Last updated by Osama Mersal 1 year, 11 months ago.
Assisted by: Osama Mersal.
August 28, 2023 at 4:52 pm #14302577
felixL-7
we are using WPML together with ACF custom post types with translation of custom post types enabled. However, there seems to be a strange issue we cannot resolve. When we click on the french switcher in the backend while being in the cutom post type posts overview, we receive an "Invalid post types" error.
On top, the custom post type toggle in settings shows, when viewed from teh frech backend, the french slug in the field for the english one. I could not figure out how to change this, using the troubleshooting options of WPML did not help either.
Many thanks for your support.
Jona
August 29, 2023 at 6:30 am #14304069
Osama Mersal
WPML Supporter since 02/2020
Hi Jona,
1) Would you please share screenshots or a screen-recorded video while reproducing the issue to help me understand it better?
2) It's not related to the issue, but according to your Debug.info, the WP memory limit needs to be increased. PHP memory is fine, but WordPress uses 40Mb as default. The minimum requirements for WPML are 128 MB. (Kindly check this page https://wpml.org/home/minimum-requirements/)
You can increase it by adding the following code in your wp-config.php file right before the /* That's all, stop editing! Happy publishing. */ line:
/* Memory Limit */
define( 'WP_MAX_MEMORY_LIMIT', '256M');
Osama
August 29, 2023 at 11:35 am #14306579
felixL-7
Hi, many thanks. We have increased the memory limit. Please find screenshot attached to understand the issue better. Looking very much forward to your response. Thanks
August 29, 2023 at 11:38 am #14306697
Osama Mersal
Thanks for your update. I would need to look closely at your site, so I would need to request temporary access (WP-Admin and FTP)
Your next answer will be private, which means only you and I can access it.
August 29, 2023 at 12:08 pm #14306855
Osama Mersal
Would you please check the access details? I got the following error. (Error: The password you entered for the username *** is incorrect. Lost your password?)
August 29, 2023 at 12:50 pm #14307307
Osama Mersal
Thanks for the access details. Would you please check if the project's post type works correctly?
August 29, 2023 at 12:53 pm #14307337
felixL-7
It does! Great! Kindly let me know what to do on the version to replicate the solution. Thanks a million!
The topic ‘[Closed] Custom post types with ACF and WPML’ is closed to new replies.
