Last updated by Bobby 3 days, 14 hours ago.
Assisted by: Bobby.
March 3, 2026 at 1:17 pm #17868595
walterS-22
Hello, sorry, I again clicked on the much larger resolved button. The issue that despite authorization, editors do not have access to most of WPMLs functions is unresolved. PLEASE look at the screenshots.
March 3, 2026 at 11:50 pm #17870292
Bobby
WPML Supporter since 04/2015
An editor by default does not have access to WPML.
Going to WPML->Translation Dashboard->Manage Translators & Services you can add them as a translator (which you did already)
------> This gives the editor access to translate content.
For example they can now go to WPML->Translations and translate any content you or another Translation Manager assigns to them.
OR
They can go to pages or posts and click on the + button to add a translation.
They also have the ability to edit the translation if need be.
On the other hand, if they are added as a Translation Manager they will now have access to:
-----> Translate content, Access to Translation Dashboard, and String Translation.
The overall idea is that with the Editor role they can translate items that are either assigned to them (by a manager) OR go to pages/posts and translate an item.
March 10, 2026 at 5:03 pm #17886544
walterS-22
Hi, Bobby,
thank you and sorry for the delay: flu has struck me down. I understand clearly what you are syaing. But that is not what I asked you about:
In this version the editor has no way to access the glossary-function. Which without saying is elementary when translating texts. So, how can I grant access to an editor to the glossary function?
Olaf
March 10, 2026 at 10:01 pm #17887154
Bobby
Hi Olaf,
The Glossary helps with the translation accuracy, this should happen automatically regardless if an editor or translation manager or even an admin is using the software.
The only access an editor does not have is to the glossary directly (not it's use)
The glossary applies directly within the Advanced Translation Editor.
However, if you want them to have access to the Glossary in terms of updating it, removing or adding items then they need to be a translation manager.
"Once created, automatic translation engines will use the glossary entry to correctly translate your terms, and translators will receive additional context during translation."
https://wpml.org/documentation/translating-your-contents/advanced-translation-editor/how-to-create-and-manage-glossary-entries/?utm_source=plugin&utm_medium=gui&utm_campaign=translation-tools&utm_term=banner
March 12, 2026 at 1:21 pm #17892401
walterS-22
They ARE registered as translators for both languages. As I stated before …
March 12, 2026 at 7:00 pm #17893690
Bobby
I understand, and in this case they should be able to see the glossary translations take effect automatically.
Is this not happening? If yes, we will need to further review by accessing the backend.
NOTE that they are not going to be able to add their own glossary items but they should be able to see the glossary items automatically applied, that is a global setting.
March 16, 2026 at 8:31 am #17898956
walterS-22
Okay, thank you, Bobby,
of course would it be helpful if folks with translator access could also enter glossary terms. It's an important part of translating 😉
March 16, 2026 at 8:55 pm #17901770
Bobby
Completely understand and will make sure to bring to the attention of our team as a feature request.
In the meantime the only way would be to give them translation manager access which stills keeps them on the Editor level but with more WPML access.
