The client is experiencing an issue where changes to the permalink of a custom post type (CPT) created with ACF Pro prior to version 6.2 are not being reflected in the WPML settings. The WPML settings page continues to display the original permalink instead of the updated one.
We recommend going to WPML -> String Translation, searching for the old slug, and deleting the string. After doing this, check if the slug is updated correctly in the WPML settings.
If this solution does not resolve your issue, please open a new support ticket with us.
Last updated by Osama Mersal 1 year, 7 months ago.
Assisted by: Osama Mersal.
November 2, 2023 at 4:37 pm #14719683
andiG
Dear Support
We found a bug within the latest plugin-versions of WPML and ACF Pro.
Case description: If you add a CPT with ACF Pro (current version) and enter a custom permalink, that is correctly displayed within WPML Settings to translate to another language. Doing a change of the permalink in ACF Pro, that change is shown in WPML Settings without any problems too.
BUT, it looks like that for existing CPTs that were added with a ACF Pro Version PRIOR to 6.2, changes in the permalink are NOT reflected within WPML Settings. WPML-Settings page shows always the original permalink that was added the first time when the CPT setup was done. ("abc" was entered in ACF, but WPML-Settings is still showing the original value from ACF).
So we need a way to push this permalink to WPML to translate it. We got stuck in a project where we need to change the URLs during the next days!
How can we update the permalink of the default language to reflect the permalink-change in ACF Pro?
We really appreciate your help to get not stuck in our project!
Best, Andi
Screenshot 2023-11-02 at 16-44-20 Edit Post Type “DP Comments” ‹ SASIS — WordPress.png
November 5, 2023 at 9:34 am #14732555
Osama Mersal
WPML Supporter since 02/2020
Hi Andi,
First of all, sorry for the late reply due to a higher workload. I would need to request temporary access (WP-Admin and FTP).
Your following answer will be private, which means only you and I can access it.
Osama
November 6, 2023 at 10:24 am #14736479
andiG
Hello Osama
I will provide some staging-setup later on the day.
But it looks like a generel error. Even changes in the default language for German for the category-slug are not transfered to WPML.
Screenshot 2023-11-06 at 11-21-40 Permalink Settings ‹ SASIS — WordPress.png
November 6, 2023 at 10:42 am #14736689
Osama Mersal
Please go to WPML-> String Translation, search for the old slug, and delete the string.
After that, please check if the slug will be updated correctly.
Osama
November 7, 2023 at 1:21 pm #14747491
andiG
Yes, that solves the issue with "category" and the other not updated strings.
Best, Andi
