After installing the WPML Multilingual CMS plugin, the site admin panel stops working and displays a critical error. The error message indicates that the class 'DOMDocument' is not found, which is part of a PHP extension that may not be enabled on the server.
If you're experiencing a critical error after installing the WPML Multilingual CMS plugin and the error message mentions that the 'DOMDocument' class is not found, we recommend checking if the PHP XML extension is enabled on your server, as the 'DOMDocument' class is part of this extension. A similar issue was resolved by another client, and you can follow the steps provided in this thread: https://wpml.org/forums/topic/fatal-error-when-trying-to-access-installed-plugin/#post-12615561.
Last updated by Noman 1 year, 7 months ago.
Assisted by: Noman.
December 27, 2023 at 8:17 pm #15133346
artakG
After installing the "sitepress multilingual cms" plugin, the site admin panel stops working and gives a critical error.
Until today the site was working fine. Today I received an email with the following content:
" Howdy!
WordPress has a built-in feature that detects when a plugin or theme causes a fatal error on your site, and notifies you with this automated email.
In this case, WordPress caught an error with one of your plugins, WPML Multilingual CMS.
When seeking help with this issue, you may be asked for some of the following information:
WordPress version 6.4.2
Active theme: Hendon Child (version 1.0.0)
Current plugin: WPML Multilingual CMS (version 4.6.8)
PHP version 8.0.30
Error Details
An error of type E_ERROR was caused in line 67 of the file /home5/sqinfosq/public_html/wp-content/plugins/sitepress-multilingual-cms/classes/xml-config/class-wpml-xml-config-validate.php. Error message: Uncaught Error: Class "DOMDocument" not found in /home5/sqinfosq/public_html/wp-content/plugins/sitepress-multilingual-cms/classes/xml-config/class-wpml-xml-config-validate.php:67
Stack trace:
#0 /home5/sqinfosq/public_html/wp-content/plugins/sitepress-multilingual-cms/classes/xml-config/class-wpml-xml-config-validate.php(51): WPML_XML_Config_Validate->get_xml()
#1 /home5/sqinfosq/public_html/wp-content/plugins/sitepress-multilingual-cms/classes/xml-config/class-wpml-xml-config-validate.php(34): WPML_XML_Config_Validate->from_string()
#2 /home5/sqinfosq/public_html/wp-content/plugins/sitepress-multilingual-cms/classes/xml-config/read/class-wpml-xml-config-read-file.php(18): WPML_XML_Config_Validate->from_file()
#3 /home5/sqinfosq/public_html/wp-content/plugins/sitepress-multilingual-cms/classes/xml-config/class-wpml-config.php(306): WPML_XML_Config_Read_File->get()
#4 /home5/sqinfosq/public_html/wp-content/plugins/sitepress-multilingual-cms/classes/xml-config/class-wpml-config.php(43): WPML_Config::parse_wpml_config_files()
#5 /home5/sqinfosq/public_html/wp-content/plugins/sitepress-multilingual-cms/classes/xml-config/class-wpml-config.php(34): WPML_Config::load_config_run()
#6 /home5/sqinfosq/public_html/wp-content/plugins/sitepress-multilingual-cms/inc/translation-management/translation-management.class.php(258): WPML_Config::load_config()
#7 /home5/sqinfosq/public_html/wp-includes/class-wp-hook.php(324): TranslationManagement->init()
#8 /home5/sqinfosq/public_html/wp-includes/class-wp-hook.php(348): WP_Hook->apply_filters()
#9 /home5/sqinfosq/public_html/wp-includes/plugin.php(517): WP_Hook->do_action()
#10 /home5/sqinfosq/public_html/wp-settings.php(643): do_action()
#11 /home5/sqinfosq/public_html/wp-config.php(95): require_once('/home5/sqinfosq...')
#12 /home5/sqinfosq/public_html/wp-load.php(50): require_once('/home5/sqinfosq...')
#13 /home5/sqinfosq/public_html/wp-admin/admin.php(34): require_once('/home5/sqinfosq...')
#14 /home5/sqinfosq/public_html/wp-admin/themes.php(10): require_once('/home5/sqinfosq...')
#15 {main}
thrown "
After deactivating the plugin, the admin panel started working.
December 28, 2023 at 7:40 am #15133742
Noman
WPML Supporter since 06/2016
Thank you for contacting WPML Support. We have another client who had a similar issue and was able to fix it by following the below thread: https://wpml.org/forums/topic/fatal-error-when-trying-to-access-installed-plugin/#post-12615561
Please let me know if this resolves your issue or if you need further assistance with this issue.
Thank you
December 28, 2023 at 8:34 am #15133804
artakG
After adding DOM extension the problem is resolved.
Thank You!
