You are trying to connect multiple domains (EE, LV, CZ, DE) for your multilingual site using WPML, which previously worked without issues. However, now the domains do not validate and fail to connect despite active SSL certificates.
We have identified SSL issues with your domains. We recommend contacting your domain provider to check and resolve these SSL issues. If the problem persists after their intervention, please visit our support forum for further assistance. We also suggest checking related known issues at https://wpml.org/known-issues/, verifying the version of the permanent fix, and confirming that you have installed the latest versions of themes and plugins.
If this solution does not apply because it might be outdated or not relevant to your case, we highly recommend opening a new support ticket.
Last updated by Kor 1 year, 8 months ago.
August 15, 2024 at 11:31 am #16074120
vitaliN-2
I am trying to connect multiple domains (EE, LV, CZ, DE) for my site hidden link using WPML. Everything was working fine for years, but now the domains do not validate. I have checked the SSL certificates, and they are active with no issues.
The EE, LV, CZ, DE domains do not validate and do not connect.
Why are the EE, LV, CZ, DE domains not validating?
What steps can I take to resolve the domain validation issue?
August 15, 2024 at 12:34 pm #16074312
Thanks for reaching us.
I've checked your language domains and I'm able to see SSL issues as shown in the attached screenshot. Could you check with your domain provider to see if they can fix this for you?
