Last updated by Bobby 1 year, 7 months ago.
Assisted by: Bobby.
September 11, 2024 at 9:09 am #16165303
paulW-64
We have a website that we are setting up for use with WPML and it uses the Custom Permalinks plugin for mapping the permalink for the categories.
I have the following versions installed: WPML: v4.6.12, Custom Permalinks: v2.7.0.
These were added when creating the categories initially and show as per the below DEFAULT LANGUAGE.
DEFAULT LANGUAGE - WORKS (English)
/industry-sectors/
/industry-sectors/infrastructure/
When viewing the 'Taxonomies Permalinks' for the Custom Permalinks plugins, these are the values shown
CUSTOM PERMALINKS - DOESN'T WORK
/en/industry-sectors/
/en/industry-sectors/infrastructure/
CURRENT SETUP FOR TRANSLATED LINKS - WORKS
/fr/secteurs-dactivite/
CURRENT SETUP FOR TRANSLATED LINKS - DOESN'T WORK
/fr/secteurs-dactivite/infrastructure-fr/
When using the Language selector in the menu and switching from the default language to French, this is the URL which appears is shown when I hover the cursor over the French flag.
DEFAULT - /industry-sectors/infrastructure/
SWITCH URL - /fr/category/secteurs-dactivite/infrastructure-fr/
While the switch URL above does show the data, but the permalink doesn't work as expected.
I investigated and the certified plugin states that it should work as expected, and I would hate to have to manually add each taxonomy permalink.
The permalink for translated taxonomies/categories does not work as expected when using the Custom Permalinks plugin with WPML.
Why doesn't the permalink for translated taxonomies/categories work as expected?
Is there a way to automatically map the permalinks for translated taxonomies/categories without manually adding each one?
September 11, 2024 at 6:39 pm #16167850
Bobby
WPML Supporter since 04/2015
Please review the following Errata of a known issue between this plugin and WPML.
https://wpml.org/errata/custom-permalinks-redirection-issue-with-trailing-slash/
There is a workaround listed, try it and let me know your results.
September 12, 2024 at 1:12 am #16168449
paulW-64
Unfortunately, this was no help.
I'm sent to a 404 page rather than retrieving the translated page using the custom permalinks plugin.
As shown by the uploaded image "wpml-cp-industry-sectors-tourism-fr-default-cp.png"
I reviewed this article to see if it would help - https://wpml.org/faq/how-can-i-reconnect-taxonomy-translations-to-their-default-language-terms/
The taxonomy/category for the translated French was connected to the default language as expected.
For the default languages these two (2) categories (Industry Sectors & Infrastructure) they have Custom Permalinks set as /industry-sectors/ & /industry-sectors/infrastructure/
As shown in the uploaded images
"wpml-cp-industry-sectors-en.png"
"wpml-cp-industry-sectors-infrastructure-en"
For the translated categories which should be served at these slugs/permalinks
/fr/secteurs-dactivite/ & /fr/secteurs-dactivite/infrastructure-fr/
When I viewed the translated categories
"wpml-cp-industry-sectors-fr.png"
This works using the default setup
However, this didn't, so I manually adjusted the permalink for this as a test
"wpml-cp-industry-sectors-infrastructure-fr.png"
Which worked as shown in this image
"wpml-cp-industry-sectors-infrastructure-fr-manual-added-cp.png"
As previously mentioned, I'm trying to avoid having to update/add a custom permalink for each language.
I'm not sure if this is a potential indicator with an issue in WPML, but if you look at the uploaded image "wpml-cp-investment-type-energy-en-menu-default-cp.png"
You will see how when attempting to switch from a category page in the default English to French, that the URL link as shown in the bottom left corner shows the default WordPress URL format which includes the word "category" (categorie - French)
I hope that you can shed some light on this.
September 13, 2024 at 3:59 am #16173847
Bobby
Thank you,
Bobby
September 16, 2024 at 12:17 am #16181038
paulW-64
I will get this setup and let you know when code has been deployed to an environment that is accessible.
September 16, 2024 at 5:14 pm #16185090
Bobby
Note: If you get an email reminding you to reply to us and the environment is not ready yet, please just send a quick update to make sure the thread remains open due to our automatic system.
September 18, 2024 at 10:46 pm #16195547
Bobby
If you edit the categories that you shared you will notice that the ID language includes the kategorie in the custom permalink field.
See here:
Removing manually resolves the issue, which is what I believe you have been doing so far from my understanding.
If you create a new category and translate it, are you able to reproduce this behavior?
Unfortunately I do not believe that there is a way to remove /kategori/ in bulk, at least not from WPML. You could tinker with a find-and-replace plugin for example and see if that would work.
September 19, 2024 at 12:13 am #16195621
paulW-64
I have created a new category and assigned a custom permalink.
Then I translated it as requested.
This however after the translation and sync of hierarchy, it didn't provide the correct custom permalink with the word category removed.
I will just handle manually updating the categories as I add a new translation.
I did have another issue where I was expecting that I would have a different Sitemap for each language as per the below URLs
However, the Indonesian version shown above doesn't work. Upon looking at the "Page Sitemap" from the existing/default language - hidden link
I can see that it has the translated version for the home page listed there.
I wanted to verify that this is the correct behavior?
September 19, 2024 at 10:32 pm #16200900
Bobby
Yes, that is the expected behavior. The only time you will have a separate URL for the sitemap is if your site is using a different domain per language.
September 20, 2024 at 12:27 am #16200976
paulW-64
One last item, within Custom Permalinks after the initial Taxonomy translations, the default language has the following permalinks listed within the Custom Permalinks plugins
/en/investment-types/
However, the links don't work and revert to what is set within the category settings of
/industry-sectors/
/investment-types/
I wanted to know if you are aware of this issue?
September 20, 2024 at 5:54 pm #16203923
Bobby
I can see what you mean by reviewing it, however, the site is not set up to use the directory in the default language. You can confirm or adjust that within WPML->Languages, therefore it is expected that the /en/ will be stripped.
Did the site use directories before at some point for the default language?
The topic ‘[Closed] Custom Permalinks not for taxonomies/categories’ is closed to new replies.
