The client is unable to translate the footer designed with Divi Theme Builder using WPML. The footer appears untranslated in the English version even after attempting direct translation in the Divi Theme Builder and using WPML's translation tools.
1. Open the Footer template for editing by navigating to the specific post in the WordPress admin area.
2. Make a minor change in the template to refresh the translation settings.
3. Update the template.
4. Update the translation using the WPML Advanced Translation Editor.
5. Visit the English homepage to see the changes.
If this solution does not resolve your issue, or if it seems outdated or irrelevant to your specific case, we recommend opening a new support ticket. Additionally, we highly recommend checking related known issues at https://wpml.org/known-issues/, verifying the version of the permanent fix, and confirming that you have installed the latest versions of themes and plugins. For further assistance, please visit our support forum at WPML support forum.
This topic contains 1 replies, has 2 voices.
Last updated by Bigul 10 months ago.
Assisted by: Bigul.
September 11, 2024 at 3:17 pm
edoardoA-4
I am trying to translate the footer designed with Divi Theme Builder on my site hidden link. I tried directly on the english area of Divi Theme Builder (successful for the header menu) and then with your translator. In the first case, if I translate in english, I see the translation also in italian. In the second case, I translate the strings but nothing changes on english version. If I can choose, I'd like to translate the footer directly on Divi Theme Builder, as I did with the header.
The footer designed with Divi Theme Builder is not translated.
How can I translate the footer designed with Divi Theme Builder using WPML?
September 11, 2024 at 3:45 pm
September 11, 2024 at 4:39 pm #16167587
Bigul
WPML Supporter since 01/2013
I am getting the expected results for the Footer after the following steps.
1) Open the Footer template for editing - hidden link
2) Make a minor change in the template to refresh the translation settings
3) Update the template
4) Update the translation from the WPML Advanced Translation Editor
5) Visit the English homepage - hidden link
Please check the attached images for more details and let us know your feedback.
Bigul
September 12, 2024 at 7:58 am #16169410
edoardoA-4
It works! Thank you very much!
