The client has set up the ACF fields programmatically and he was unable to translate them using the WPML Translation Editor. It is not possible to translate the ACF Fields if they are not existing in WP Admin.
If you're experiencing issues with custom ACF fields not working correctly after following WPML instructions, it's likely due to translation preferences not being set properly.
First, ensure that the ACF Multilingual add-on is installed, as it adds custom fields to each ACF Field to manage translation preferences. These fields are not registered within WP Admin, so they need to be configured in WPML settings. For a guide on how to translate sites built with ACF, visit our documentation.
Next, navigate to WPML > Settings > Custom Field Translation. Here, you should set the fields that require translation to "Translate". Additionally, the ACF Field Groups should be set to the translation preference "Expert". For more detailed instructions, refer to this guide.
If this solution doesn't seem relevant to your issue, please don't hesitate to open a new support ticket with us for further assistance.
Last updated by herriaanF 1 year, 11 months ago.
January 18, 2024 at 1:27 pm
herriaanF
Custom ACF multi translation site not working after follow instructions WPML
January 19, 2024 at 6:40 pm #15206131
To translate each field, our add-on ACF Multilingual adds custom fields to each ACF Field that allow to handle the translation preference.
We can sadly not control those fields inside ACF, as they are not registered inside WP Admin.
Guide:
January 19, 2024 at 6:42 pm #15206136
I see you can find your custom fields at WPML > Settings > Custom Field Translation.
See screenshot.
You will need to make sure to set the fields that do need a translation to "Translate".
Guide:
https://wpml.org/documentation/related-projects/translate-sites-built-with-acf/expert-translation-option/
The ACF Field Groups should use the translation preference "Expert" in this case.
January 22, 2024 at 3:54 pm #15212676
herriaanF
Hi Andreas,
Is this still the case when the ACF has a custom code in de function.php?
Is not not set in the plugin. I noticed the translation only shows when using a other page template then default.
January 23, 2024 at 12:52 am #15213856
herriaanF
Can you please check my settings I have a strong feeling that this is causing the problem
Array
[hide_upgrade_notice] => 3.2.7
[icl_capabilities_verified] => 1
[active_languages] => Array
[0] => en
[1] => nl
[interview_translators] => 1
[existing_content_language_verified] => 1
[language_negotiation_type] => 1
[theme_localization_type] => 2
[icl_lso_header] => 0
[icl_lso_link_empty] => 0
[icl_lso_flags] => 0
[icl_lso_native_lang] => 1
[icl_lso_display_lang] => 0
[sync_page_ordering] => 1
[sync_page_parent] => 1
[sync_page_template] => 1
[sync_ping_status] => 1
[sync_comment_status] => 1
[sync_sticky_flag] => 1
[sync_private_flag] => 1
[sync_post_format] => 1
[sync_delete] => 1
[sync_delete_tax] => 1
[sync_post_taxonomies] => 1
[sync_post_date] => 1
[sync_taxonomy_parents] => 0
[translation_pickup_method] => 0
[notify_complete] => 1
[translated_document_status] => 1
[remote_management] => 0
[auto_adjust_ids] => 0
[alert_delay] => 0
[promote_wpml] => 0
[troubleshooting_options] => Array
[http_communication] => 1
[automatic_redirect] => 0
[remember_language] => 24
[icl_lang_sel_type] => list
[icl_lang_sel_stype] => classic
[icl_lang_sel_orientation] => horizontal
[icl_lang_sel_copy_parameters] =>
[icl_widget_title_show] => 0
[translated_document_page_url] => auto-generate
[sync_comments_on_duplicates ] => 0
[seo] => Array
[head_langs] => 0
[canonicalization_duplicates] => 0
[head_langs_priority] => 1
[posts_slug_translation] => Array
[on] => 1
[string_name_migrated] => 1
[types] => Array
[cpt_news] => 1
[cpt_agenda] => 1
[cpt_project] => 1
[languages_order] => Array
[0] => nl
[1] => en
[urls] => Array
[directory_for_default_language] => 0
[show_on_root] =>
[root_html_file_path] =>
[root_page] => 0
[hide_language_switchers] => 1
[admin_default_language] => en
[taxonomy_names_checked] => 1
[setup_complete] => 1
[ajx_health_checked] => 1
[default_categories] => Array
[nl] => 1
[en] => 3
[default_language] => nl
[setup_wizard_step] => 4
[font-current-normal] => #444444
[font-current-hover] => #000000
[background-current-normal] => #ffffff
[background-current-hover] => #eeeeee
[font-other-normal] => #444444
[font-other-hover] => #000000
[background-other-normal] => #ffffff
[background-other-hover] => #eeeeee
[border] => #cdcdcd
[icl_lang_sel_config] => Array
[border] => #cdcdcd
[background] => #eeeeee
[icl_lang_sel_footer_config] => Array
[border] => #cdcdcd
[icl_language_switcher_sidebar] => 0
[icl_lang_sel_footer] => 0
[icl_post_availability] => 0
[icl_post_availability_position] => below
[icl_post_availability_text] => This post is also available in: %s
[language_selector_initialized] => 1
[translation-management] => Array
[notification] => Array
[new-job] => 1
[completed] => 1
[resigned] => 1
[dashboard] => 1
[purge-old] => 7
[include_xliff] => 0
[completed_frequency] => 1
[overdue] => 1
[overdue_offset] => 7
[custom_fields_translation] => Array
[title] => 2
[description] => 2
[keywords] => 2
[_edit_last] => 0
[_edit_lock] => 0
[_wp_page_template] => 0
[_wp_attachment_metadata] => 0
[original_post_id] => 0
[_wpml_original_post_id] => 0
[_wp_old_slug] => 0
[_icl_translator_note] => 0
[_alp_processed] => 0
[_pingme] => 0
[_encloseme] => 0
[_icl_lang_duplicate_of] => 0
[_thumbnail_id] => 0
[_wp_attached_file] => 0
[_yoast_wpseo_title] => 2
[_yoast_wpseo_bctitle] => 2
[_yoast_wpseo_metadesc] => 2
[_yoast_wpseo_metakeywords] => 2
[_yoast_wpseo_focuskw] => 2
[_yoast_wpseo_meta-robots-noindex] => 1
[_yoast_wpseo_meta-robots-nofollow] => 1
[_yoast_wpseo_meta-robots-adv] => 1
[_yoast_wpseo_canonical] => 0
[_yoast_wpseo_redirect] => 0
[_yoast_wpseo_opengraph-description] => 2
[_yoast_wpseo_google-plus-description] => 2
[_yoast_wpseo_twitter-title] => 2
[_yoast_wpseo_twitter-description] => 2
[agenda_organizer] => 1
[_agenda_organizer] => 0
[agenda_start_date] => 1
[_agenda_start_date] => 0
[agenda_time] => 1
[_agenda_time] => 0
[agenda_locatie] => 1
[_agenda_locatie] => 0
[agenda_who] => 1
[_agenda_who] => 0
[agenda_exceptions] => 1
[_agenda_exceptions] => 0
[agenda_banner] => 1
[_agenda_banner] => 0
[_dp_original] => 0
[news_image] => 1
[_news_image] => 1
[project_image] => 1
[_project_image] => 0
[related_agenda] => 1
[_related_agenda] => 1
[related_news] => 1
[_related_news] => 1
[related_project] => 1
[_related_project] => 1
[projet_organizer] => 0
[_projet_organizer] => 0
[project_start_date] => 0
[_project_start_date] => 0
[project_time] => 0
[_project_time] => 0
[project_locatie] => 0
[_project_locatie] => 0
[project_who] => 0
[_project_who] => 0
[project_exceptions] => 0
[_project_exceptions] => 0
[project_finance] => 0
[_project_finance] => 0
[project_budget] => 0
[_project_budget] => 0
[project_link] => 0
[_project_link] => 0
[related_agenda_0_related_agenda_item] => 0
[_related_agenda_0_related_agenda_item] => 0
[related_news_0_related_news_item] => 0
[_related_news_0_related_news_item] => 0
[related_project_0_related_project_item] => 2
[_related_project_0_related_project_item] => 0
[project_introduction_title] => 0
[_project_introduction_title] => 0
[project_introduction_text] => 0
[_project_introduction_text] => 0
[project_downloads_0_name] => 0
[_project_downloads_0_name] => 0
[project_downloads_0_download] => 0
[_project_downloads_0_download] => 0
[project_downloads_0_icon] => 0
[_project_downloads_0_icon] => 0
[project_downloads_1_name] => 0
[_project_downloads_1_name] => 0
[project_downloads_1_download] => 0
[_project_downloads_1_download] => 0
[project_downloads_1_icon] => 0
[_project_downloads_1_icon] => 0
[project_downloads] => 0
[_project_downloads] => 0
[carousel_0_carousel_image] => 1
[_carousel_0_carousel_image] => 0
[carousel_0_carousel_youtube] => 1
[_carousel_0_carousel_youtube] => 0
[carousel_0_carousel_vimeo] => 1
[_carousel_0_carousel_vimeo] => 0
[carousel] => 1
[_carousel] => 0
[carousel_1_carousel_image] => 1
[_carousel_1_carousel_image] => 0
[carousel_1_carousel_youtube] => 1
[_carousel_1_carousel_youtube] => 0
[carousel_1_carousel_vimeo] => 1
[_carousel_1_carousel_vimeo] => 0
[carousel_2_carousel_image] => 1
[_carousel_2_carousel_image] => 0
[carousel_2_carousel_youtube] => 1
[_carousel_2_carousel_youtube] => 0
[carousel_2_carousel_vimeo] => 1
[_carousel_2_carousel_vimeo] => 0
[carousel_3_carousel_image] => 1
[_carousel_3_carousel_image] => 0
[carousel_3_carousel_youtube] => 1
[_carousel_3_carousel_youtube] => 0
[carousel_3_carousel_vimeo] => 1
[_carousel_3_carousel_vimeo] => 0
[carousel_4_carousel_image] => 1
[_carousel_4_carousel_image] => 0
[carousel_4_carousel_youtube] => 1
[_carousel_4_carousel_youtube] => 0
[carousel_4_carousel_vimeo] => 1
[_carousel_4_carousel_vimeo] => 0
[text_subscribed] => 2
[text_error] => 2
[text_invalid_email] => 2
[text_already_subscribed] => 2
[text_required_field_missing] => 2
[text_unsubscribed] => 2
[text_not_subscribed] => 2
[agenda_image] => 1
[_agenda_image] => 0
[agenda_end_date] => 1
[_agenda_end_date] => 0
[_yoast_wpseo_primary_organizer] => 0
[_yoast_wpseo_content_score] => 0
[text_no_lists_selected] => 2
[text_updated] => 2
[_yoast_wpseo_opengraph-title] => 2
[_yoast_wpseo_opengraph-image] => 0
[_yoast_wpseo_twitter-image] => 0
[_wp_attachment_image_alt] => 2
[_mc4wp_settings] => 3
[popup_settings] => 3
[popup_title] => 3
[_cms_nav_minihome] => 1
[_cms_nav_section] => 2
[_top_nav_excluded] => 1
[_wpml_media_duplicate] => 1
[_wpml_media_featured] => 1
[field_568ad8b818bd0] => 1
[field_568ad8e918bd1] => 1
[field_568adba32a3c3] => 1
[field_568b7df45b73e] => 1
[field_568d5ca4f1229] => 1
[field_5682ae1a34ac5] => 0
[field_5683b6a6ec8f8] => 0
[field_5683b6b7ec8f9] => 0
[field_5683b66bec8f6] => 0
[field_5683b69cec8f7] => 0
[field_5683b608ec8f5] => 0
[field_5683b714c56f2] => 0
[field_5683bbba38a14] => 0
[field_5687ddeed092c] => 1
[field_5687de5569488] => 1
[field_5687e7a6e97a5] => 1
[field_5687e7a6e865e] => 1
[field_5687e7a6ea58c] => 1
[field_5687e7a6eb4bf] => 1
[field_5687e7a6ec49b] => 1
[field_5687e7a6ed592] => 1
[field_5689adee3586a] => 1
[field_5689b31b4e59f] => 1
[field_5689b31b4f89a] => 1
[field_56819d3647ee2] => 0
[field_56850f66e8964] => 1
[field_56850fabd66eb] => 1
[field_568426c774f08] => 0
[field_56842911b8bbc] => 0
[field_5684442611de7] => 1
[header_slideshow] => 1
[header_slideshow_0_slide_image] => 1
[header_slideshow_0_slide_text] => 2
[header_slideshow_1_slide_image] => 1
[header_slideshow_1_slide_text] => 2
[hide_on_screen] => 1
[highlight_project] => 1
[highlight_project_0_highlight_project_item] => 2
[layout] => 1
[page_accordion] => 1
[page_accordion_0_downloads] => 1
[page_accordion_0_editor] => 2
[page_accordion_0_title] => 2
[page_accordion_1_downloads] => 1
[page_accordion_1_editor] => 2
[page_accordion_1_title] => 2
[page_accordion_2_downloads] => 1
[page_accordion_2_editor] => 2
[page_accordion_2_title] => 2
[page_accordion_3_downloads] => 1
[page_accordion_3_editor] => 2
[page_accordion_3_title] => 2
[page_accordion_4_downloads] => 1
[page_accordion_4_editor] => 2
[page_accordion_4_title] => 2
[page_accordion_5_downloads] => 1
[page_accordion_5_editor] => 2
[page_accordion_5_title] => 2
[page_introduction] => 2
[position] => 1
[rule] => 1
[add_arrow_links] => 1
[add_numbers] => 1
[add_quote_to_bottom] => 1
[arrow_links] => 1
[arrow_links_0_link] => 1
[arrow_links_1_link] => 1
[bottom_quote] => 1
[bottom_quote_quote] => 1
[bottom_quote_quote_arrow_position] => 1
[bottom_quote_quote_color] => 1
[bottom_quote_quote_image] => 1
[bottom_quote_quote_link] => 1
[bottom_quote_quote_push_quote_to_right] => 1
[bottom_quote_quote_small_text_right] => 2
[bottom_quote_quote_text] => 2
[bottom_quote_quote_titel] => 2
[carousel_0_carousel_credits] => 1
[carousel_0_carousel_image_credits] => 1
[carousel_0_slide_p_image] => 1
[carousel_1_carousel_credits] => 1
[carousel_1_carousel_image_credits] => 1
[carousel_1_slide_p_image] => 1
[carousel_2_carousel_credits] => 1
[carousel_2_carousel_image_credits] => 1
[carousel_2_slide_p_image] => 1
[carousel_3_carousel_credits] => 1
[carousel_3_carousel_image_credits] => 1
[carousel_3_slide_p_image] => 1
[carousel_4_carousel_credits] => 1
[carousel_4_carousel_image_credits] => 1
[carousel_5_carousel_credits] => 1
[carousel_5_carousel_image] => 1
[carousel_5_carousel_image_credits] => 1
[carousel_5_carousel_vimeo] => 1
[carousel_5_carousel_youtube] => 1
[carousel_6_carousel_credits] => 1
[carousel_6_carousel_image] => 1
[carousel_6_carousel_image_credits] => 1
[carousel_6_carousel_vimeo] => 1
[carousel_6_carousel_youtube] => 1
[carousel_7_carousel_credits] => 1
[carousel_7_carousel_image] => 1
[carousel_7_carousel_image_credits] => 1
[carousel_7_carousel_vimeo] => 1
[carousel_7_carousel_youtube] => 1
[carousel_8_carousel_credits] => 1
[carousel_8_carousel_image] => 1
[carousel_8_carousel_image_credits] => 1
[carousel_8_carousel_vimeo] => 1
[carousel_8_carousel_youtube] => 1
[carousel_9_carousel_credits] => 1
[carousel_9_carousel_image] => 1
[carousel_9_carousel_image_credits] => 1
[carousel_9_carousel_vimeo] => 1
[carousel_9_carousel_youtube] => 1
[carousel_10_carousel_credits] => 1
[carousel_10_carousel_image] => 1
[carousel_10_carousel_image_credits] => 1
[carousel_10_carousel_vimeo] => 1
[carousel_10_carousel_youtube] => 1
[carousel_11_carousel_credits] => 1
[carousel_11_carousel_image] => 1
[carousel_11_carousel_image_credits] => 1
[carousel_11_carousel_vimeo] => 1
[carousel_11_carousel_youtube] => 1
[carousel_12_carousel_credits] => 1
[carousel_12_carousel_image] => 1
[carousel_12_carousel_image_credits] => 1
[carousel_12_carousel_vimeo] => 1
[carousel_12_carousel_youtube] => 1
[carousel_13_carousel_credits] => 1
[carousel_13_carousel_image] => 1
[carousel_13_carousel_image_credits] => 1
[carousel_13_carousel_vimeo] => 1
[carousel_13_carousel_youtube] => 1
[carousel_14_carousel_credits] => 1
[carousel_14_carousel_image] => 1
[carousel_14_carousel_image_credits] => 1
[carousel_14_carousel_vimeo] => 1
[carousel_14_carousel_youtube] => 1
[carousel_15_carousel_credits] => 1
[carousel_15_carousel_image] => 1
[carousel_15_carousel_image_credits] => 1
[carousel_15_carousel_vimeo] => 1
[carousel_15_carousel_youtube] => 1
[carousel_16_carousel_credits] => 1
[carousel_16_carousel_image] => 1
[carousel_16_carousel_image_credits] => 1
[carousel_16_carousel_vimeo] => 1
[carousel_16_carousel_youtube] => 1
[carousel_17_carousel_credits] => 1
[carousel_17_carousel_image] => 1
[carousel_17_carousel_image_credits] => 1
[carousel_17_carousel_vimeo] => 1
[carousel_17_carousel_youtube] => 1
[carousel_18_carousel_credits] => 1
[carousel_18_carousel_image] => 1
[carousel_18_carousel_image_credits] => 1
[carousel_18_carousel_vimeo] => 1
[carousel_18_carousel_youtube] => 1
[carousel_19_carousel_image_credits] => 1
[completed_projects] => 1
[data_version] => 1
[email_firstmane] => 1
[email_lastname] => 1
[email_to] => 1
[enabled] => 1
[facts_repeater] => 1
[facts_repeater_0_number] => 1
[facts_repeater_0_text] => 2
[facts_repeater_1_number] => 1
[facts_repeater_1_text] => 2
[facts_repeater_2_number] => 1
[facts_repeater_2_text] => 2
[facts_repeater_3_number] => 1
[facts_repeater_3_text] => 1
[facts_repeater_4_number] => 1
[facts_repeater_4_text] => 1
[facts_repeater_5_number] => 1
[facts_repeater_5_text] => 1
[field_56a53a2f64cda] => 1
[field_56a539db64cd9] => 1
[field_56a5397864cd8] => 1
[field_56b4fb12205cf] => 1
[field_56b2132c8bdc3] => 1
[header_slideshow_0_slide_p_text] => 2
[header_slideshow_1_slide_p_text] => 2
[header_slideshow_2_slide_image] => 1
[header_slideshow_2_slide_p_text] => 2
[header_slideshow_2_slide_text] => 2
[header_slideshow_3_slide_image] => 1
[header_slideshow_3_slide_p_text] => 2
[header_slideshow_3_slide_text] => 2
[header_slideshow_4_slide_image] => 1
[header_slideshow_4_slide_p_text] => 2
[header_slideshow_4_slide_text] => 2
[header_slideshow_5_slide_image] => 1
[header_slideshow_5_slide_p_text] => 2
[header_slideshow_5_slide_text] => 2
[header_slideshow_6_slide_image] => 1
[header_slideshow_6_slide_p_text] => 2
[header_slideshow_6_slide_text] => 2
[header_slideshow_7_slide_image] => 1
[header_slideshow_7_slide_p_text] => 2
[header_slideshow_8_slide_image] => 1
[header_slideshow_8_slide_p_text] => 2
[header_slideshow_9_slide_image] => 1
[header_slideshow_9_slide_p_text] => 2
[header_slideshow_10_slide_image] => 1
[header_slideshow_10_slide_p_text] => 2
[header_slideshow_11_slide_image] => 1
[header_slideshow_11_slide_p_text] => 2
[header_slideshow_12_slide_image] => 1
[header_slideshow_12_slide_p_text] => 2
[header_slideshow_13_slide_image] => 1
[header_slideshow_13_slide_p_text] => 2
[header_slideshow_14_slide_image] => 1
[header_slideshow_14_slide_p_text] => 2
[hide_title] => 1
[highlight_project_1_highlight_project_item] => 2
[highlight_project_2_highlight_project_item] => 2
[highlight_project_3_highlight_project_item] => 2
[highlight_project_4_highlight_project_item] => 2
[highlight_project_5_highlight_project_item] => 2
[highlight_project_6_highlight_project_item] => 2
[highlight_project_7_highlight_project_item] => 2
[link_show] => 1
[link_text] => 2
[link_url] => 1
[middle_quote] => 1
[middle_quote_quote] => 1
[middle_quote_quote_arrow_position] => 1
[middle_quote_quote_color] => 1
[middle_quote_quote_image] => 1
[middle_quote_quote_link] => 1
[middle_quote_quote_push_quote_to_right] => 1
[middle_quote_quote_small_text_right] => 2
[middle_quote_quote_text] => 2
[middle_quote_quote_titel] => 2
[page_accordion_0_downloads_0_download] => 0
[page_accordion_0_downloads_0_icon] => 0
[page_accordion_0_downloads_0_name] => 0
[page_accordion_0_downloads_1_download] => 0
[page_accordion_0_downloads_1_icon] => 0
[page_accordion_0_downloads_1_name] => 0
[page_accordion_0_downloads_2_download] => 0
[page_accordion_0_downloads_2_icon] => 0
[page_accordion_0_downloads_2_name] => 0
[page_accordion_0_downloads_3_download] => 0
[page_accordion_0_downloads_3_icon] => 0
[page_accordion_0_downloads_3_name] => 0
[page_accordion_0_red] => 1
[page_accordion_1_downloads_0_download] => 0
[page_accordion_1_downloads_0_icon] => 0
[page_accordion_1_downloads_0_name] => 0
[page_accordion_1_downloads_1_download] => 0
[page_accordion_1_downloads_1_icon] => 0
[page_accordion_1_downloads_1_name] => 0
[page_accordion_1_downloads_2_download] => 0
[page_accordion_1_downloads_2_icon] => 0
[page_accordion_1_downloads_2_name] => 0
[page_accordion_1_downloads_3_download] => 0
[page_accordion_1_downloads_3_icon] => 0
[page_accordion_1_downloads_3_name] => 0
[page_accordion_1_red] => 1
[page_accordion_2_downloads_0_download] => 0
[page_accordion_2_downloads_0_icon] => 0
[page_accordion_2_downloads_0_name] => 0
[page_accordion_2_downloads_1_download] => 0
[page_accordion_2_downloads_1_icon] => 0
[page_accordion_2_downloads_1_name] => 0
[page_accordion_2_downloads_2_download] => 0
[page_accordion_2_downloads_2_icon] => 0
[page_accordion_2_downloads_2_name] => 0
[page_accordion_2_downloads_3_download] => 0
[page_accordion_2_downloads_3_icon] => 0
[page_accordion_2_downloads_3_name] => 0
[page_accordion_2_downloads_4_download] => 0
[page_accordion_2_downloads_4_icon] => 0
[page_accordion_2_downloads_4_name] => 0
[page_accordion_2_downloads_5_download] => 0
[page_accordion_2_downloads_5_icon] => 0
[page_accordion_2_downloads_5_name] => 0
[page_accordion_2_red] => 1
[page_accordion_3_downloads_0_download] => 0
[page_accordion_3_downloads_0_icon] => 0
[page_accordion_3_downloads_0_name] => 0
[page_accordion_3_downloads_1_download] => 0
[page_accordion_3_downloads_1_icon] => 0
[page_accordion_3_downloads_1_name] => 0
[page_accordion_3_downloads_2_download] => 0
[page_accordion_3_downloads_2_icon] => 0
[page_accordion_3_downloads_2_name] => 0
[page_accordion_3_downloads_3_download] => 0
[page_accordion_3_downloads_3_icon] => 0
[page_accordion_3_downloads_3_name] => 0
[page_accordion_3_downloads_4_download] => 0
[page_accordion_3_downloads_4_icon] => 0
[page_accordion_3_downloads_4_name] => 0
[page_accordion_3_downloads_5_download] => 0
[page_accordion_3_downloads_5_icon] => 0
[page_accordion_3_downloads_5_name] => 0
[page_accordion_3_downloads_6_download] => 0
[page_accordion_3_downloads_6_icon] => 0
[page_accordion_3_downloads_6_name] => 0
[page_accordion_3_downloads_7_download] => 0
[page_accordion_3_downloads_7_icon] => 0
[page_accordion_3_downloads_7_name] => 0
[page_accordion_3_red] => 1
[page_accordion_4_downloads_0_download] => 1
[page_accordion_4_downloads_0_icon] => 1
[page_accordion_4_downloads_0_name] => 1
[page_accordion_4_downloads_1_download] => 1
[page_accordion_4_downloads_1_icon] => 1
[page_accordion_4_downloads_1_name] => 1
[page_accordion_4_downloads_2_download] => 0
[page_accordion_4_downloads_2_icon] => 0
[page_accordion_4_downloads_2_name] => 0
[page_accordion_4_downloads_3_download] => 0
[page_accordion_4_downloads_3_icon] => 0
[page_accordion_4_downloads_3_name] => 0
[page_accordion_4_downloads_4_download] => 0
[page_accordion_4_downloads_4_icon] => 0
[page_accordion_4_downloads_4_name] => 0
[page_accordion_4_downloads_5_download] => 0
[page_accordion_4_downloads_5_icon] => 0
[page_accordion_4_downloads_5_name] => 0
[page_accordion_4_downloads_6_download] => 0
[page_accordion_4_downloads_6_icon] => 0
[page_accordion_4_downloads_6_name] => 0
[page_accordion_4_downloads_7_download] => 0
[page_accordion_4_downloads_7_icon] => 0
[page_accordion_4_downloads_7_name] => 0
[page_accordion_4_red] => 1
[page_accordion_5_downloads_0_download] => 1
[page_accordion_5_downloads_0_icon] => 1
[page_accordion_5_downloads_0_name] => 1
[page_accordion_5_downloads_1_download] => 0
[page_accordion_5_downloads_1_icon] => 0
[page_accordion_5_downloads_1_name] => 0
[page_accordion_5_downloads_2_download] => 0
[page_accordion_5_downloads_2_icon] => 0
[page_accordion_5_downloads_2_name] => 0
[page_accordion_5_downloads_3_download] => 0
[page_accordion_5_downloads_3_icon] => 0
[page_accordion_5_downloads_3_name] => 0
[page_accordion_5_downloads_4_download] => 0
[page_accordion_5_downloads_4_icon] => 0
[page_accordion_5_downloads_4_name] => 0
[page_accordion_5_downloads_5_download] => 0
[page_accordion_5_downloads_5_icon] => 0
[page_accordion_5_downloads_5_name] => 0
[page_accordion_5_downloads_6_download] => 0
[page_accordion_5_downloads_6_icon] => 0
[page_accordion_5_downloads_6_name] => 0
[page_accordion_5_red] => 1
[page_accordion_6_downloads] => 1
[page_accordion_6_downloads_0_download] => 1
[page_accordion_6_downloads_0_icon] => 1
[page_accordion_6_downloads_0_name] => 1
[page_accordion_6_editor] => 2
[page_accordion_6_red] => 1
[page_accordion_6_title] => 2
[page_accordion_7_downloads] => 1
[page_accordion_7_downloads_0_download] => 0
[page_accordion_7_downloads_0_icon] => 0
[page_accordion_7_downloads_0_name] => 0
[page_accordion_7_downloads_1_download] => 0
[page_accordion_7_downloads_1_icon] => 0
[page_accordion_7_downloads_1_name] => 0
[page_accordion_7_downloads_2_download] => 0
[page_accordion_7_downloads_2_icon] => 0
[page_accordion_7_downloads_2_name] => 0
[page_accordion_7_downloads_3_download] => 0
[page_accordion_7_downloads_3_icon] => 0
[page_accordion_7_downloads_3_name] => 0
[page_accordion_7_downloads_4_download] => 0
[page_accordion_7_downloads_4_icon] => 0
[page_accordion_7_downloads_4_name] => 0
[page_accordion_7_downloads_5_download] => 0
[page_accordion_7_downloads_5_icon] => 0
[page_accordion_7_downloads_5_name] => 0
[page_accordion_7_downloads_6_download] => 0
[page_accordion_7_downloads_6_icon] => 0
[page_accordion_7_downloads_6_name] => 0
[page_accordion_7_downloads_7_download] => 0
[page_accordion_7_downloads_7_icon] => 0
[page_accordion_7_downloads_7_name] => 0
[page_accordion_7_editor] => 2
[page_accordion_7_red] => 1
[page_accordion_7_title] => 2
[page_accordion_8_downloads] => 1
[page_accordion_8_downloads_0_download] => 0
[page_accordion_8_downloads_0_icon] => 0
[page_accordion_8_downloads_0_name] => 0
[page_accordion_8_downloads_1_download] => 0
[page_accordion_8_downloads_1_icon] => 0
[page_accordion_8_downloads_1_name] => 0
[page_accordion_8_downloads_2_download] => 0
[page_accordion_8_downloads_2_icon] => 0
[page_accordion_8_downloads_2_name] => 0
[page_accordion_8_downloads_3_download] => 0
[page_accordion_8_downloads_3_icon] => 0
[page_accordion_8_downloads_3_name] => 0
[page_accordion_8_downloads_4_download] => 0
[page_accordion_8_downloads_4_icon] => 0
[page_accordion_8_downloads_4_name] => 0
[page_accordion_8_downloads_5_download] => 0
[page_accordion_8_downloads_5_icon] => 0
[page_accordion_8_downloads_5_name] => 0
[page_accordion_8_downloads_6_download] => 0
[page_accordion_8_downloads_6_icon] => 0
[page_accordion_8_downloads_6_name] => 0
[page_accordion_8_downloads_7_download] => 0
[page_accordion_8_downloads_7_icon] => 0
[page_accordion_8_downloads_7_name] => 0
[page_accordion_8_editor] => 2
[page_accordion_8_red] => 1
[page_accordion_8_title] => 2
[page_accordion_9_downloads] => 1
[page_accordion_9_downloads_0_download] => 0
[page_accordion_9_downloads_0_icon] => 0
[page_accordion_9_downloads_0_name] => 0
[page_accordion_9_downloads_1_download] => 1
[page_accordion_9_downloads_1_icon] => 1
[page_accordion_9_downloads_1_name] => 1
[page_accordion_9_downloads_2_download] => 1
[page_accordion_9_downloads_2_icon] => 1
[page_accordion_9_downloads_2_name] => 1
[page_accordion_9_downloads_3_download] => 1
[page_accordion_9_downloads_3_icon] => 1
[page_accordion_9_downloads_3_name] => 1
[page_accordion_9_downloads_4_download] => 1
[page_accordion_9_downloads_4_icon] => 1
[page_accordion_9_downloads_4_name] => 1
[page_accordion_9_editor] => 2
[page_accordion_9_red] => 1
[page_accordion_9_title] => 2
[page_accordion_10_downloads] => 1
[page_accordion_10_downloads_0_download] => 1
[page_accordion_10_downloads_0_icon] => 1
[page_accordion_10_downloads_0_name] => 1
[page_accordion_10_downloads_1_download] => 1
[page_accordion_10_downloads_1_icon] => 1
[page_accordion_10_downloads_1_name] => 1
[page_accordion_10_downloads_2_download] => 1
[page_accordion_10_downloads_2_icon] => 1
[page_accordion_10_downloads_2_name] => 1
[page_accordion_10_editor] => 1
[page_accordion_10_red] => 1
[page_accordion_10_title] => 1
[partners] => 1
[partners_0_partner_link] => 1
[partners_0_partner_logo] => 1
[partners_0_partner_name] => 1
[partners_1_partner_link] => 1
[partners_1_partner_logo] => 1
[partners_1_partner_name] => 1
[partners_2_partner_link] => 1
[partners_2_partner_logo] => 1
[partners_2_partner_name] => 1
[partners_3_partner_link] => 1
[partners_3_partner_logo] => 1
[partners_3_partner_name] => 1
[partners_4_partner_link] => 1
[partners_4_partner_logo] => 1
[partners_4_partner_name] => 1
[partners_5_partner_link] => 1
[partners_5_partner_logo] => 1
[partners_5_partner_name] => 1
[partners_6_partner_link] => 1
[partners_6_partner_logo] => 1
[partners_6_partner_name] => 1
[partners_7_partner_link] => 0
[_header_slideshow] => 1
[_header_slideshow_0_slide_image] => 1
[_header_slideshow_0_slide_text] => 2
[_header_slideshow_1_slide_image] => 1
[_header_slideshow_1_slide_text] => 2
[_page_accordion] => 0
[_page_accordion_0_downloads] => 0
[_page_accordion_0_editor] => 0
[_page_accordion_0_title] => 0
[_page_accordion_1_downloads] => 0
[_page_accordion_1_editor] => 0
[_page_accordion_1_title] => 0
[_page_accordion_2_downloads] => 0
[_page_accordion_2_editor] => 0
[_page_accordion_2_title] => 0
[_page_accordion_3_downloads] => 0
[_page_accordion_3_editor] => 0
[_page_accordion_3_title] => 0
[_page_accordion_4_downloads] => 0
[_page_accordion_4_editor] => 0
[_page_accordion_4_title] => 0
[_page_accordion_5_downloads] => 0
[_page_accordion_5_editor] => 0
[_page_accordion_5_title] => 0
[_page_introduction] => 0
[_carousel_6_carousel_image] => 0
[_carousel_7_carousel_image] => 0
[_carousel_8_carousel_image] => 0
[_carousel_9_carousel_image] => 0
[_carousel_10_carousel_image] => 0
[_carousel_11_carousel_image] => 0
[_carousel_12_carousel_image] => 0
[_header_slideshow_2_slide_image] => 1
[_header_slideshow_3_slide_image] => 1
[speech_bubble_header_quote_small_text_right] => 2
[show_quote] => 1
[speech_bubble_header_quote_image] => 1
[speech_bubble_header_quote_titel] => 2
[speech_bubble_header_quote_color] => 1
[speech_bubble_header_quote_text] => 2
[speech_bubble_header_quote_link] => 1
[speech_bubble_header_quote_arrow_position] => 1
[speech_bubble_header_quote_push_quote_to_right] => 1
[speech_bubble_header_quote] => 1
[speech_bubble_header] => 1
[small_link_text] => 2
[quote_under_map_quote_text] => 2
[_wp_old_date] => 0
[quote_above_map_quote_image] => 1
[quote_above_map_quote_text] => 2
[quote_above_map_quote_small_text_right] => 2
[quote_under_map_quote_image] => 1
[quote_under_map_quote_small_text_right] => 2
[quote_above_map_quote_titel] => 2
[quote_above_map_quote_color] => 1
[quote_above_map_quote_link] => 1
[quote_above_map_quote_arrow_position] => 1
[quote_above_map_quote] => 1
[quote_above_map] => 1
[quote_under_map_quote_titel] => 2
[quote_under_map_quote_color] => 1
[quote_under_map_quote_link] => 1
[quote_under_map_quote_arrow_position] => 1
[quote_under_map_quote] => 1
[quote_under_map] => 1
[quote_above_map_quote_push_quote_to_right] => 1
[quote_under_map_quote_push_quote_to_right] => 1
[show_quote_above_map] => 1
[show_quote_under_map] => 1
[show_partner_block] => 1
[_highlight_project] => 1
[_highlight_project_0_highlight_project_item] => 0
[_header_slideshow_2_slide_text] => 2
[_header_slideshow_3_slide_text] => 2
[_link_url] => 1
[_link_text] => 2
[_link_show] => 0
[_yoast_wpseo_focuskw_text_input] => 0
[_yoast_wpseo_linkdex] => 0
[_header_slideshow_4_slide_image] => 1
[_header_slideshow_4_slide_text] => 2
[_header_slideshow_5_slide_image] => 1
[_header_slideshow_5_slide_text] => 1
[_show_quote] => 0
[_speech_bubble_header_quote_image] => 1
[_speech_bubble_header_quote_titel] => 2
[_speech_bubble_header_quote_color] => 1
[_speech_bubble_header_quote_text] => 2
[_speech_bubble_header_quote_small_text_right] => 1
[_speech_bubble_header_quote_link] => 2
[_speech_bubble_header_quote_arrow_position] => 1
[_speech_bubble_header_quote] => 0
[_speech_bubble_header] => 1
[_small_link_text] => 2
[_quote_above_map_quote_image] => 1
[_quote_above_map_quote_titel] => 0
[_quote_above_map_quote_color] => 0
[_quote_above_map_quote_text] => 0
[_quote_above_map_quote_small_text_right] => 0
[_quote_above_map_quote_link] => 0
[_quote_above_map_quote_arrow_position] => 0
[_quote_above_map_quote] => 1
[_quote_above_map] => 1
[_quote_under_map_quote_image] => 1
[_quote_under_map_quote_titel] => 1
[_quote_under_map_quote_color] => 1
[_quote_under_map_quote_text] => 1
[_quote_under_map_quote_small_text_right] => 1
[_quote_under_map_quote_link] => 1
[_quote_under_map_quote_arrow_position] => 1
[_quote_under_map_quote] => 1
[_quote_under_map] => 0
[_partners_0_partner_logo] => 0
[_partners_0_partner_name] => 0
[_partners_0_partner_link] => 0
[_partners_1_partner_logo] => 1
[_partners_1_partner_name] => 1
[_partners_1_partner_link] => 1
[_partners_2_partner_logo] => 1
[_partners_2_partner_name] => 0
[_partners_2_partner_link] => 1
[_partners_3_partner_logo] => 1
[_partners_3_partner_name] => 0
[_partners_3_partner_link] => 0
[_partners_4_partner_logo] => 0
[_partners_4_partner_name] => 0
[_partners_4_partner_link] => 0
[_partners] => 0
[_speech_bubble_header_quote_push_quote_to_right] => 0
[_quote_above_map_quote_push_quote_to_right] => 0
[_quote_under_map_quote_push_quote_to_right] => 0
[_show_quote_above_map] => 0
[_show_quote_under_map] => 0
[_show_partner_block] => 0
[_header_slideshow_0_slide_p_text] => 0
[_header_slideshow_1_slide_p_text] => 0
[_header_slideshow_2_slide_p_text] => 0
[_header_slideshow_3_slide_p_text] => 2
[_header_slideshow_4_slide_p_text] => 2
[_header_slideshow_5_slide_p_text] => 2
[_header_slideshow_6_slide_image] => 0
[_header_slideshow_6_slide_p_text] => 2
[_header_slideshow_7_slide_image] => 1
[_header_slideshow_7_slide_p_text] => 0
[_header_slideshow_8_slide_image] => 1
[_header_slideshow_8_slide_p_text] => 0
[_header_slideshow_9_slide_image] => 1
[_header_slideshow_9_slide_p_text] => 0
[_header_slideshow_10_slide_image] => 1
[_header_slideshow_10_slide_p_text] => 2
[_header_slideshow_11_slide_image] => 1
[_header_slideshow_11_slide_p_text] => 1
[_highlight_project_1_highlight_project_item] => 0
[_highlight_project_2_highlight_project_item] => 0
[_header_slideshow_12_slide_image] => 1
[_header_slideshow_12_slide_p_text] => 0
[_header_slideshow_13_slide_image] => 1
[_header_slideshow_13_slide_p_text] => 0
[_highlight_project_3_highlight_project_item] => 0
[_highlight_project_4_highlight_project_item] => 0
[_wpml_word_count] => 0
[_wpml_post_translation_editor_native] => 0
[_yoast_wpseo_estimated-reading-time-minutes] => 0
[_yoast_wpseo_wordproof_timestamp] => 0
[_hide_title] => 0
[_add_arrow_links] => 0
[_add_quote_to_bottom] => 0
[_bottom_quote_quote_image] => 0
[_bottom_quote_quote_titel] => 0
[_bottom_quote_quote_color] => 0
[_bottom_quote_quote_text] => 0
[_bottom_quote_quote_small_text_right] => 0
[_bottom_quote_quote_link] => 0
[_bottom_quote_quote_arrow_position] => 0
[_bottom_quote_quote_push_quote_to_right] => 0
[_bottom_quote_quote] => 0
[_bottom_quote] => 0
[related_agenda_0_highlight_project_item] => 0
[related_project_0_highlight_project_item] => 0
[related_project_1_highlight_project_item] => 0
[featured_projects_0_category] => 2
[featured_projects_0_project] => 1
[featured_projects_1_category] => 2
[featured_projects_1_project] => 1
[featured_projects_2_category] => 2
[featured_projects_2_project] => 1
[featured_projects] => 1
[projects_overview_quote_quote_image] => 1
[projects_overview_quote_quote_titel] => 2
[projects_overview_quote_quote_color] => 1
[projects_overview_quote_quote_text] => 2
[projects_overview_quote_quote_small_text_right] => 2
[projects_overview_quote_quote_link] => 1
[projects_overview_quote_quote_arrow_position] => 1
[projects_overview_quote_quote_push_quote_to_right] => 1
[projects_overview_quote_quote] => 1
[projects_overview_quote] => 1
[project_email] => 1
[header_p_slideshow_0_slide_p_image] => 1
[header_p_slideshow_0_slide_p_text] => 2
[header_p_slideshow_1_slide_p_image] => 1
[header_p_slideshow_1_slide_p_text] => 2
[header_p_slideshow_2_slide_p_image] => 1
[header_p_slideshow_2_slide_p_text] => 2
[header_p_slideshow_3_slide_p_image] => 1
[header_p_slideshow_3_slide_p_text] => 2
[header_p_slideshow_4_slide_p_image] => 1
[header_p_slideshow_4_slide_p_text] => 2
[header_p_slideshow_5_slide_p_image] => 1
[header_p_slideshow_5_slide_p_text] => 2
[header_p_slideshow] => 1
[custom-fields_readonly_config] => Array
[custom_fields_translation_custom] => Array
[custom_fields_translation_custom_readonly] => Array
[doc_translation_method] => ATE
[__custom_types_readonly_config_prev] => Array
[custom_types_readonly_config] => Array
[__custom_fields_readonly_config_prev] => Array
[0] => title
[1] => description
[2] => keywords
[3] => _edit_last
[4] => _edit_lock
[5] => _wp_page_template
[6] => _wp_attachment_metadata
[7] => original_post_id
[8] => _wpml_original_post_id
[9] => _wp_old_slug
[10] => _icl_translator_note
[11] => _alp_processed
[12] => _pingme
[13] => _encloseme
[14] => _icl_lang_duplicate_of
[15] => _thumbnail_id
[16] => _wp_attached_file
[17] => _wp_attachment_image_alt
[18] => _mc4wp_settings
[19] => text_subscribed
[20] => text_error
[21] => text_invalid_email
[22] => text_already_subscribed
[23] => text_required_field_missing
[24] => text_unsubscribed
[25] => text_not_subscribed
[26] => popup_settings
[27] => popup_title
[28] => _yoast_wpseo_title
[29] => _yoast_wpseo_bctitle
[30] => _yoast_wpseo_metadesc
[31] => _yoast_wpseo_metakeywords
[32] => _yoast_wpseo_focuskw
[33] => _yoast_wpseo_meta-robots-noindex
[34] => _yoast_wpseo_meta-robots-nofollow
[35] => _yoast_wpseo_meta-robots-adv
[36] => _yoast_wpseo_canonical
[37] => _yoast_wpseo_redirect
[38] => _yoast_wpseo_opengraph-description
[39] => _yoast_wpseo_google-plus-description
[40] => _yoast_wpseo_twitter-title
[41] => _yoast_wpseo_twitter-description
[42] => _cms_nav_minihome
[43] => _cms_nav_section
[44] => _top_nav_excluded
[45] => _wpml_media_duplicate
[46] => _wpml_media_featured
[custom_fields_readonly_config] => Array
[0] => title
[1] => description
[2] => keywords
[3] => _edit_last
[4] => _edit_lock
[9] => _wp_old_slug
[12] => _pingme
[13] => _encloseme
[20] => text_error
[27] => popup_title
[custom-types_readonly_config] => Array
[attachment] => 1
[wp_block] => 1
[wp_navigation] => 1
[wp_template] => 1
[wp_template_part] => 1
[mc4wp-form] => 1
[popup] => 1
[taxonomies_readonly_config] => Array
[translation_priority] => 1
[wp_theme] => 0
[__custom_term_fields_readonly_config_prev] => Array
[custom_term_fields_readonly_config] => Array
[post_translation_editor_native_for_post_type] => Array
[page] =>
[acf-field-group] => 1
[custom_fields_unlocked_config] => Array
[agenda_image] => 0
[agenda_organizer] => 0
[agenda_start_date] => 0
[carousel] => 0
[carousel_0_carousel_image] => 0
[carousel_0_carousel_vimeo] => 0
[carousel_0_carousel_youtube] => 0
[carousel_1_carousel_image] => 0
[carousel_1_carousel_vimeo] => 0
[carousel_1_carousel_youtube] => 0
[carousel_2_carousel_image] => 0
[carousel_2_carousel_vimeo] => 0
[carousel_2_carousel_youtube] => 0
[carousel_3_carousel_image] => 0
[carousel_3_carousel_vimeo] => 0
[carousel_3_carousel_youtube] => 0
[field_568ad8b818bd0] => 0
[field_568ad8e918bd1] => 0
[field_568adba32a3c3] => 0
[field_568b7df45b73e] => 0
[field_568d5ca4f1229] => 0
[field_5687ddeed092c] => 0
[field_5687de5569488] => 0
[field_5687e7a6e97a5] => 0
[field_5687e7a6e865e] => 0
[field_5687e7a6ea58c] => 0
[field_5687e7a6eb4bf] => 0
[field_5687e7a6ec49b] => 0
[field_5687e7a6ed592] => 0
[field_5689adee3586a] => 0
[field_5689b31b4e59f] => 0
[field_5689b31b4f89a] => 0
[field_56850f66e8964] => 0
[field_56850fabd66eb] => 0
[field_5684442611de7] => 0
[header_slideshow] => 0
[header_slideshow_0_slide_image] => 0
[header_slideshow_0_slide_text] => 0
[header_slideshow_1_slide_image] => 0
[header_slideshow_1_slide_text] => 0
[hide_on_screen] => 0
[highlight_project] => 0
[highlight_project_0_highlight_project_item] => 0
[layout] => 0
[page_accordion] => 0
[page_accordion_0_downloads] => 0
[page_accordion_0_editor] => 0
[page_accordion_0_title] => 0
[page_accordion_1_downloads] => 0
[page_accordion_1_editor] => 0
[page_accordion_1_title] => 0
[page_accordion_2_downloads] => 0
[page_accordion_2_editor] => 0
[page_accordion_2_title] => 0
[page_accordion_3_downloads] => 0
[page_accordion_3_editor] => 0
[page_accordion_3_title] => 0
[page_accordion_4_downloads] => 0
[page_accordion_4_editor] => 0
[page_accordion_4_title] => 0
[page_accordion_5_downloads] => 0
[page_accordion_5_editor] => 0
[page_accordion_5_title] => 0
[page_introduction] => 0
[position] => 0
[project_image] => 0
[project_link] => 0
[project_time] => 0
[project_who] => 0
[related_agenda] => 0
[related_news] => 0
[related_project] => 0
[related_project_0_related_project_item] => 0
[rule] => 0
[add_arrow_links] => 0
[add_numbers] => 0
[add_quote_to_bottom] => 0
[agenda_banner] => 0
[agenda_end_date] => 0
[agenda_exceptions] => 0
[agenda_locatie] => 0
[agenda_time] => 0
[agenda_who] => 0
[arrow_links] => 0
[arrow_links_0_link] => 0
[arrow_links_1_link] => 0
[bottom_quote] => 0
[bottom_quote_quote] => 0
[bottom_quote_quote_arrow_position] => 0
[bottom_quote_quote_color] => 0
[bottom_quote_quote_image] => 0
[bottom_quote_quote_link] => 0
[bottom_quote_quote_push_quote_to_right] => 0
[bottom_quote_quote_small_text_right] => 0
[bottom_quote_quote_text] => 0
[bottom_quote_quote_titel] => 0
[carousel_0_carousel_credits] => 0
[carousel_0_carousel_image_credits] => 0
[carousel_0_slide_p_image] => 0
[carousel_1_carousel_credits] => 0
[carousel_1_carousel_image_credits] => 0
[carousel_1_slide_p_image] => 0
[carousel_2_carousel_credits] => 0
[carousel_2_carousel_image_credits] => 0
[carousel_2_slide_p_image] => 0
[carousel_3_carousel_credits] => 0
[carousel_3_carousel_image_credits] => 0
[carousel_3_slide_p_image] => 0
[carousel_4_carousel_credits] => 0
[carousel_4_carousel_image] => 0
[carousel_4_carousel_image_credits] => 0
[carousel_4_carousel_vimeo] => 0
[carousel_4_carousel_youtube] => 0
[carousel_5_carousel_credits] => 0
[carousel_5_carousel_image] => 0
[carousel_5_carousel_image_credits] => 0
[carousel_5_carousel_vimeo] => 0
[carousel_5_carousel_youtube] => 0
[carousel_6_carousel_credits] => 0
[carousel_6_carousel_image] => 0
[carousel_6_carousel_image_credits] => 0
[carousel_6_carousel_vimeo] => 0
[carousel_6_carousel_youtube] => 0
[carousel_7_carousel_credits] => 0
[carousel_7_carousel_image] => 0
[carousel_7_carousel_image_credits] => 0
[carousel_7_carousel_vimeo] => 0
[carousel_7_carousel_youtube] => 0
[carousel_8_carousel_credits] => 0
[carousel_8_carousel_image] => 0
[carousel_8_carousel_image_credits] => 0
[carousel_8_carousel_vimeo] => 0
[carousel_8_carousel_youtube] => 0
[carousel_9_carousel_credits] => 0
[carousel_9_carousel_image] => 0
[carousel_9_carousel_image_credits] => 0
[carousel_9_carousel_vimeo] => 0
[carousel_9_carousel_youtube] => 0
[carousel_10_carousel_credits] => 0
[carousel_10_carousel_image] => 0
[carousel_10_carousel_image_credits] => 0
[carousel_10_carousel_vimeo] => 0
[carousel_10_carousel_youtube] => 0
[carousel_11_carousel_credits] => 0
[carousel_11_carousel_image] => 0
[carousel_11_carousel_image_credits] => 0
[carousel_11_carousel_vimeo] => 0
[carousel_11_carousel_youtube] => 0
[carousel_12_carousel_credits] => 0
[carousel_12_carousel_image] => 0
[carousel_12_carousel_image_credits] => 0
[carousel_12_carousel_vimeo] => 0
[carousel_12_carousel_youtube] => 0
[carousel_13_carousel_credits] => 0
[carousel_13_carousel_image] => 0
[carousel_13_carousel_image_credits] => 0
[carousel_13_carousel_vimeo] => 0
[carousel_13_carousel_youtube] => 0
[carousel_14_carousel_credits] => 0
[carousel_14_carousel_image] => 0
[carousel_14_carousel_image_credits] => 0
[carousel_14_carousel_vimeo] => 0
[carousel_14_carousel_youtube] => 0
[carousel_15_carousel_credits] => 0
[carousel_15_carousel_image] => 0
[carousel_15_carousel_image_credits] => 0
[carousel_15_carousel_vimeo] => 0
[carousel_15_carousel_youtube] => 0
[carousel_16_carousel_credits] => 0
[carousel_16_carousel_image] => 0
[carousel_16_carousel_image_credits] => 0
[carousel_16_carousel_vimeo] => 0
[carousel_16_carousel_youtube] => 0
[carousel_17_carousel_credits] => 0
[carousel_17_carousel_image] => 0
[carousel_17_carousel_image_credits] => 0
[carousel_17_carousel_vimeo] => 0
[carousel_17_carousel_youtube] => 0
[carousel_18_carousel_credits] => 0
[carousel_18_carousel_image] => 0
[carousel_18_carousel_image_credits] => 0
[carousel_18_carousel_vimeo] => 0
[carousel_18_carousel_youtube] => 0
[carousel_19_carousel_image_credits] => 0
[completed_projects] => 0
[data_version] => 0
[email_firstmane] => 0
[email_lastname] => 0
[email_to] => 0
[enabled] => 0
[facts_repeater] => 0
[facts_repeater_0_number] => 0
[facts_repeater_0_text] => 0
[facts_repeater_1_number] => 0
[facts_repeater_1_text] => 0
[facts_repeater_2_number] => 0
[facts_repeater_2_text] => 0
[facts_repeater_3_number] => 0
[facts_repeater_3_text] => 0
[facts_repeater_4_number] => 0
[facts_repeater_4_text] => 0
[facts_repeater_5_number] => 0
[facts_repeater_5_text] => 0
[field_56a53a2f64cda] => 0
[field_56a539db64cd9] => 0
[field_56a5397864cd8] => 0
[field_56b4fb12205cf] => 0
[field_56b2132c8bdc3] => 0
[header_slideshow_0_slide_p_text] => 0
[header_slideshow_1_slide_p_text] => 0
[header_slideshow_2_slide_image] => 0
[header_slideshow_2_slide_p_text] => 0
[header_slideshow_2_slide_text] => 0
[header_slideshow_3_slide_image] => 0
[header_slideshow_3_slide_p_text] => 0
[header_slideshow_3_slide_text] => 0
[header_slideshow_4_slide_image] => 0
[header_slideshow_4_slide_p_text] => 0
[header_slideshow_4_slide_text] => 0
[header_slideshow_5_slide_image] => 0
[header_slideshow_5_slide_p_text] => 0
[header_slideshow_5_slide_text] => 0
[header_slideshow_6_slide_image] => 0
[header_slideshow_6_slide_p_text] => 0
[header_slideshow_6_slide_text] => 0
[header_slideshow_7_slide_image] => 0
[header_slideshow_7_slide_p_text] => 0
[header_slideshow_8_slide_image] => 0
[header_slideshow_8_slide_p_text] => 0
[header_slideshow_9_slide_image] => 0
[header_slideshow_9_slide_p_text] => 0
[header_slideshow_10_slide_image] => 0
[header_slideshow_10_slide_p_text] => 0
[header_slideshow_11_slide_image] => 0
[header_slideshow_11_slide_p_text] => 0
[header_slideshow_12_slide_image] => 0
[header_slideshow_12_slide_p_text] => 0
[header_slideshow_13_slide_image] => 0
[header_slideshow_13_slide_p_text] => 0
[header_slideshow_14_slide_image] => 0
[header_slideshow_14_slide_p_text] => 0
[hide_title] => 0
[highlight_project_1_highlight_project_item] => 0
[highlight_project_2_highlight_project_item] => 0
[highlight_project_3_highlight_project_item] => 0
[highlight_project_4_highlight_project_item] => 0
[highlight_project_5_highlight_project_item] => 0
[highlight_project_6_highlight_project_item] => 0
[highlight_project_7_highlight_project_item] => 0
[link_show] => 0
[link_text] => 0
[link_url] => 0
[middle_quote] => 0
[middle_quote_quote] => 0
[middle_quote_quote_arrow_position] => 0
[middle_quote_quote_color] => 0
[middle_quote_quote_image] => 0
[middle_quote_quote_link] => 0
[middle_quote_quote_push_quote_to_right] => 0
[middle_quote_quote_small_text_right] => 0
[middle_quote_quote_text] => 0
[middle_quote_quote_titel] => 0
[news_image] => 0
[page_accordion_0_red] => 0
[page_accordion_1_red] => 0
[page_accordion_2_red] => 0
[page_accordion_3_red] => 0
[page_accordion_4_downloads_0_download] => 0
[page_accordion_4_downloads_0_icon] => 0
[page_accordion_4_downloads_0_name] => 0
[page_accordion_4_downloads_1_download] => 0
[page_accordion_4_downloads_1_icon] => 0
[page_accordion_4_downloads_1_name] => 0
[page_accordion_4_red] => 0
[page_accordion_5_downloads_0_download] => 0
[page_accordion_5_downloads_0_icon] => 0
[page_accordion_5_downloads_0_name] => 0
[page_accordion_5_red] => 0
[page_accordion_6_downloads] => 0
[page_accordion_6_downloads_0_download] => 0
[page_accordion_6_downloads_0_icon] => 0
[page_accordion_6_downloads_0_name] => 0
[page_accordion_6_editor] => 0
[page_accordion_6_red] => 0
[page_accordion_6_title] => 0
[page_accordion_7_downloads] => 0
[page_accordion_7_editor] => 0
[page_accordion_7_red] => 0
[page_accordion_7_title] => 0
[page_accordion_8_downloads] => 0
[page_accordion_8_editor] => 0
[page_accordion_8_red] => 0
[page_accordion_8_title] => 0
[page_accordion_9_downloads] => 0
[page_accordion_9_downloads_1_download] => 0
[page_accordion_9_downloads_1_icon] => 0
[page_accordion_9_downloads_1_name] => 0
[page_accordion_9_downloads_2_download] => 0
[page_accordion_9_downloads_2_icon] => 0
[page_accordion_9_downloads_2_name] => 0
[page_accordion_9_downloads_3_download] => 0
[page_accordion_9_downloads_3_icon] => 0
[page_accordion_9_downloads_3_name] => 0
[page_accordion_9_downloads_4_download] => 0
[page_accordion_9_downloads_4_icon] => 0
[page_accordion_9_downloads_4_name] => 0
[page_accordion_9_editor] => 0
[page_accordion_9_red] => 0
[page_accordion_9_title] => 0
[page_accordion_10_downloads] => 0
[page_accordion_10_downloads_0_download] => 0
[page_accordion_10_downloads_0_icon] => 0
[page_accordion_10_downloads_0_name] => 0
[page_accordion_10_downloads_1_download] => 0
[page_accordion_10_downloads_1_icon] => 0
[page_accordion_10_downloads_1_name] => 0
[page_accordion_10_downloads_2_download] => 0
[page_accordion_10_downloads_2_icon] => 0
[page_accordion_10_downloads_2_name] => 0
[page_accordion_10_editor] => 0
[page_accordion_10_red] => 0
[page_accordion_10_title] => 0
[partners] => 0
[partners_0_partner_link] => 0
[partners_0_partner_logo] => 0
[partners_0_partner_name] => 0
[partners_1_partner_link] => 0
[partners_1_partner_logo] => 0
[partners_1_partner_name] => 0
[partners_2_partner_link] => 0
[partners_2_partner_logo] => 0
[partners_2_partner_name] => 0
[partners_3_partner_link] => 0
[partners_3_partner_logo] => 0
[partners_3_partner_name] => 0
[partners_4_partner_link] => 0
[partners_4_partner_logo] => 0
[partners_4_partner_name] => 0
[partners_5_partner_link] => 0
[partners_5_partner_logo] => 0
[partners_5_partner_name] => 0
[partners_6_partner_link] => 0
[partners_6_partner_logo] => 0
[partners_6_partner_name] => 0
[_dp_original] => 0
[_header_slideshow] => 0
[_header_slideshow_0_slide_image] => 0
[_header_slideshow_0_slide_text] => 0
[_header_slideshow_1_slide_image] => 0
[_header_slideshow_1_slide_text] => 0
[_project_who] => 0
[_related_agenda] => 0
[_related_news] => 0
[_related_project] => 0
[_header_slideshow_2_slide_image] => 0
[_header_slideshow_3_slide_image] => 0
[_news_image] => 0
[custom_term_fields_translation] => Array
[news_image] => 2
[project_image] => 2
[carousel] => 2
[agenda_banner] => 2
[show_quote] => 1
[link_url] => 1
[link_text] => 2
[link_show] => 1
[partners] => 1
[related_news] => 1
[hide_title] => 1
[bottom_quote] => 1
[middle_quote] => 1
[custom_posts_sync_option] => Array
[acf] => 0
[cpt_news] => 1
[cpt_agenda] => 1
[cpt_project] => 1
[mc4wp-form] => 1
[acf-field] => 0
[attachment] => 0
[wp_block] => 1
[post] => 1
[page] => 1
[wp_template] => 1
[popup] => 1
[custom_css] => 0
[customize_changeset] => 2
[oembed_cache] => 0
[user_request] => 0
[wp_global_styles] => 1
[popup_theme] => 1
[acf-taxonomy] => 1
[acf-post-type] => 1
[acf-ui-options-page] => 1
[acf-field-group] => 0
[sp_easy_accordion] => 1
[icl_additional_css] =>
[display_ls_in_menu] => 0
[menu_for_ls] => 0
[st] => Array
[strings_per_page] => 100
[icl_st_auto_reg] => auto-admin
[strings_language] => en
[translated-users] => Array
[0] => administrator
[db_ok_for_gettext_context] => 1
[sw] => Array
[use_header_text_domains_when_missing] => 0
[theme_localization_domains] => Array
[0] => cpt-news
[1] => news
[2] => cpt-agenda
[3] => brabantc
[4] => WordPress
[5] => default
[brabantc] => Array
[brabantc] => 212
[WordPress] => 100
[cpt-news] => 16
[news] => 2
[cpt-agenda] => 18
[default] => 12
[track_strings] => 1
[hl_color] => #FFFF00
[lang_of_domain] => Array
[brabantc] => nl
[use_original_cache] =>
[WPML_ST_Upgrade_MO_Scanning_4_has_run] => 1
[WPML_ST_Upgrade_DB_String_Packages_Word_Count_has_run] => 1
[WPML_ST_Upgrade_Migrate_Originals_has_run] => 1
[WPML_ST_Upgrade_Display_Strings_Scan_Notices_has_run] => 1
[WPML_ST_Upgrade_DB_String_Packages_2.4.2_has_run] => 1
[WPML_ST_Upgrade_DB_String_Name_Index_2_has_run] => 1
[WPML_ST_Upgrade_DB_Longtext_String_Value_has_run] => 1
[WPML_ST_Upgrade_DB_Strings_Add_Translation_Priority_Field_has_run] => 1
[WPML\ST\MO\Generate\Process\Status_background_has_run] => 1
[WPML\ST\Upgrade\Command\RegenerateMoFilesWithStringNames_has_run] => 1
[WPML\ST\Upgrade\Command\MigrateMultilingualWidgets_has_run] => 1
[WPML\ST\MO\Generate\Process\Status_has_run] => 1
[plugin_localization_domains] => Array
[popup-maker/popup-maker.php] => Array
[popup-maker] => 1278
[WordPress] => 48
[default] => 11
[wpforms-lite] => 1
[buddypress] => 14
[woocommerce] => 7
[wordpress-seo/wp-seo.php] => Array
[wordpress-seo] => 399
[wordproof] => 9
[updraftplus/updraftplus.php] => Array
[plugin-update-checker] => 1
[WordPress] => 39
[updraftplus] => 2455
[ updraftplus ] => 1
[default] => 2
[admin_text_3_2_migration_complete_40cd750bba9870f18aada2478b24840a] => 1
[admin_text_3_2_migration_complete_1919536f902c9efd7d20a6d877b5f68a] => 1
[sync_password] => 1
[xdomain_data] => 1
[xliff_newlines] => 1
[tm_xliff_version] => 12
[translation_service] =>
[taxonomies_sync_option] => Array
[organizer] => 1
[categorie] => 1
[discipline] => 1
[category] => 1
[post_tag] => 1
[wp_theme] => 0
[wp_template_part_area] => 1
[wp_pattern_category] => 1
[size] => 0
[show_translations_flag] => 1
[custom-types_sync_option] => Array
[mc4wp-form] => 1
[attachment] => 1
[wp_block] => 1
[wp_template] => 1
[popup] => 1
[admin_text_3_2_migration_complete_d91b1704b64b5177f68a84622b1b3a90] => 1
[just_reactivated] => 0
[admin_text_3_2_migration_complete_53124476f0465596f9cd5ad52f018988] => 1
[admin_text_3_2_migration_complete_e5961f7ed90c8c17549a336d3bdfc1f9] => 1
[admin_text_3_2_migration_complete_d1caaa643fb3e05876385a08f03f0707] => 1
[theme_localization_load_textdomain] => 0
[gettext_theme_domain_name] => wpml-media,default,acf,all-in-one-wp-migration,installer,wpml-translation-management,acfml
[edit_languages_flag_migration] => 1
[hidden_languages] => Array
[admin_text_3_2_migration_complete_2b6e8b8cb8fb5ef0f77189401780f703] => 1
[dont_show_help_admin_notice] => 1
[translated_document_status_sync] => 1
[sync_comments_on_duplicates] => 1
[tm_block_retranslating_terms] => 1
[site_does_not_use_icl] => 1
[admin_text_3_2_migration_complete_66945846737e03939ba81a8a9e2dfe7b] => 1
[WPML_Translate_Link_Target_Global_State] => 1
[admin_text_3_2_migration_complete_221d85a71efb8025133a72b5af86064a] => 1
[custom_posts_unlocked_option] => Array
[post] => 0
[page] => 0
[attachment] => 1
[custom_css] => 0
[customize_changeset] => 0
[oembed_cache] => 0
[user_request] => 0
[wp_block] => 0
[wp_template] => 1
[wp_global_styles] => 0
[popup] => 0
[popup_theme] => 0
[acf-taxonomy] => 0
[acf-post-type] => 0
[acf-ui-options-page] => 0
[sp_easy_accordion] => 0
[mc4wp-form] => 0
[cpt_news] => 0
[cpt_agenda] => 0
[cpt_project] => 0
[taxonomies_unlocked_option] => Array
[category] => 0
[post_tag] => 0
[wp_theme] => 0
[wp_template_part_area] => 0
[wp_pattern_category] => 0
[translation_priority] => 0
[categorie] => 0
[organizer] => 0
[discipline] => 0
[size] => 0
[language_per_domain_sso_enabled] =>
