Last updated by Dražen 1 year, 3 months ago.
May 1, 2024 at 10:34 am #15583582
madsG-2
ACF custom fields with the field type Text does not show up in the advanced translation editor when they contain numbers.
If I change the content to text the field shows up in the translation editor as expected.
I have added the function on this thread but it did not work:
https://wpml.org/forums/topic/custom-field-not-showing-in-classic-translation-editor-2/
May 1, 2024 at 11:36 am #15583766
Dražen
Thank you for contacting WPML support. While you are waiting for one of my colleagues to take this ticket and work on it, let me provide you with the first debugging steps and try to help with the issue quickly.
After implementing the custom code, you need to re-translate the current pages / make a small change, save and re-translate. For new pages, you can just search for the number value in ATE to translate it.
- https://wpml.org/announcements/2020/02/translating-links-with-advanced-translation-editor/
Let us know if this helps.
Drazen
May 1, 2024 at 2:45 pm #15584254
madsG-2
Thanks. It's working now. I missed the "search for the number value in ATE" part.
