pm #16421022
peter-rF
Hi Bruno, as I specified earlier, if I disable the Contact Form 7 Multilingual plugin it resolves the contact form 7 editing screen from displaying incorrectly. But also means that the form is no longer translated. I have reverted back to enabling this plugin. I would very much appreciate your support with this at your soonest convenience. Thank you
November 20, 2024 at 9:48 am #16423544
Bruno Kos
Can you try this?
https://wpml.org/forums/topic/wpml-multilingual-cms-i-contact-form-7/#post-16422385
But I see in our system that the permanent patch will go into Contact Form 7 Multilingual 1.3.2, so the next version.
I don't have an exact date, but most likely soon.
November 20, 2024 at 3:46 pm #16425515
peter-rF
Hi Bruno, this resolved the conflict issues with CF7 but I am still unable to see any of my drop_menu, this is an ACF which shows a dropdown menu on the main nav.
New threads created by Bruno Kos and linked to this one are listed below:
https://wpml.org/forums/topic/split-contact-form-7-and-acf-pro-specific-parts-not-showing/
November 20, 2024 at 3:47 pm #16425517
peter-rF
Are there issues with ACF clone fields and WPML?
November 21, 2024 at 7:13 am #16427465
Bruno Kos
That being a different issue, I created a ticket here https://wpml.org/forums/topic/split-contact-form-7-and-acf-pro-specific-parts-not-showing/, let me close here and continue there.
