You are trying to translate the Divi Supreme post carousel with a loop from a custom post type 'Producten (products)'. You expected to see a loop from the translated custom post type 'Producten' in each language (EN, FR, DE), but instead, you got a loop from the original language (NL - Dutch).
We recommend increasing the memory limit as a first step. After that, deactivate all plugins except for WPML, ACF, and Divi Supreme. If the posts appear correctly after this step, reactivate the plugins one by one to identify which one causes the issue. In this specific case, the 'WP File Download' plugin was causing the issue. Deactivate this plugin and check if the posts appear correctly in English.
Please note that this solution might be outdated or not applicable to your specific case. We highly recommend checking related known issues at https://wpml.org/known-issues/, verifying the version of the permanent fix, and confirming that you have installed the latest versions of themes and plugins. If the problem persists, please open a new support ticket.
Last updated by Osama Mersal 3 months, 4 weeks ago.
Assisted by: Osama Mersal.
February 20, 2025 at 9:38 am #16728351
pieterC-9
I am trying to translate the Divi Supreme post carousel with a loop from a custom post type 'Producten (products)'. The issue can be seen on this page: hidden link
I expected to see a loop from the translated custom post type 'Producten' in each language (EN, FR, DE), but instead, I got a loop from the original language (NL - Dutch).
How can I ensure the Divi Supreme post carousel displays the translated custom post type 'Producten' in each language?
February 20, 2025 at 4:24 pm #16730671
Osama Mersal
WPML Supporter since 02/2020
I would need to look closely at your site, so I would need to request temporary access (WP-Admin and FTP)
Osama
February 25, 2025 at 9:51 am #16744767
Osama Mersal
Thanks for the access details. I get a fatal error even in the default language when trying to edit any product to check the categories issue. (hidden link)
Would you please check it and share the error log with me?
Osama
February 25, 2025 at 10:21 am #16744911
pieterC-9
I've enabled the wp_debug. Here is the error.
February 25, 2025 at 11:11 am #16745159
Osama Mersal
Thanks for the error log. I fixed the error by increasing the memory limit. After that, I deactivated the plugins except WPML, ACF, and Divi Supreme.
The posts appeared correctly after deactivating the plugins, so I activated them one by one and checked the issue. The issue happens when the "WP File Download" plugin is activated.
I deactivated this plugin, so please check if the posts appear correctly in English. (hidden link)
Osama
February 25, 2025 at 12:30 pm #16745636
pieterC-9
Thank you for your support!
I can see that ‘WP File Download’ is indeed the issue.
So I guess I need to contact their support team?
February 25, 2025 at 12:38 pm #16745685
Osama Mersal
Yes, please get in touch with their support team, consult them regarding this issue, and let us know their findings.
Osama
