Last updated by Bigul 1 year, 9 months ago.
Assisted by: Bigul.
November 15, 2023 at 1:38 pm #14809193
fionaM-12
Having issues with Currency switcher. It does not change currency based on country / IP of the user. Also, the currency selector has disappeared
November 15, 2023 at 3:37 pm #14811083
fionaM-12
Still not working.
November 15, 2023 at 4:25 pm #14811699
Bigul
WPML Supporter since 01/2013
Thank you for the updates. Please fill in the private details fields after a full site backup{mandatory}. I would like to access the admin area of your site for further checking. Refer to the following links for more details about our private information sharing policies.
Please allow me to make a duplicator copy of your site using the Duplicator plugin(https://wordpress.org/plugins/duplicator/) for debugging the issue on my local server.
Bigul
November 16, 2023 at 4:52 am #14821713
Bigul
Please check the attached image. Now the staging site is asking for the Authorization credentials.
So I am enabling the private option for the next reply. Please share the credentials to access it.
Bigul
November 16, 2023 at 6:22 am #14822097
fionaM-12
I have removed the security popup. please check.
November 16, 2023 at 8:55 am #14823147
Bigul
Thank you for the updates. I can access the site now. Can I switch the theme to the default 2023 for debugging?
Bigul
November 16, 2023 at 11:09 am #14824749
fionaM-12
Hi Support,
I need to manually switch the currency switcher as per IP Location using Javascript in WordPress, can you please tell me what hook or code i can do?
Mahendra
November 16, 2023 at 11:37 am #14825083
Bigul
Hi Mahendra,
Thank you for the updates. You can use the following hooks for the customizations.
https://wpml.org/wcml-hook/wcml_client_currency/
https://wpml.org/wcml-hook/wcml_geolocation_get_user_country/
Please visit the following URL to get more details about WooCommerce Multilingual hooks.
https://wpml.org/documentation/related-projects/woocommerce-multilingual/wcml-hooks-reference/
Bigul
November 16, 2023 at 12:34 pm #14826497
fionaM-12
Hi Support,
I am using the below code to switch the currency, but i have no idea what class or ID i can use for swiche by javascript.
my code is below, please correct this. and i have attached the website switcher screenshot for class. hidden link
document.addEventListener('userCountrySet', function(e) {
var userCountry = e.detail;
// Mapping of countries to currencies
var countryCurrencyMap = {
"USA": "USD",
"UK": "GBP",
"EU": "EUR",
"IN": "GBP"
// Add more mappings as needed
// Function to set the default currency in WPML
function setDefaultCurrency() {
var currency = countryCurrencyMap[userCountry] || "USD"; // Default to USD if country not found
// Find WPML currency switcher element and set the value
var currencySwitcher = document.querySelector('.wcml_currency_switcher'); // Replace with the correct ID or class
if (currencySwitcher) {
currencySwitcher.value = currency; // Set the currency
// Trigger any change events if necessary
var event = new Event('change');
currencySwitcher.dispatchEvent(event);
// Run the function
setDefaultCurrency();
November 16, 2023 at 3:10 pm #14828289
Bigul
Thank you for the feedback. I have consulted about this with our team for the expert opinion. Sorry, we have limitations to supporting customized themes/plugins or codes as a part of our support policies. But maybe you can find a workaround using wcml_load_currency function of the following JS file.
Also, one request. Please downgrade to 5.2.1 version of WooCommerce Multilingual on your staging site after a site backup and make sure the issue exists or not.
Bigul
November 16, 2023 at 3:46 pm #14828473
fionaM-12
Hi Support,
Don't worry i have fixed the issue. Thanks For support.
November 16, 2023 at 4:04 pm #14828723
Bigul
Thank you for the feedback. Happy to know you are getting the expected results now. Please feel free to ping us if you need any further assistance with WPML.
Bigul
