You are using WPML with the BeTheme theme and WooCommerce, and have encountered an issue where the currency display in a product quickview popup does not update to the selected currency (e.g., Euro - EUR) and instead shows the default currency (Polish Zloty - PLN). This issue occurs despite the selected currency displaying correctly across the rest of the site.
If you're experiencing this issue, we recommend you try the following steps:
1. Ensure you make a full backup of your website.
2. Open your functions.php file. You can do this in Appearance > Theme file editor > functions.php.
3. Add the following code:
// WPML Workaround for compsupp-7826<br />add_filter( 'wcml_multi_currency_ajax_actions', 'add_action_to_multi_currency_ajax', 10, 1 );<br /><br />function add_action_to_multi_currency_ajax( $ajax_actions ) {<br /><br />    $ajax_actions[] = 'mfnproductquickview';<br />    return $ajax_actions;<br /><br />}
4. Save the changes.
This solution might be irrelevant if it's outdated or not applicable to your case. We highly recommend checking related known issues at https://wpml.org/known-issues/, verifying the version of the permanent fix, and confirming that you have installed the latest versions of themes and plugins. If the issue persists, please open a new support ticket.
Last updated by pavelK-39 4 months, 2 weeks ago.
January 23, 2025 at 1:42 pm #16628226
pavelK-39
I am using WPML with the BeTheme theme and WooCommerce. I’ve implemented a product quickview popup, but I’ve encountered an issue with currency display. After switching the currency using WPML Currency Switcher or the Currency Switcher for WooCommerce plugin, the popup displays prices in the default currency (Polish Zloty - PLN), even if the user selects another currency (e.g., Euro - EUR). The selected currency is displayed correctly across the rest of the site, but not in the popup. I attempted to switch the currency in the popup via PHP using wcml_switch_currency and get_woocommerce_currency(), but the popup does not reflect the selected currency. I ensured the woocommerce_multicurrency cookie is set correctly, but this did not resolve the issue. Link to a page where the issue can be seen: Test server ip 159.223.210.131 address:fedrs.eu
The popup displays prices in the default currency (PLN) instead of the selected currency (e.g., EUR).
How can I properly configure the currency to update in the popup?
Are additional WPML settings required to handle popups correctly?
January 23, 2025 at 2:02 pm #16628413
Lucas Vidal de Andrade
WPML Supporter since 11/2023
I would like to request temporary access (wp-admin and FTP) to your site to take a better look at the issue. It would be better to a testing site where the issue is replicated.
IMPORTANT
- If you do not see the wp-admin/FTP fields this means your post & website login details will be made PUBLIC. DO NOT post your website details unless you see the required wp-admin/FTP fields. If you do not, please ask me to enable the private box. The private box looks like this:
I'll sent you further instructions, depending on what I find.
January 23, 2025 at 2:11 pm #16628514
pavelK-39
i give you access
if you need see website you need on windows update hosts file
159.223.210.131 fedrs.eu
also sftp access you can you like ssh
January 27, 2025 at 7:23 am #16635993
pavelK-39
Please tell me if something needs more
January 27, 2025 at 11:33 am #16637392
pavelK-39
In your test website i cant activate betheme i don't have new code, that's why i deregister my code from my own website, please when you will complete testing deregister betheme code.
i cant use template because is error time out, please add more php input
PHP Time Limit
60
Current time limit is OK, however 180 is recommended.
PHP Max Input Vars
1000
Minimum 5000 is required
January 27, 2025 at 12:12 pm #16637571
Hey there,
I'm currently checking. I'll let you know once I'm done. Thanks.
January 27, 2025 at 12:54 pm #16637785
Hey there,
I was able to reproduce the issue in the testing environment, thanks. We still need to check the issue with BeTheme active, so please don't deactivate it yet. I'll let you know once we hear from our developers.
January 27, 2025 at 1:27 pm #16638028
pavelK-39
Thanks, i will wait response
January 28, 2025 at 12:20 pm #16641591
Hey there,
I got feedback from our developers. Please make sure to make a full website backup, and follow these steps:
1. Open your functions.php file (you can do that in Appearance > Theme file editor > functions.php);
2. Add the code:
3. Save
That should do it. Let me know how it goes.
January 28, 2025 at 5:13 pm #16643460
pavelK-39
Thank you, its works))
