You are experiencing a connection issue with WPML on your site, specifically a cURL error 7 indicating a timeout when trying to connect to cdn.wpml.org.
We recommend that your hosting provider whitelists the following domains to resolve the connection issue:
- wpml.org
- cdn.wpml.org
- api.wpml.org
- api.toolset.com
- cloudfront.net
Please follow the steps in our dedicated guide here.
If this solution does not apply to your case, or if it seems outdated, we highly recommend checking related known issues at https://wpml.org/known-issues/, verifying the version of the permanent fix, and confirming that you have installed the latest versions of themes and plugins. Should you need further assistance, please open a new support ticket here.
Last updated by Andrey 12 months ago.
Assisted by: Andrey.
October 25, 2024 at 10:24 am #16330061
bangsongB
I am trying to resolve a connection issue with WPML on my site hidden link. We have attempted to solve this with our hosting provider, but they advised contacting the service provider related to cdn.wpml.org for further assistance. I am following the status display in my backend.
cURL error 7: Failed to connect to cdn.wpml.org port 80: Connection timed out.
What is the exact IP address I should disable to resolve the connection issue with cdn.wpml.org?
October 25, 2024 at 10:25 am #16330138
bangsongB
code: http_request_failed
message: cURL error 7: Failed to connect to cdn.wpml.org port 80: Connection timed out
October 25, 2024 at 1:33 pm #16330923
Andrey
WPML Supporter since 06/2013
I apologize for the trouble you've encountered.
It looks like a firewall is blocking WPML. Your hosting provider needs to whitelist the following domains:
- wpml.org
- cdn.wpml.org
- api.wpml.org
- api.toolset.com
- cloudfront.net
Please refer to our dedicated guide here: https://wpml.org/faq/wpml-plugin-cannot-connect-to-wpml-org/.
