The client is unable to create a fully-functioning staging site replica of their production site using 'subdomain-like' URLs to distinguish languages without changing their hosting subscription.
We recommend using the free version of the Duplicator plugin to clone the production site to a staging environment. After importing the site into the staging environment, the client should change the Language URL format to ensure it functions correctly. This approach avoids the need to upgrade the hosting plan.
If this solution does not apply to your situation, or if it seems outdated, we highly recommend checking related known issues at https://wpml.org/known-issues/, verifying the version of the permanent fix, and confirming that you have installed the latest versions of themes and plugins. If issues persist, please open a new support ticket at WPML support forum for further assistance.
Last updated by Kor 1 year, 6 months ago.
September 10, 2024 at 4:34 pm #16162887
Javier
In all these years using WPML, we have never been able to create a fully-functioning staging site replica of our production site. Our homepage URLs are for EN, FR, and ES respectively: hidden link, hidden link, hidden link. Our hosting service says we would need to change our subscription which is already quite significant cost-wise. Your support team seems to be able to do this, is there anyway we can do this please? The use of 'subdomain-like' URLs to distinguish languages was a choice we have regretted every time we tried to build a staging site.
Unable to create a fully-functioning staging site replica of our production site using 'subdomain-like' URLs to distinguish languages.
Is there any way we can create a fully-functioning staging site replica of our production site using 'subdomain-like' URLs to distinguish languages without changing our hosting subscription?
September 10, 2024 at 4:56 pm #16162986
Thanks for your patience.
September 13, 2024 at 6:50 pm #16177472
Thank you for your response.
I've investigated the issue and it seems like it might be related to another third-party plugin. Have you considered deactivating your third-party plugins one by one to see if you can pinpoint the one causing the problem? If you decide to do that, please make sure you have a backup prepared on your end.
September 16, 2024 at 9:50 am #16182693
Javier
Hello Kor, thank you for your kind support. I have made a backup and authorise you to do what you consider necessary (deactivate and reactivate plugins and the theme, as well as make configuration changes on the site if necessary).
September 16, 2024 at 10:36 am #16182951
Thanks for your reply.
Did you make any changes on your end? I cannot see any issues now.
September 17, 2024 at 9:54 am #16187419
Javier
Hello, no changes on my side, it seems the issue appears randomly, will get back when I see it again as I can't reproduce it at this moment.
